Once successfully booted on the new image, can you run incus admin os system security tpm-rebind? That will reboot the system and hopefully no longer prompt for the recovery key.
@gibmat looks like the new systemd has changed how systemd-stub measures things in a non-secureboot environment… Kinda annoying as it means it’s not something that we can fix in a new image…
Anyone currently running with SecureBoot disabled will need to enter the recovery key and do a TPM rebind. Thankfully the no-SecureBoot but physical TPM is by far the least common setup, but it’s still pretty annoying when we don’t have a way to prevent it…
I’m preparing a change to incus-osd to harden against future similar changes by systemd.
Yeah, you will most likely have to do this one more time as we’ve noticed an issue with PCR12 calculation when run on systems without Secure Boot. We now have a test system with that configuration so were able to confirm the behavior when preparing yesterday’s update and have sent a follow up tweak to the logic which should eliminate this problem with the next IncusOS update.
