Thanks for the ideas, firstly btrfs subvolumes:
$ btrfs subvol list /btrfs/
ID 264 gen 1667 top level 5 path lxc
ID 265 gen 1667 top level 264 path lxc/containers
ID 266 gen 1668 top level 264 path lxc/containers-snapshots
ID 267 gen 1667 top level 264 path lxc/images
ID 268 gen 1668 top level 264 path lxc/custom
ID 269 gen 1668 top level 264 path lxc/custom-snapshots
ID 272 gen 245 top level 267 path lxc/images/979ff60086ca9fb1c93d3131f8eca291820a524f0bd0b7d621a3c2f5f41ef185
ID 274 gen 1661 top level 5 path libvirt-images
ID 275 gen 1669 top level 265 path lxc/containers/helping-puma
ID 276 gen 1669 top level 265 path lxc/containers/choice-lioness
Also, I don’t have fstab entry for lxc subvolume, previously it worked fine without.
Now, after setting daemon.debug=true
and reloading snap.lxd.daemon
, the output of lxc info
config: {}
api_extensions:
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
environment:
addresses: []
architectures:
- x86_64
- i686
certificate: |
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
certificate_fingerprint: [...]
driver: lxc
driver_version: 3.2.1
kernel: Linux
kernel_architecture: x86_64
kernel_features:
netnsid_getifaddrs: "false"
seccomp_listener: "false"
seccomp_listener_continue: "false"
shiftfs: "false"
uevent_injection: "true"
unpriv_fscaps: "true"
kernel_version: 4.19.0-6-amd64
lxc_features:
cgroup2: "false"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
seccomp_notify: "true"
project: default
server: lxd
server_clustered: false
server_name: plaes-blade
server_pid: 16075
server_version: "3.19"
storage: btrfs
storage_version: "4.4"
Output of cat /proc/$(cat /var/snap/lxd/common/lxd.pid)/mountinfo
222 312 8:1 / /var/lib/snapd/hostfs rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
228 222 0:21 / /var/lib/snapd/hostfs/run rw,nosuid,noexec,relatime master:5 - tmpfs tmpfs rw,size=19807580k,mode=755
229 228 0:23 / /var/lib/snapd/hostfs/run/lock rw,nosuid,nodev,noexec,relatime master:6 - tmpfs tmpfs rw,size=5120k
230 228 0:21 /snapd/ns /var/lib/snapd/hostfs/run/snapd/ns rw,nosuid,noexec,relatime - tmpfs tmpfs rw,size=19807580k,mode=755
251 222 0:41 /home /var/lib/snapd/hostfs/home rw,relatime master:57 - btrfs /dev/sda3 rw,space_cache,subvolid=257,subvol=/home
252 222 0:41 / /var/lib/snapd/hostfs/btrfs rw,relatime master:59 - btrfs /dev/sda3 rw,space_cache,subvolid=5,subvol=/
253 222 8:5 / /var/lib/snapd/hostfs/var rw,relatime master:61 - ext4 /dev/sda5 rw
254 253 0:41 /libvirt-images /var/lib/snapd/hostfs/var/lib/libvirt/images rw,relatime master:65 - btrfs /dev/sda3 rw,space_cache,subvolid=274,subvol=/libvirt-images
255 222 8:6 / /var/lib/snapd/hostfs/tmp rw,relatime master:63 - ext4 /dev/sda6 rw
257 222 7:0 / /var/lib/snapd/hostfs/snap/core/8268 ro,nodev,relatime master:69 - squashfs /dev/loop0 ro
264 221 7:0 / / ro,nodev,relatime master:69 - squashfs /dev/loop0 ro
265 264 0:6 / /dev rw,nosuid,relatime master:2 - devtmpfs udev rw,size=99021028k,nr_inodes=24755257,mode=755
266 265 0:20 / /dev/pts rw,nosuid,noexec,relatime master:3 - devpts devpts rw,gid=5,mode=620,ptmxmode=000
267 265 0:22 / /dev/shm rw,nosuid,nodev master:4 - tmpfs tmpfs rw
268 265 0:40 / /dev/hugepages rw,relatime master:26 - hugetlbfs hugetlbfs rw,pagesize=2M
269 265 0:18 / /dev/mqueue rw,relatime master:27 - mqueue mqueue rw
271 264 0:41 /home /home rw,relatime master:57 - btrfs /dev/sda3 rw,space_cache,subvolid=257,subvol=/home
272 264 8:1 /root /root rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
273 264 0:4 / /proc rw,nosuid,nodev,noexec,relatime master:14 - proc proc rw
274 273 0:39 / /proc/sys/fs/binfmt_misc rw,relatime master:25 - autofs systemd-1 rw,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15976
275 264 0:19 / /sys rw,nosuid,nodev,noexec,relatime master:7 - sysfs sysfs rw
276 275 0:7 / /sys/kernel/security rw,nosuid,nodev,noexec,relatime master:8 - securityfs securityfs rw
