OK, I can see how this might have been a case of “thin pool” running out of disk space. When I ran sudo lvs at the start, it showed Data% as being at 100% for LXDThinPool. This is what it shows now:
[d24lau-adm@marmoset03 ~]$ sudo lvs
LV VG Attr LSize Pool Origin Data% Meta% Move Log Cpy%Sync Convert
root centos -wi-ao---- 185.82g
swap centos_marmoset03 -wi-ao---- 119.24g
LXDThinPool default twi-aotz-- <32.46g 86.26 3.63
containers_marmoset--build--ece--05 default Vwi---tz-k 10.00g LXDThinPool
containers_marmoset--build--ece--06 default Vwi-aotz-k 10.00g LXDThinPool 44.59
containers_marmoset--build--mme--01 default Vwi---tz-k <9.32g LXDThinPool
containers_marmoset03--submit--01 default Vwi-aotz-k 10.00g LXDThinPool containers_marmoset03--submit--01-certificates_installed 72.90
containers_marmoset03--submit--01-apache2_setup default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-backup_03 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--01-backup_04 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--01-backup_05 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--01-backup_06 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--01-before_ME_101_projects_uploaded default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--01-certificates_installed default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-database_setup default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-marmoset_builded default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-marmoset_cloned default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-mod_auth_cas_installed default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--01-mod_jk_installed default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-mysql_setup default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-submitserver_configured default Vri---tz-k 10.00g LXDThinPool
containers_marmoset03--submit--01-test_dpkg default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--05 default Vwi---tz-k <9.32g LXDThinPool containers_marmoset03--submit--01
containers_marmoset03--submit--05-apache2_setup default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-apache2_setup
containers_marmoset03--submit--05-backup_03 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-backup_03
containers_marmoset03--submit--05-backup_04 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-backup_04
containers_marmoset03--submit--05-backup_05 default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-backup_05
containers_marmoset03--submit--05-before_ME_101_projects_uploaded default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-before_ME_101_projects_uploaded
containers_marmoset03--submit--05-certificates_installed default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-certificates_installed
containers_marmoset03--submit--05-database_setup default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-database_setup
containers_marmoset03--submit--05-marmoset_builded default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-marmoset_builded
containers_marmoset03--submit--05-marmoset_cloned default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-marmoset_cloned
containers_marmoset03--submit--05-mod_auth_cas_installed default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-mod_auth_cas_installed
containers_marmoset03--submit--05-mod_jk_installed default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-mod_jk_installed
containers_marmoset03--submit--05-mysql_setup default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-mysql_setup
containers_marmoset03--submit--05-submitserver_configured default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-submitserver_configured
containers_marmoset03--submit--05-test_dpkg default Vri---tz-k 10.00g LXDThinPool containers_marmoset03--submit--01-test_dpkg
images_a92eaa65a5c5e53c6bf788b4443f4e5d2afac1665486247c336aa90959522bb6 default Vwi---tz-k <9.32g LXDThinPool
I’m not quite sure what you mean when you say “unmount and remount”. Do you mean that I need to unmount and remount LXDThinPool, and that I should run fsck on LXDThinPool in between the unmount and remount?
-----edit-----
From my previous experience unmounting and remounting on a Ubuntu host (this is a Centos host), here are the commands that are my best guess at doing this:
For the unmount:
sudo umount /var/snap/lxd/common/lxd/storage-pools/default
For the remount:
sudo mount /var/snap/lxd/common/lxd/disks/default.img /var/snap/lxd/common/lxd/storage-pools/default
Does this look like I’m on the right track?
-----edit-----
No, the umount didn’t work:
[d24lau-adm@marmoset03 ~]$ sudo umount /var/snap/lxd/common/lxd/storage-pools/default
umount: /var/snap/lxd/common/lxd/storage-pools/default: not mounted
-----edit-----
Here is part of what lsblk shows:
sdi 8:128 0 1.8T 0 disk
├─sdi1 8:129 0 1.6T 0 part
│ └─md127 9:127 0 8.1T 0 raid5 /home
└─sdi2 8:130 0 202.9G 0 part
└─md126 9:126 0 1013.8G 0 raid5 /scratch
loop0 7:0 0 55M 1 loop /var/lib/snapd/snap/core18/1880
loop1 7:1 0 96.6M 1 loop /var/lib/snapd/snap/core/9804
loop2 7:2 0 55.3M 1 loop /var/lib/snapd/snap/core18/1885
loop3 7:3 0 68.6M 1 loop /var/lib/snapd/snap/lxd/17320
loop4 7:4 0 70.6M 1 loop
loop5 7:5 0 68.6M 1 loop /var/lib/snapd/snap/lxd/17497
loop6 7:6 0 34.5G 0 loop
├─default-LXDThinPool_tmeta 253:2 0 1G 0 lvm
│ └─default-LXDThinPool-tpool 253:4 0 32.5G 0 lvm
│ ├─default-LXDThinPool 253:5 0 32.5G 0 lvm
│ ├─default-containers_marmoset03----submit----01 253:6 0 10G 0 lvm
│ └─default-containers_marmoset----build----ece----06 253:7 0 10G 0 lvm
└─default-LXDThinPool_tdata 253:3 0 32.5G 0 lvm
loop7 7:7 0 97.1M 1 loop /var/lib/snapd/snap/core/9993
loop8 7:8 0 59.6G 0 loop
├─pool02-LXDThinPool_tmeta 253:8 0 1G 0 lvm
│ └─pool02-LXDThinPool 253:10 0 57.6G 0 lvm
└─pool02-LXDThinPool_tdata 253:9 0 57.6G 0 lvm
So I ran fsck on default-containers_marmoset03----submit----01 and it just shows
[root@marmoset03 disks]# fsck default-containers_marmoset03----submit----01
fsck from util-linux 2.23.2
Since fsck didn’t report any errors, am I to assume that things look OK with that volume?
