Unable to restore container
can someone explain to me what is the problem, when i try to import a
container instance from a tarball this error message appears
# lxc import teampass-06-01-2021.tar.xz teampass27-2 -s www_pool2
Error: Post hook: Failed to run: resize2fs /dev/vg_ct_100/containers_teampass27–2 1953125K: resize2fs 1.44.1 (24-Mar-2018)
resize2fs: New size smaller than minimum (548890)
the container backup was created from this command
# lxc export teampass teampass-$(date +'%m-%d-%Y').tar.xz
but there is no problem to import the instance to a default storage(with drive dir)
storage www_pool2 info:
  lvm.use_thinpool: "false"
  lvm.vg_name: vg_ct_100
  source: vg_ct_100
  volatile.initial_source: vg_ct_100
driver: lvm
@parallax are you using profiles? Can you show the output of lxc profile show default?
Also, which version of LXD is this?
Finally, can you open the tarball and attach the backup/container/backup.yaml file from inside?
Also could you import it into a dir pool and then show the output of:
lxc config show <instance> --expanded
lxd 4.14 20450
lxc config show teampass27-3 --expanded
  image.architecture: amd64
  image.description: Centos 7 amd64 (20210211_07:08)
  image.os: Centos
  image.release: "7"
  image.serial: "20210211_07:08"
  image.type: squashfs
  image.variant: default
  volatile.base_image: 8d34dbf5b85f69a4dd73939059b9f676efb39066ca91814761e4f0cb3f44321c
  volatile.eth0.host_name: veth5cb76101
  volatile.eth0.hwaddr: 00:16:3e:68:39:93
  volatile.eth1.host_name: vport16
  volatile.eth1.hwaddr: 00:16:3e:e7:dd:82
  volatile.eth1.name: eth1
  volatile.idmap.base: "0"
  volatile.uuid: 20e588f7-ae4c-4f69-82da-ea4850aef75a
    ipv4.address: 10.30.26.100
    network: lxdbr1
  eth1:
    host_name: vport16
    nictype: bridged
    parent: mybridge
  proxyv4:
    connect: tcp:0.0.0.0:80
    listen: tcp:10.64.0.151:8080
    nat: "true"
    type: proxy
    pool: default
  shared1:
    path: /host-data
    source: /home/david/teampass-mount/
- web2
config: {}
    network: lxdbr1
    pool: default
- /1.0/instances/nginx
- /1.0/instances/ksm45
- /1.0/instances/c3
- /1.0/instances/teampass
- /1.0/instances/teampass27
- /1.0/instances/teampass27-3
lxc profile show web2
config: {}
    pool: lvm_thinpool1
- /1.0/instances/c3
cat backup.yaml
container:
    image.os: Centos
    image.release: "7"
      network: lxdbr1
    eth1:
      host_name: vport16
      nictype: bridged
      parent: mybridge
    proxyv4:
      nat: "true"
      type: proxy
      pool: www_pool2
    shared1:
      path: /host-data
  - web2
  created_at: 2021-05-17T09:23:54.743007096+04:00
  expanded_config:
    image.os: Centos
    image.release: "7"
  expanded_devices:
      network: lxdbr1
    eth1:
      host_name: vport16
      nictype: bridged
      parent: mybridge
    proxyv4:
      nat: "true"
      type: proxy
      pool: www_pool2
    shared1:
      path: /host-data
  status: Running
  status_code: 103
  last_used_at: 2021-05-17T09:24:34.020453344+04:00
  type: container
pool:
    source: vg_ct_100
  driver: lvm
  used_by: []
  status: Created
  locations:
  - none
volume:
    block.filesystem: ext4
    block.mount_options: discard
  type: container
  used_by: []
  content_type: filesystem
If you start up and login to the container imported to the dir pool, what does the output of du -h / show?
It looks to me like the container is actually bigger than its configured 2GB size, suggesting that either there’s a file that has been expanded somehow during export or import, or that the original source LVM volume had been manually grown alongside the filesystem without LXD knowing about it.
Do you know if the source LVM volume from which the export was made had been resized manually?
Also what OS and version are you running on the LXD host?
CentOS Linux release 7.9.2009 (Core)
moving between storages works
moved the container from default storage to www_pool2
lxc move teampass27-3 teampass27-3 -s www_pool2
and here is the output of df:
Filesystem                            Size  Used Avail Use% Mounted on
/dev/vg_ct_100/containers_teampass27  1.9G  1.2G  531M  70% /
none                                  492K  4.0K  488K   1% /dev
devtmpfs                              7.8G     0  7.8G   0% /dev/tty
tmpfs                                 100K     0  100K   0% /dev/lxd
/dev/mapper/centos-root                17G  9.2G  7.9G  54% /host-data
tmpfs                                 100K     0  100K   0% /dev/.lxd-mounts
none                                   10M     0   10M   0% /sys/fs/cgroup
tmpfs                                 7.8G     0  7.8G   0% /dev/shm
tmpfs                                 7.8G  8.2M  7.8G   1% /run
tmpfs                                 1.6G     0  1.6G   0% /run/user/0
i think lxd sees the actual size of the storage
vgs
  VG        #PV #LV #SN Attr   VSize    VFree
  vg_ct_100   1   5   0 wz--n- <120.00g <57.59g
lxc storage info www_pool2
info:
  driver: lvm
  space used: 71.01GB
  total space: 128.84GB
Great, at least thats a workaround.
Would it be possible to make that container backup file available for me to download somehow and try importing it locally?
a download link sent to your email
The link had expired when I tried to download it.
please check your email for new link
Got it thanks
Thanks. I’ve recreated the issue.
I believe the problem is that the ext4 resize2fs command is estimating that it needs more disk space to shrink the volume than would be available at the original specified size of 2GB.
I can workaround it with this PR, that forces the resize and disables the safety checks:
https://github.com/lxc/lxd/pull/8864
But I am concerned this introduces the possibility of corrupting filesystems in other scenarios.
One workaround (in addition to the one you used above) is to edit the backup.yaml file in container directory inside the tarball and increase the disk size to 3GB.
This is fixed in:
https://github.com/lxc/lxd/pull/8875
