Unprivileged container - tar: can't create node ./dev/urandom: Operation not permitted
I am trying to run unprivileged lxc container in openwrt (lxc 2.1.1). I am getting Operation not permitted error…
Any idea? Thanks
root@OpenWrt:~# lxc-create --name ubuntu -t download -- --server images.linuxcontainers.org -d ubuntu -r bionic -a amd64
Setting up the GPG keyring
Downloading the image index
Downloading the rootfs
Downloading the metadata
The image cache is now ready
Unpacking the rootfs
tar: can't create node ./dev/ptmx: Operation not permitted
tar: can't create node ./dev/tty: Operation not permitted
tar: can't create node ./dev/random: Operation not permitted
tar: can't create node ./dev/full: Operation not permitted
tar: can't create node ./dev/zero: Operation not permitted
tar: can't create node ./dev/null: Operation not permitted
You just created an Ubuntu bionic amd64 (20180719_08:51) container.
To enable SSH, run: apt install openssh-server
No default root or user password are set by LXC.
Host mounts:
root@ubuntu:~# cat /proc/self/mounts
/dev/root / ext4 rw,noatime,block_validity,delalloc,barrier,user_xattr 0 0
none /dev tmpfs rw,relatime,size=492k,mode=755,uid=100000,gid=100000 0 0
proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0
proc /proc/sys proc ro,nosuid,nodev,noexec,relatime 0 0
proc /proc/sysrq-trigger proc ro,nosuid,nodev,noexec,relatime 0 0
sysfs /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0
sysfs /sys sysfs ro,nosuid,nodev,noexec,relatime 0 0
sysfs /sys/devices/virtual/net sysfs rw,relatime 0 0
sysfs /sys/devices/virtual/net sysfs rw,nosuid,nodev,noexec,relatime 0 0
sysfs /sys/fs/fuse/connections sysfs rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,noatime 0 0
sysfs /sys/kernel/security sysfs rw,nosuid,nodev,noexec,relatime 0 0
mqueue /dev/mqueue mqueue rw,relatime 0 0
proc /proc/sys/fs/binfmt_misc proc rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/null tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/zero tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/full tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/urandom tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/random tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
tmpfs /dev/tty tmpfs rw,nosuid,relatime,size=512k,mode=755 0 0
devpts /dev/console devpts rw,nosuid,noexec,relatime,mode=600,ptmxmode=000 0 0
devpts /dev/pts devpts rw,relatime,gid=100005,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/ptmx devpts rw,relatime,gid=100005,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty1 devpts rw,relatime,gid=100005,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty2 devpts rw,relatime,gid=100005,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty3 devpts rw,relatime,gid=100005,mode=620,ptmxmode=666,max=1024 0 0
devpts /dev/tty4 devpts rw,relatime,gid=100005,mode=620,ptmxmode=666,max=1024 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev,uid=100000,gid=100000 0 0
tmpfs /run tmpfs rw,nosuid,nodev,mode=755,uid=100000,gid=100000 0 0
tmpfs /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755,uid=100000,gid=100000 0 0
From container:
root@ubuntu:~# ls -lha /dev/
total 4.0K
drwxr-xr-x  5 root   root       420 Jul 19 19:15 .
drwxr-xr-x 21 root   root      4.0K Jul 19 17:28 ..
c--x--x--x  1 root   root    136, 1 Jul 19 19:15 console
lrwxrwxrwx  1 root   root        13 Jul 19 19:15 fd -> /proc/self/fd
crw-rw-rw-  1 nobody nogroup   1, 7 Jul 19 16:37 full
drwxrwxrwt  2 nobody nogroup     40 Jul 19 19:15 mqueue
crw-rw-rw-  1 nobody nogroup   1, 3 Jul 19 16:37 null
crw-rw-rw-  1 root   root      5, 2 Jul 19 19:15 ptmx
drwxr-xr-x  2 root   root         0 Jul 19 19:15 pts
crw-rw-rw-  1 nobody nogroup   1, 8 Jul 19 16:37 random
drwxrwxrwt  2 root   root        40 Jul 19 19:15 shm
lrwxrwxrwx  1 root   root        15 Jul 19 19:15 stderr -> /proc/self/fd/2
lrwxrwxrwx  1 root   root        15 Jul 19 19:15 stdin -> /proc/self/fd/0
lrwxrwxrwx  1 root   root        15 Jul 19 19:15 stdout -> /proc/self/fd/1
crw-rw-rw-  1 nobody nogroup   5, 0 Jul 19 19:16 tty
crw--w----  1 root   tty     136, 0 Jul 19 19:15 tty1
crw--w----  1 root   tty     136, 1 Jul 19 19:15 tty2
crw--w----  1 root   tty     136, 2 Jul 19 19:15 tty3
crw--w----  1 root   tty     136, 3 Jul 19 19:15 tty4
crw-rw-rw-  1 nobody nogroup   1, 9 Jul 19 16:37 urandom
crw-rw-rw-  1 nobody nogroup   1, 5 Jul 19 16:37 zero
Can be this related to https://github.com/fgrehm/vagrant-lxc/issues/339#issuecomment-108150622 ?