277 275 0:24 / /sys/fs/cgroup ro,nosuid,nodev,noexec master:9 - tmpfs tmpfs ro,mode=755
278 277 0:25 / /sys/fs/cgroup/unified rw,nosuid,nodev,noexec,relatime master:10 - cgroup2 cgroup2 rw
279 277 0:26 / /sys/fs/cgroup/systemd rw,nosuid,nodev,noexec,relatime master:11 - cgroup cgroup rw,xattr,name=systemd
280 277 0:29 / /sys/fs/cgroup/cpu,cpuacct rw,nosuid,nodev,noexec,relatime master:15 - cgroup cgroup rw,cpu,cpuacct
281 277 0:30 / /sys/fs/cgroup/net_cls,net_prio rw,nosuid,nodev,noexec,relatime master:16 - cgroup cgroup rw,net_cls,net_prio
282 277 0:31 / /sys/fs/cgroup/freezer rw,nosuid,nodev,noexec,relatime master:17 - cgroup cgroup rw,freezer
283 277 0:32 / /sys/fs/cgroup/blkio rw,nosuid,nodev,noexec,relatime master:18 - cgroup cgroup rw,blkio
284 277 0:33 / /sys/fs/cgroup/cpuset rw,nosuid,nodev,noexec,relatime master:19 - cgroup cgroup rw,cpuset,clone_children
285 277 0:34 / /sys/fs/cgroup/pids rw,nosuid,nodev,noexec,relatime master:20 - cgroup cgroup rw,pids
286 277 0:35 / /sys/fs/cgroup/devices rw,nosuid,nodev,noexec,relatime master:21 - cgroup cgroup rw,devices
287 277 0:36 / /sys/fs/cgroup/perf_event rw,nosuid,nodev,noexec,relatime master:22 - cgroup cgroup rw,perf_event
288 277 0:37 / /sys/fs/cgroup/rdma rw,nosuid,nodev,noexec,relatime master:23 - cgroup cgroup rw,rdma
289 277 0:38 / /sys/fs/cgroup/memory rw,nosuid,nodev,noexec,relatime master:24 - cgroup cgroup rw,memory
290 275 0:27 / /sys/fs/pstore rw,nosuid,nodev,noexec,relatime master:12 - pstore pstore rw
291 275 0:28 / /sys/fs/bpf rw,nosuid,nodev,noexec,relatime master:13 - bpf bpf rw,mode=700
292 275 0:8 / /sys/kernel/debug rw,relatime master:28 - debugfs debugfs rw
293 264 8:6 / /tmp rw,relatime master:63 - ext4 /dev/sda6 rw
294 264 8:5 /snap /var/snap rw,relatime master:61 - ext4 /dev/sda5 rw
295 264 8:5 /lib/snapd /var/lib/snapd rw,relatime master:61 - ext4 /dev/sda5 rw
296 264 8:5 /tmp /var/tmp rw,relatime master:61 - ext4 /dev/sda5 rw
300 264 8:1 /usr/lib/modules /lib/modules rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
301 264 8:1 /usr/lib/firmware /lib/firmware rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
302 264 8:1 /usr/src /usr/src rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
303 264 8:5 /log /var/log rw,relatime master:61 - ext4 /dev/sda5 rw
304 264 8:1 /media /media rw,relatime shared:1 - ext4 /dev/sda1 rw,errors=remount-ro
306 264 8:1 /mnt /mnt rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
309 264 8:1 /snap /snap rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
311 309 7:0 / /snap/core/8268 ro,nodev,relatime master:69 - squashfs /dev/loop0 ro
312 295 8:5 /lib/snapd/hostfs /var/lib/snapd/hostfs rw,relatime - ext4 /dev/sda5 rw
223 293 8:6 /snap.lxd/tmp /tmp rw,relatime - ext4 /dev/sda6 rw
224 266 0:48 / /dev/pts rw,relatime - devpts devpts rw,gid=5,mode=620,ptmxmode=666
225 265 0:48 /ptmx /dev/ptmx rw,relatime - devpts devpts rw,gid=5,mode=620,ptmxmode=666
226 294 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
227 294 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
344 294 0:49 / /var/snap/lxd/common/shmounts rw,relatime shared:130 - tmpfs tmpfs rw,size=1024k,mode=711
326 264 7:1 /wrappers/kmod /bin/kmod ro,nodev,relatime - squashfs /dev/loop1 ro
298 264 8:1 /usr/share/ca-certificates /usr/share/ca-certificates rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
299 222 0:6 / /var/lib/snapd/hostfs/dev rw,nosuid,relatime master:2 - devtmpfs udev rw,size=99021028k,nr_inodes=24755257,mode=755
305 222 0:4 / /var/lib/snapd/hostfs/proc rw,nosuid,nodev,noexec,relatime master:14 - proc proc rw
307 222 0:19 / /var/lib/snapd/hostfs/sys rw,nosuid,nodev,noexec,relatime master:7 - sysfs sysfs rw
343 307 0:55 / /var/lib/snapd/hostfs/sys/fs/fuse/connections rw,relatime master:129 - fusectl fusectl rw
332 275 0:55 / /sys/fs/fuse/connections rw,relatime master:129 - fusectl fusectl rw
