Hi!
Long story short: updated to snap version of lxd, mounted zfs pool with containers, had to use lxd-recover, managed to negotiate all that, and imported all the containers. However, two of them refuse to start now.
I’m stumped as to why the rest of them are going but these two are not.
Here’s my snap info lxd:
jack@kdsapp0:~$ snap info lxd
summary: LXD - container and VM manager
publisher: Canonical✓
store-url: https://snapcraft.io/lxd
contact: https://github.com/lxc/lxd/issues
license: unset
description: |
LXD is a system container and virtual machine manager.
It offers a simple CLI and REST API to manage local or remote instances,
uses an image based workflow and support for a variety of advanced features.
Images are available for all Ubuntu releases and architectures as well
as for a wide number of other Linux distributions. Existing
integrations with many deployment and operation tools, makes it work
just like a public cloud, except everything is under your control.
LXD containers are lightweight, secure by default and a great
alternative to virtual machines when running Linux on Linux.
LXD virtual machines are modern and secure, using UEFI and secure-boot
by default and a great choice when a different kernel or operating
system is needed.
With clustering, up to 50 LXD servers can be easily joined and managed
together with the same tools and APIs and without needing any external
dependencies.
Supported configuration options for the snap (snap set lxd [<key>=<value>...]):
- ceph.builtin: Use snap-specific Ceph configuration [default=false]
- ceph.external: Use the system's ceph tools (ignores ceph.builtin) [default=false]
- criu.enable: Enable experimental live-migration support [default=false]
- daemon.debug: Increase logging to debug level [default=false]
- daemon.group: Set group of users that have full control over LXD [default=lxd]
- daemon.user.group: Set group of users that have restricted LXD access [default=lxd]
- daemon.preseed: Pass a YAML configuration to `lxd init` on initial start
- daemon.syslog: Send LXD log events to syslog [default=false]
- daemon.verbose: Increase logging to verbose level [default=false]
- lvm.external: Use the system's LVM tools [default=false]
- lxcfs.pidfd: Start per-container process tracking [default=false]
- lxcfs.loadavg: Start tracking per-container load average [default=false]
- lxcfs.cfs: Consider CPU shares for CPU usage [default=false]
- openvswitch.builtin: Run a snap-specific OVS daemon [default=false]
- openvswitch.external: Use the system's OVS tools (ignores openvswitch.builtin) [default=false]
- ovn.builtin: Use snap-specific OVN configuration [default=false]
- shiftfs.enable: Enable shiftfs support [default=auto]
For system-wide configuration of the CLI, place your configuration in
/var/snap/lxd/common/global-conf/ (config.yml and servercerts)
commands:
- lxd.benchmark
- lxd.buginfo
- lxd.check-kernel
- lxd.lxc
- lxd.lxc-to-lxd
- lxd
- lxd.migrate
services:
lxd.activate: oneshot, enabled, inactive
lxd.daemon: simple, enabled, active
lxd.user-daemon: simple, enabled, inactive
snap-id: J60k4JY0HppjwOjW8dZdYc8obXKxujRu
tracking: latest/stable
refresh-date: yesterday at 12:30 EDT
channels:
latest/stable: 5.6-794016a 2022-09-27 (23680) 142MB -
latest/candidate: 5.6-794016a 2022-09-23 (23680) 142MB -
latest/beta: ↑
latest/edge: git-c2aa857 2022-10-08 (23760) 142MB -
5.6/stable: 5.6-794016a 2022-09-27 (23680) 142MB -
5.6/candidate: 5.6-794016a 2022-09-23 (23680) 142MB -
5.6/beta: ↑
5.6/edge: ↑
5.5/stable: 5.5-37534be 2022-08-27 (23537) 113MB -
5.5/candidate: 5.5-37534be 2022-08-19 (23537) 113MB -
5.5/beta: ↑
5.5/edge: ↑
5.4/stable: 5.4-1ff8d34 2022-08-13 (23367) 108MB -
5.4/candidate: 5.4-3bf11b7 2022-08-12 (23453) 108MB -
5.4/beta: ↑
5.4/edge: ↑
5.3/stable: 5.3-91e042b 2022-07-06 (23270) 107MB -
5.3/candidate: 5.3-b403e7f 2022-07-05 (23282) 107MB -
5.3/beta: ↑
5.3/edge: ↑
5.0/stable: 5.0.1-9dcf35b 2022-08-24 (23541) 107MB -
5.0/candidate: 5.0.1-9dcf35b 2022-08-19 (23541) 107MB -
5.0/beta: ↑
5.0/edge: git-13e1e53 2022-08-21 (23564) 113MB -
4.0/stable: 4.0.9-8e2046b 2022-03-26 (22753) 71MB -
4.0/candidate: 4.0.9-dea944b 2022-09-27 (23694) 72MB -
4.0/beta: ↑
4.0/edge: git-407205d 2022-03-31 (22797) 73MB -
3.0/stable: 3.0.4 2019-10-10 (11348) 55MB -
3.0/candidate: 3.0.4 2019-10-10 (11348) 55MB -
3.0/beta: ↑
3.0/edge: git-81b81b9 2019-10-10 (11362) 55MB -
installed: 5.6-794016a (23680) 142MB -
I’m suspecting some kind of network problem… but I really have no idea. The reason is because the configs for the broken containers don’t show a volatile.eth0.host_name entry. Here’s the config show of a working container:
jack@kdsapp0:~$ lxc config show apps -e
image.architecture: amd64
image.description: ubuntu 18.04 LTS amd64 (release) (20181206)
image.label: release
image.os: ubuntu
image.release: bionic
image.serial: "20181206"
image.version: "18.04"
volatile.base_image: 84a71299044bc3c3563396bef153c0da83d494f6bf3d38fecc55d776b1e19bf9
volatile.cloud-init.instance-id: 91f5603b-7d99-458e-a80a-336062d512a2
volatile.eth0.host_name: veth4aa4cc02
volatile.eth0.hwaddr: 00:16:3e:fd:e9:cf
volatile.idmap.base: "0"
volatile.uuid: 3dbf843c-bbd6-4b0b-80b3-226e523557c8
nictype: bridged
parent: br0
pool: zomg
and here’s one of a broken container
image.os: ubuntu
volatile.cloud-init.instance-id: bb566fca-6a45-41d5-bb71-df1e0c69e993
volatile.eth0.hwaddr: 00:16:3e:df:ea:84
volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":100000,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":100000,"Nsid":0,"Maprange":65536}]'
volatile.uuid: f322beb3-4e0c-4dad-aca1-f916b97b7d97
nictype: bridged
parent: br0
pool: zomg
and I’ve noticed that the broken containers don’t have a volatile.eth0.host_name entry.
At any rate, any help would be appreciated! I’ve been working on this all weekend and I’m stumped.
Thank you!
Jack