There’s a bunch of stuff that could cause this:
  • the filesystem where the container is supposed to be unpacked is mount with nodev
  • the environment you’re running this in somehow doesn’t allow for creating device nodes (the circle-ci example illustrates this)
    In any case it doesn’t look like the errors you’re seeing are fatal. Are you able to run the container afterwards?
I can create device nodes on host OS:
root@OpenWrt:~# mknod -m 666 /tmp/tty c 4 0 && ls -lha /tmp/tty
crw-rw-rw-    1 root     root        4,   0 Jul 22 11:18 /tmp/tty
Also / , where is saved lxc.lxcpath is mounted without nodev
root@OpenWrt:~# mount
/dev/root on / type ext4 (rw,noatime,block_validity,delalloc,barrier,user_xattr)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,cpu,cpuacct,blkio,memory,devices,freezer,net_cls,pids,clone_children)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
/dev/sda1 on /boot type ext4 (ro,noatime,block_validity,delalloc,barrier,user_xattr)
tmpfs on /dev type tmpfs (rw,nosuid,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
root@OpenWrt:~# cat /etc/lxc/lxc.conf
lxc.lxcpath = /srv/lxc
Yes I can run container with this error, but I want to know, where is a probelm.
Any other ideas?
Thanks
If you’re creating unprivileged containers you won’t be able to mknod() prior to 4.18 kernels. Could be that the template is not correctly being informed that it is run in a user namespace. You can try and see whether you see the same issue with one of the 3.*.* releases.
I am using 4.14.54 kernel. So thats my case.
LXC 3.x.x is not available yet in openwrt. Just 2.1.1
So should I ignore this message unitl 3.x.x or kernel >= 4.18 ?
Or possible workaround (to hide error messages) should be add
–exclude=./rootfs/dev --exclude=./rootfs/var/spool/postfix/dev to tar parameters in lxc-download template ,right?
You can ignore them for now, yes.
Hi Christian,
Sorry for re-opening this old thread. I have a similar problem, but I cannot even create a container. Same setting (LXC 2.1.1 on OpenWrt). My kernel is Linux OpenWrt 4.19.62
Privileged containers work but I get the following error for unprivileged containers:
lxc-create -n template -t download -- --dist devuan --release ascii --arch amd64
Using image from local cache
tar: ./dev/ptmx: Cannot mknod: Operation not permitted
tar: ./dev/tty: Cannot mknod: Operation not permitted
tar: ./dev/urandom: Cannot mknod: Operation not permitted
tar: ./dev/random: Cannot mknod: Operation not permitted
tar: ./dev/full: Cannot mknod: Operation not permitted
tar: ./dev/zero: Cannot mknod: Operation not permitted
tar: ./dev/null: Cannot mknod: Operation not permitted
tar: Exiting with failure status due to previous errors
lxc-create: template: lxccontainer.c: create_run_template: 1473 container creation template for template failed
lxc-create: template: tools/lxc_create.c: main: 329 Error creating container template
Any idea what I can do/investigate?
That would likely be a bug with the devuan image. The rootfs tarballs/squashfs should never have files inside the /dev directory, this is causing this issue.
@monstermunchkin can you fix this? We’d want to confirm that all our production distrobuilder yaml files properly wipe /dev to avoid this kind of problem.
Hi Stéphane,
Thank you for your quick reply! Unfortunately I get the same error with Debian containers:
lxc-create -n template -t download -- --dist debian --release buster --arch amd64
Centos on the other hand does not have the same problem:
lxc-create -n template -t download -- --dist centos --release 7 --arch amd64
You just created a Centos 7 x86_64 (20190802_07:08) container.
Is there anything I can do myself to fix the debian/devuan container? Is there any way I can be of any help in fixing the image on the server?
Thank you,
alex
Here’s the PR that makes sure that images have a clean /dev.