352 226 0:41 /lxc /var/snap/lxd/common/lxd/storage-pools/default rw,relatime shared:137 master:59 - btrfs /dev/sda3 rw,space_cache,subvolid=264,subvol=/lxc
454 274 0:65 / /proc/sys/fs/binfmt_misc rw,relatime master:138 - binfmt_misc binfmt_misc rw
440 228 0:71 / /var/lib/snapd/hostfs/run/user/1000 rw,nosuid,nodev,relatime master:142 - tmpfs tmpfs rw,size=19807576k,mode=700,uid=1000,gid=1000
1101 260 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
1102 324 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
1103 326 7:2 /wrappers/kmod /bin/kmod ro,nodev,relatime - squashfs /dev/loop2 ro
416 309 7:3 / /snap/lxd/13085 ro,nodev,relatime master:314 - squashfs /dev/loop3 ro
409 222 7:3 / /var/lib/snapd/hostfs/snap/lxd/13085 ro,nodev,relatime master:314 - squashfs /dev/loop3 ro
417 262 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
418 261 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
419 327 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
420 325 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
421 1103 7:3 /wrappers/kmod /bin/kmod ro,nodev,relatime master:314 - squashfs /dev/loop3 ro
767 309 7:4 / /snap/lxd/13098 ro,nodev,relatime master:67 - squashfs /dev/loop4 ro
124 222 7:4 / /var/lib/snapd/hostfs/snap/lxd/13098 ro,nodev,relatime master:67 - squashfs /dev/loop4 ro
1104 310 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
1107 297 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
1106 270 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
1105 263 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
1108 333 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
1111 331 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
1110 329 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
1109 328 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
1112 421 7:4 /wrappers/kmod /bin/kmod ro,nodev,relatime master:67 - squashfs /dev/loop4 ro
123 320 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
237 319 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
236 318 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
235 317 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
234 316 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
233 315 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
232 314 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
231 313 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
238 341 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
245 340 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
244 339 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
243 338 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
242 337 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
241 336 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
240 335 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
239 334 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
246 1112 7:4 /wrappers/kmod /bin/kmod ro,nodev,relatime master:67 - squashfs /dev/loop4 ro
258 344 0:53 / /var/snap/lxd/common/shmounts/lxcfs rw,nosuid,nodev,relatime shared:128 - fuse.lxcfs lxcfs rw,user_id=0,group_id=0,allow_other
259 123 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
320 1104 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
319 417 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
318 1101 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
317 226 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
316 418 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
315 1107 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
314 1106 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
313 1105 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
310 237 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
297 236 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
270 235 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
263 234 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
