Unable to run planka on unprivilved LXD container can't mount /proc
I am trying to run the following in docker-compose under an alpine container (running docker with a uid map as well). Here is the yaml
services:
  planka:
    image: ghcr.io/plankanban/planka:latest
    restart: on-failure
    volumes:
      - user-avatars:/app/public/user-avatars
      - project-background-images:/app/public/project-background-images
      - attachments:/app/private/attachments
    ports:
      - 127.0.0.1:3000:1337
    environment:
      - BASE_URL=<edacted>
      - DATABASE_URL=postgresql://postgres@postgres/planka
      - SECRET_KEY=<redacted>
      - TRUST_PROXY=1
      - DEFAULT_ADMIN_EMAIL=<redacted>
      - DEFAULT_ADMIN_PASSWORD=<redacted>
      - DEFAULT_ADMIN_NAME=<redacted>
      - DEFAULT_ADMIN_USERNAME=<redacted>
    depends_on:
      postgres:
        condition: service_healthy
  postgres:
    image: postgres:16-alpine
    restart: on-failure
    volumes:
      - db-data:/var/lib/postgresql/data
    environment:
      - POSTGRES_DB=planka
      - POSTGRES_HOST_AUTH_METHOD=trust
    healthcheck:
      test: ["CMD-SHELL", "pg_isready -U postgres -d planka"]
      interval: 10s
      timeout: 5s
      retries: 5
volumes:
  user-avatars:
  db-data:
Here is the error message:
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "proc" to rootfs at "/proc": mount src=proc, dst=/proc, dstFd=/proc/thread-self/fd/8, flags=MS_NOSUID|MS_NODEV|MS_NOEXEC: operation not permitted
I figured it out. Having docker ‘change’ contexts within an non-privleged container results in this error. Running docker without this (kind of not necessary, since our container is non-privileged anyways) seems to fix it. I would be curious to see if I could do this anyways…
