Pardon the whole sordid story below, but figured best way to explain. The Other three upgrade fine, well actually still stuck waiting for this one.
root@Q3:/home/ic2000# apt upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
Get more security updates through Ubuntu Pro with ‘esm-apps’ enabled:
libavformat58 python2.7-dev libavfilter7 mc libmagickcore-6.q16-6-extra sntp
imagemagick libswresample3 libzmq5 python2.7-minimal libmagickwand-6.q16-6
libpython2.7 python2.7 libpython2.7-dev mc-data libpostproc55 ntp
imagemagick-6.q16 libavcodec58 libavutil56 libswscale5 libopenexr24
libmysofa1 libmagickcore-6.q16-6 libpython2.7-minimal libpython2.7-stdlib
imagemagick-6-common
Learn more about Ubuntu Pro at Ubuntu Pro | Ubuntu
The following NEW packages will be installed:
incus-base nftables
The following packages will be upgraded:
incus incus-client libnss-myhostname libnss-systemd libpam-systemd libsystemd0 libudev1 systemd systemd-sysv udev
10 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 91.3 MB of archives.
After this operation, 21.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 Index of /ubuntu focal-updates/main amd64 libnss-systemd amd64 245.4-4ubuntu3.23 [96.2 kB]
Get:2 Index of /ubuntu focal-updates/main amd64 udev amd64 245.4-4ubuntu3.23 [1,366 kB]
Get:3 Index of /incus/stable/ focal/main amd64 incus amd64 0.5-202401260134-ubuntu20.04 [25.0 MB]
Get:4 Index of /ubuntu focal-updates/main amd64 libudev1 amd64 245.4-4ubuntu3.23 [75.6 kB]
Get:5 Index of /ubuntu focal-updates/main amd64 systemd-sysv amd64 245.4-4ubuntu3.23 [10.3 kB]
Get:6 Index of /ubuntu focal-updates/main amd64 libpam-systemd amd64 245.4-4ubuntu3.23 [186 kB]
Get:7 Index of /ubuntu focal-updates/main amd64 systemd amd64 245.4-4ubuntu3.23 [3,811 kB]
Get:8 Index of /ubuntu focal-updates/main amd64 libsystemd0 amd64 245.4-4ubuntu3.23 [268 kB]
Get:9 Index of /ubuntu focal/universe amd64 nftables amd64 0.9.3-2 [51.2 kB]
Get:10 Index of /ubuntu focal-updates/main amd64 libnss-myhostname amd64 245.4-4ubuntu3.23 [41.4 kB]
Get:11 Index of /incus/stable/ focal/main amd64 incus-client amd64 0.5-202401260134-ubuntu20.04 [4,342 kB]
Get:12 Index of /incus/stable/ focal/main amd64 incus-base amd64 0.5-202401260134-ubuntu20.04 [56.1 MB]
Fetched 91.3 MB in 5s (19.3 MB/s)
(Reading database … 196559 files and directories currently installed.)
Preparing to unpack …/libnss-systemd_245.4-4ubuntu3.23_amd64.deb …
Unpacking libnss-systemd:amd64 (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Preparing to unpack …/udev_245.4-4ubuntu3.23_amd64.deb …
Unpacking udev (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Preparing to unpack …/libudev1_245.4-4ubuntu3.23_amd64.deb …
Unpacking libudev1:amd64 (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Setting up libudev1:amd64 (245.4-4ubuntu3.23) …
Preparing to unpack …/systemd-sysv_245.4-4ubuntu3.23_amd64.deb …
Unpacking systemd-sysv (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Preparing to unpack …/libpam-systemd_245.4-4ubuntu3.23_amd64.deb …
Unpacking libpam-systemd:amd64 (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Preparing to unpack …/systemd_245.4-4ubuntu3.23_amd64.deb …
Unpacking systemd (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Preparing to unpack …/libsystemd0_245.4-4ubuntu3.23_amd64.deb …
Unpacking libsystemd0:amd64 (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Setting up libsystemd0:amd64 (245.4-4ubuntu3.23) …
Selecting previously unselected package nftables.