262 233 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
261 232 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
260 231 8:5 /snap/lxd/common/lxd/storage-pools /var/snap/lxd/common/lxd/storage-pools rw,relatime shared:126 - ext4 /dev/sda5 rw
321 238 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
341 1108 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
340 419 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
339 1102 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
338 227 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
337 420 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
336 1111 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
335 1110 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
334 1109 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
333 245 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
331 244 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
329 243 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
328 242 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
327 241 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
325 240 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
324 239 8:5 /snap/lxd/common/lxd/devices /var/snap/lxd/common/lxd/devices rw,relatime shared:127 master:61 - ext4 /dev/sda5 rw
342 246 7:4 /wrappers/kmod /bin/kmod ro,nodev,relatime master:67 - squashfs /dev/loop4 ro
247 264 8:1 /boot /boot rw,relatime master:1 - ext4 /dev/sda1 rw,errors=remount-ro
248 264 0:54 / /run rw,nosuid,nodev,relatime - tmpfs tmpfs rw,mode=755
249 264 0:51 / /etc rw,relatime - tmpfs tmpfs rw,mode=755
349 344 0:56 / /var/snap/lxd/common/shmounts/containers rw,relatime shared:131 - tmpfs tmpfs rw,size=100k,mode=711
350 294 0:63 / /var/snap/lxd/common/lxd/devlxd rw,relatime - tmpfs tmpfs rw,size=100k,mode=755
$ lxc launch ubuntu:18.04
Creating the instance
Error: Failed instance creation: Create instance from image: Failed to run: btrfs subvolume create /var/snap/lxd/common/lxd/storage-pools/default/images/6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794: ERROR: not a btrfs filesystem: /var/snap/lxd/common/lxd/storage-pools/default/images
$ cat /var/snap/lxd/common/lxd/logs/lxd.log
t=2020-01-25T08:44:05+0200 lvl=info msg="LXD 3.19 is starting in normal mode" path=/var/snap/lxd/common/lxd
t=2020-01-25T08:44:05+0200 lvl=info msg="Kernel uid/gid map:"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - u 0 0 4294967295"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - g 0 0 4294967295"
t=2020-01-25T08:44:05+0200 lvl=info msg="Configured LXD uid/gid map:"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - u 0 1000000 1000000000"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - g 0 1000000 1000000000"
t=2020-01-25T08:44:05+0200 lvl=info msg="Kernel features:"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - netnsid-based network retrieval: no"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - uevent injection: yes"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - seccomp listener: no"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - seccomp listener continue syscalls: no"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - unprivileged file capabilities: yes"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - cgroup layout: hybrid"
t=2020-01-25T08:44:05+0200 lvl=warn msg=" - Couldn't find the CGroup memory swap accounting, swap limits will be ignored"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - shiftfs support: disabled"
t=2020-01-25T08:44:05+0200 lvl=info msg="Initializing local database"
t=2020-01-25T08:44:05+0200 lvl=dbug msg="Initializing database gateway"
t=2020-01-25T08:44:05+0200 lvl=dbug msg="Start database node" address= id=1
t=2020-01-25T08:44:05+0200 lvl=info msg="Starting /dev/lxd handler:"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - binding devlxd socket" socket=/var/snap/lxd/common/lxd/devlxd/sock
