systemd seems quite unhappy when a host is shutting down and there is an unprivileged container still running:
A stop job is running for Session 2 of user zub (30s / 1min 30s)
The host does eventually shut down, but only after waiting 1.5 min for - presumably - lxc to shut down. Looking into systemd journal I don’t see much that would seem relevant, perhaps except for:
Feb 13 10:07:18 bug systemd-logind[969]: System is rebooting.
Feb 13 10:07:18 bug systemd[1]: Stopping Session 2 of user zub.
Feb 13 10:07:18 bug systemd[1]: lxc.service: Control process exited, code=exited, status=1/FAILURE
Feb 13 10:07:18 bug systemd[1]: lxc.service: Failed with result 'exit-code'.
Feb 13 10:07:18 bug systemd[1]: Stopped LXC Container Initialization and Autoboot Code.
Feb 13 10:07:18 bug systemd[1892]: var-lib-lxcfs.mount: Succeeded.
Feb 13 10:07:18 bug systemd[1]: Stopped LSB: NFC daemon.
Feb 13 10:07:18 bug systemd[1]: var-lib-lxcfs.mount: Succeeded.
Feb 13 10:07:18 bug systemd[1]: Unmounted /var/lib/lxcfs.
Feb 13 10:07:18 bug fusermount[5717]: /bin/fusermount: failed to unmount /var/lib/lxcfs: Invalid argument
Feb 13 10:07:18 bug systemd[1]: lxc-net.service: Succeeded.
Feb 13 10:07:18 bug systemd[1]: Stopped LXC network bridge setup.
Feb 13 10:07:18 bug systemd[1]: lxcfs.service: Succeeded.
Feb 13 10:07:18 bug systemd[1]: Stopped FUSE filesystem for LXC.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Stopping timed out. Killing.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 4741 (lxc-start) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 4751 (systemd) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5765 (systemd-journal) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5767 (systemd-logind) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5770 (dbus-daemon) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5766 (systemd-network) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5771 (rsyslogd) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5774 (systemd-resolve) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5769 (agetty) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5763 (agetty) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5768 (agetty) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5764 (agetty) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5762 (agetty) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5781 (gdm3) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5785 (accounts-daemon) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5794 (polkitd) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5786 (gmain) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Killing process 5795 (gmain) with signal SIGKILL.
Feb 13 10:08:48 bug systemd[1]: session-2.scope: Failed with result 'timeout'.
Feb 13 10:08:48 bug systemd[1]: Stopped Session 2 of user zub.
Feb 13 10:08:48 bug systemd[1]: Stopping Login Service...
Feb 13 10:08:48 bug systemd[1]: Stopping User Manager for UID 1002...
I wonder why is this happening. I would expect systemd to notify lxc it should shut down (perhaps via SIGHUP or so?), and I would expect lxc then to shut the container down.
If I run lxc-stop -n <container-name> to stop the container manually prior to shut down, then the container quickly shuts down and when I then shut down the host, it also shuts down correctly.
I’m on Debian testing and the containers I run are various versions of Ubuntu. I’m running lxc 3.0.4 and systemd 244.
I’m grateful for any ideas/pointers on where to look/explanations about what happens in this case.
