sqllyw
1
here is what in the snap:
core18 20220831 2566 latest/stable canonical✓ base
core20 20220919 1634 latest/stable canonical✓ base
lxd 4.0.9-8e2046b 22753 4.0/stable/… canonical✓ -
snapd 2.57.4 17336 latest/stable canonical✓ snapd
doing a snap refresh lxd, got:
sudo snap refresh lxd
snap “lxd” has no updates available
what I’m missing here? thanks.
stgraber
(Stéphane Graber)
2
You’re on 4.0/stable
so are getting the latest 4.0 snap.
snap refresh lxd --channel=5.0/stable
would move you to 5.0.x
, snap refresh lxd --channel=latest/stable
would move you to 5.x
(5.7 currently)
sqllyw
3
right, i ended up remove 4.0.9 and install the 5.7, is this the correct approach?
stgraber
(Stéphane Graber)
4
Not if you have any instance you care about as removal would delete everything.
The refresh commands above would have been the correct way to move to a newer release without losing anything.