t=2020-01-25T08:44:05+0200 lvl=info msg="REST API daemon:"
t=2020-01-25T08:44:05+0200 lvl=info msg=" - binding Unix socket" inherited=true socket=/var/snap/lxd/common/lxd/unix.socket
t=2020-01-25T08:44:05+0200 lvl=info msg="Initializing global database"
t=2020-01-25T08:44:05+0200 lvl=dbug msg="Dqlite: connected address=1 id=1 attempt=0"
t=2020-01-25T08:44:05+0200 lvl=info msg="Initializing storage pools"
t=2020-01-25T08:44:05+0200 lvl=dbug msg="Initializing and checking storage pool \"default\""
t=2020-01-25T08:44:05+0200 lvl=dbug msg="Mount started" driver=btrfs pool=default
t=2020-01-25T08:44:05+0200 lvl=dbug msg="Mount finished" driver=btrfs pool=default
t=2020-01-25T08:44:05+0200 lvl=info msg="Initializing networks"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="New task Operation: 8fa04da1-8514-48af-849a-41180d37ba1c"
t=2020-01-25T08:44:06+0200 lvl=info msg="Pruning leftover image files"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Started task operation: 8fa04da1-8514-48af-849a-41180d37ba1c"
t=2020-01-25T08:44:06+0200 lvl=info msg="Done pruning leftover image files"
t=2020-01-25T08:44:06+0200 lvl=info msg="Loading daemon configuration"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Success for task operation: 8fa04da1-8514-48af-849a-41180d37ba1c"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Initialized inotify with file descriptor 3"
t=2020-01-25T08:44:06+0200 lvl=dbug msg=Handling ip=@ method=GET url=/1.0 user=
t=2020-01-25T08:44:06+0200 lvl=dbug msg="New task Operation: e2bf4dbe-7fc0-4508-8c8b-f2afc81c4d78"
t=2020-01-25T08:44:06+0200 lvl=info msg="Pruning expired images"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Started task operation: e2bf4dbe-7fc0-4508-8c8b-f2afc81c4d78"
t=2020-01-25T08:44:06+0200 lvl=info msg="Done pruning expired images"
t=2020-01-25T08:44:06+0200 lvl=dbug msg=Handling ip=@ method=GET url=/internal/ready user=
t=2020-01-25T08:44:06+0200 lvl=dbug msg="New task Operation: 9d125b35-73f2-48d3-8de2-b86926911082"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Success for task operation: e2bf4dbe-7fc0-4508-8c8b-f2afc81c4d78"
t=2020-01-25T08:44:06+0200 lvl=info msg="Pruning expired container backups"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Started task operation: 9d125b35-73f2-48d3-8de2-b86926911082"
t=2020-01-25T08:44:06+0200 lvl=info msg="Done pruning expired container backups"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Success for task operation: 9d125b35-73f2-48d3-8de2-b86926911082"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="New task Operation: 1d8cad75-e5c5-406c-8fb9-dd7b75a2b985"
t=2020-01-25T08:44:06+0200 lvl=info msg="Updating instance types"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Started task operation: 1d8cad75-e5c5-406c-8fb9-dd7b75a2b985"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="New task Operation: ca44dead-ff1a-4bb6-b497-07829637d110"
t=2020-01-25T08:44:06+0200 lvl=info msg="Updating images"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Started task operation: ca44dead-ff1a-4bb6-b497-07829637d110"
t=2020-01-25T08:44:06+0200 lvl=info msg="Done updating images"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="New task Operation: 9db24161-8481-4423-9236-b51b9b57212d"
t=2020-01-25T08:44:06+0200 lvl=info msg="Expiring log files"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Started task operation: 9db24161-8481-4423-9236-b51b9b57212d"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Success for task operation: 9db24161-8481-4423-9236-b51b9b57212d"
t=2020-01-25T08:44:06+0200 lvl=info msg="Done expiring log files"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Scheduler: network: veth7ef67aba has been added: updating network priorities"
