stgraber@dakara:~$ incus version
Client version: 6.18
Server version: 6.18
stgraber@dakara:~$ incus admin os system backup
Description:
Backup the system
Usage:
incus admin os system backup [<remote>:] <file> [flags]
Flags:
-d, --data Command data
--target Cluster member name
Global Flags:
--debug Show all debug messages
--force-local Force using the local unix socket
-h, --help Print help
--project Override the source project
-q, --quiet Don't show progress information
--sub-commands Use with help or --help to view sub-commands
-v, --verbose Show all information messages
--version Print version number
stgraber@dakara:~$
bastien@precision ~ % incus version
Client version: 6.17
bastien@precision ~ % incus admin os system backup
Error: unknown command "backup" for "incus admin os system"
My last update on Arch was just a few days ago, but indeed after the upgrade:
Description:
Backup the system
Usage:
Flags:
Global Flags:
The CLI actually was reworked a bit more recently so will look slightly different under Incus 6.19 (mostly introducing a bunch of sub-commands like incus admin os system storage edit instead of incus admin os system edit storage.
So moving the entity (storage) to be its own set of sub-commands (show/edit) rather than being an argument to a generic show/edit set of commands.
That’s basically the precursor for supporting incus admin os system storage info for example as the info type commands will need to have endpoint specific logic and so can’t just go through a generic function.