t=2020-01-25T08:44:06+0200 lvl=info msg="Done updating instance types"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Scheduler: network: vethf92f3cf7 has been added: updating network priorities"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Processing image" alias=19.04 fp=371697337f961b5763f0f1df4710aeceed6b2a41b8b9ca0adf2262d829b4ae09 protocol=simplestreams server=https://cloud-images.ubuntu.com/releases
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Connecting to a remote simplestreams server"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="MountInstance started" driver=btrfs instance=choice-lioness pool=default project=default
t=2020-01-25T08:44:06+0200 lvl=dbug msg="MountInstance finished" driver=btrfs instance=choice-lioness pool=default project=default
t=2020-01-25T08:44:06+0200 lvl=eror msg="Failed to start container 'choice-lioness': Common start logic: saving config file for the container failed"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Scheduler: network: vethe67b9b62 has been added: updating network priorities"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="Scheduler: network: veth65abf814 has been added: updating network priorities"
t=2020-01-25T08:44:06+0200 lvl=dbug msg="MountInstance started" driver=btrfs instance=helping-puma pool=default project=default
t=2020-01-25T08:44:06+0200 lvl=dbug msg="MountInstance finished" driver=btrfs instance=helping-puma pool=default project=default
t=2020-01-25T08:44:06+0200 lvl=eror msg="Failed to start container 'helping-puma': Common start logic: saving config file for the container failed"
t=2020-01-25T08:44:07+0200 lvl=dbug msg=Handling ip=@ method=GET url=/1.0 user=
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Image already exists in the db" image=371697337f961b5763f0f1df4710aeceed6b2a41b8b9ca0adf2262d829b4ae09
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Already up to date" fp=371697337f961b5763f0f1df4710aeceed6b2a41b8b9ca0adf2262d829b4ae09
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Processing image" alias=18.04 fp=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794 protocol=simplestreams server=https://cloud-images.ubuntu.com/releases
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Connecting to a remote simplestreams server"
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Success for task operation: 1d8cad75-e5c5-406c-8fb9-dd7b75a2b985"
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Image already exists in the db" image=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Already up to date" fp=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794
t=2020-01-25T08:44:08+0200 lvl=dbug msg="Processing image" alias=18.04 fp=979ff60086ca9fb1c93d3131f8eca291820a524f0bd0b7d621a3c2f5f41ef185 protocol=simplestreams server=https://cloud-images.ubuntu.com/releases
t=2020-01-25T08:44:09+0200 lvl=dbug msg="Image already exists in the db" image=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794
t=2020-01-25T08:44:09+0200 lvl=dbug msg="Success for task operation: ca44dead-ff1a-4bb6-b497-07829637d110"
t=2020-01-25T08:50:42+0200 lvl=dbug msg=Handling ip=@ method=GET url=/1.0 user=
t=2020-01-25T08:50:42+0200 lvl=dbug msg=Handling ip=@ method=GET url=/1.0/events user=
t=2020-01-25T08:50:42+0200 lvl=dbug msg="New event listener: b42d2275-6903-41d3-a8e0-915b6bce53f3"
t=2020-01-25T08:50:42+0200 lvl=dbug msg=Handling ip=@ method=POST url=/1.0/instances user=
t=2020-01-25T08:50:42+0200 lvl=dbug msg="\n\t{\n\t\t\"architecture\": \"\",\n\t\t\"config\": {},\n\t\t\"devices\": {},\n\t\t\"ephemeral\": false,\n\t\t\"profiles\": null,\n\t\t\"stateful\": false,\n\t\t\"description\": \"\",\n\t
\t\"name\": \"\",\n\t\t\"source\": {\n\t\t\t\"type\": \"image\",\n\t\t\t\"certificate\": \"\",\n\t\t\t\"alias\": \"18.04\",\n\t\t\t\"server\": \"https://cloud-images.ubuntu.com/releases\",\n\t\t\t\"protocol\": \"simplestreams\",
\n\t\t\t\"mode\": \"pull\"\n\t\t},\n\t\t\"instance_type\": \"\",\n\t\t\"type\": \"container\"\n\t}"
t=2020-01-25T08:50:42+0200 lvl=dbug msg="Responding to container create"
t=2020-01-25T08:50:42+0200 lvl=dbug msg="Connecting to a remote simplestreams server"
t=2020-01-25T08:50:42+0200 lvl=dbug msg="No name provided, creating stable-collie"
t=2020-01-25T08:50:42+0200 lvl=dbug msg="New task Operation: 8f1c8df6-f960-45d7-887b-d73dc67686bf"
t=2020-01-25T08:50:42+0200 lvl=dbug msg="Started task operation: 8f1c8df6-f960-45d7-887b-d73dc67686bf"
t=2020-01-25T08:50:42+0200 lvl=dbug msg="\n\t{\n\t\t\"type\": \"async\",\n\t\t\"status\": \"Operation created\",\n\t\t\"status_code\": 100,\n\t\t\"operation\": \"/1.0/operations/8f1c8df6-f960-45d7-887b-d73dc67686bf\",\n\t\t\"err
or_code\": 0,\n\t\t\"error\": \"\",\n\t\t\"metadata\": {\n\t\t\t\"id\": \"8f1c8df6-f960-45d7-887b-d73dc67686bf\",\n\t\t\t\"class\": \"task\",\n\t\t\t\"description\": \"Creating container\",\n\t\t\t\"created_at\": \"2020-01-25T08
:50:42.803309631+02:00\",\n\t\t\t\"updated_at\": \"2020-01-25T08:50:42.803309631+02:00\",\n\t\t\t\"status\": \"Running\",\n\t\t\t\"status_code\": 103,\n\t\t\t\"resources\": {\n\t\t\t\t\"containers\": [\n\t\t\t\t\t\"/1.0/containe
rs/stable-collie\"\n\t\t\t\t],\n\t\t\t\t\"instances\": [\n\t\t\t\t\t\"/1.0/instances/stable-collie\"\n\t\t\t\t]\n\t\t\t},\n\t\t\t\"metadata\": null,\n\t\t\t\"may_cancel\": false,\n\t\t\t\"err\": \"\",\n\t\t\t\"location\": \"none
\"\n\t\t}\n\t}"
t=2020-01-25T08:50:42+0200 lvl=dbug msg=Handling ip=@ method=GET url=/1.0/operations/8f1c8df6-f960-45d7-887b-d73dc67686bf user=
t=2020-01-25T08:50:43+0200 lvl=dbug msg="Image already exists in the db" image=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794
t=2020-01-25T08:50:43+0200 lvl=info msg="Creating container" ephemeral=false name=stable-collie project=default
t=2020-01-25T08:50:43+0200 lvl=info msg="Created container" ephemeral=false name=stable-collie project=default
t=2020-01-25T08:50:43+0200 lvl=dbug msg="CreateInstanceFromImage started" driver=btrfs instance=stable-collie pool=default project=default
t=2020-01-25T08:50:43+0200 lvl=dbug msg="EnsureImage started" driver=btrfs fingerprint=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794 pool=default
t=2020-01-25T08:50:43+0200 lvl=dbug msg="EnsureImage finished" driver=btrfs fingerprint=6b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794 pool=default
t=2020-01-25T08:50:43+0200 lvl=dbug msg="DeleteInstance started" driver=btrfs instance=stable-collie pool=default project=default
t=2020-01-25T08:50:43+0200 lvl=dbug msg="Deleting instance volume" driver=btrfs instance=stable-collie pool=default project=default volName=stable-collie
t=2020-01-25T08:50:43+0200 lvl=dbug msg="DeleteInstance finished" driver=btrfs instance=stable-collie pool=default project=default
t=2020-01-25T08:50:43+0200 lvl=dbug msg="CreateInstanceFromImage finished" driver=btrfs instance=stable-collie pool=default project=default
t=2020-01-25T08:50:43+0200 lvl=info msg="Deleting container" created=2020-01-25T08:50:43+0200 ephemeral=false name=stable-collie project=default used=1970-01-01T03:00:00+0300
t=2020-01-25T08:50:43+0200 lvl=dbug msg="Database error: &errors.errorString{s:\"No such object\"}"
t=2020-01-25T08:50:43+0200 lvl=info msg="Deleted container" created=2020-01-25T08:50:43+0200 ephemeral=false name=stable-collie project=default used=1970-01-01T03:00:00+0300
t=2020-01-25T08:50:43+0200 lvl=dbug msg="Failure for task operation: 8f1c8df6-f960-45d7-887b-d73dc67686bf: Create instance from image: Failed to run: btrfs subvolume create /var/snap/lxd/common/lxd/storage-pools/default/images/6
b11d9656e44792ead7f6571fb69b8425a87a3e7ad5a222028e5c9daf97ed794: ERROR: not a btrfs filesystem: /var/snap/lxd/common/lxd/storage-pools/default/images"
t=2020-01-25T08:50:43+0200 lvl=dbug msg="Event listener finished: b42d2275-6903-41d3-a8e0-915b6bce53f3"
t=2020-01-25T08:50:43+0200 lvl=dbug msg="Disconnected event listener: b42d2275-6903-41d3-a8e0-915b6bce53f3"