Preparing to unpack …/nftables_0.9.3-2_amd64.deb …
Unpacking nftables (0.9.3-2) …
Preparing to unpack …/incus_0.5-202401260134-ubuntu20.04_amd64.deb …
Unpacking incus (0.5-202401260134-ubuntu20.04) over (0.4-202312232117-ubuntu20.04) …
dpkg: warning: unable to delete old directory ‘/var/log/incus’: Directory not empty
dpkg: warning: unable to delete old directory ‘/var/lib/incus’: Directory not empty
Preparing to unpack …/incus-client_0.5-202401260134-ubuntu20.04_amd64.deb …
Unpacking incus-client (0.5-202401260134-ubuntu20.04) over (0.4-202312232117-ubuntu20.04) …
Selecting previously unselected package incus-base.
Preparing to unpack …/incus-base_0.5-202401260134-ubuntu20.04_amd64.deb …
Unpacking incus-base (0.5-202401260134-ubuntu20.04) …
Preparing to unpack …/libnss-myhostname_245.4-4ubuntu3.23_amd64.deb …
Unpacking libnss-myhostname:amd64 (245.4-4ubuntu3.23) over (245.4-4ubuntu3.22) …
Setting up nftables (0.9.3-2) …
Setting up systemd (245.4-4ubuntu3.23) …
Setting up udev (245.4-4ubuntu3.23) …
update-initramfs: deferring update (trigger activated)
Setting up libnss-myhostname:amd64 (245.4-4ubuntu3.23) …
Setting up incus-client (0.5-202401260134-ubuntu20.04) …
Setting up systemd-sysv (245.4-4ubuntu3.23) …
Setting up incus-base (0.5-202401260134-ubuntu20.04) …
Job failed. See “journalctl -xe” for details.
dpkg: error processing package incus-base (–configure):
installed incus-base package post-installation script subprocess returned error exit status 1
Setting up libnss-systemd:amd64 (245.4-4ubuntu3.23) …
dpkg: dependency problems prevent configuration of incus:
incus depends on incus-base (= 0.5-202401260134-ubuntu20.04); however:
Package incus-base is not configured yet.
dpkg: error processing package incus (–configure):
dependency problems - leaving unconfigured
Setting up libpam-systemd:amd64 (245.4-4ubuntu3.23) …
No apport report written because the error message indicates its a followup error from a previous failure.
Processing triggers for man-db (2.
9.1-1) …
Processing triggers for ureadahead (0.100.0-21) …
Processing triggers for dbus (1.12.16-2ubuntu2.3) …
Processing triggers for libc-bin (2.31-0ubuntu9.14) …
Processing triggers for initramfs-tools (0.136ubuntu6.7) …
update-initramfs: Generating /boot/initrd.img-5.4.0-170-generic
Errors were encountered while processing:
incus-base
incus
E: Sub-process /usr/bin/dpkg returned an error code (1)
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
2.31-0ubuntu9.14) …
incus-base
incus
root@Q3:/home/ic2000# apt update
Hit:1 Index of /ubuntu focal InRelease
Hit:2 Index of /ubuntu focal-updates InRelease
Hit:3 Index of /ubuntu focal-backports InRelease
Hit:4 Index of /ubuntu focal-security InRelease
Hit:5 Index of /incus/stable/ focal InRelease
All packages are up to date.
2.31-0ubuntu9.14) …
incus-base
incus
root@Q3:/home/ic2000# sudo dpkg --configure -a
incus-base
incus
root@Q3:/home/ic2000# sudo dpkg --remove --force-remove-reinstreq incus-base
dpkg: dependency problems prevent removal of incus-base:
incus depends on incus-base (= 0.5-202401260134-ubuntu20.04).
dpkg: error processing package incus-base (–remove):
dependency problems - not removing
incus-base
(Reading database … 196631 files and directories currently installed.)
Removing incus (0.5-202401260134-ubuntu20.04) …
root@Q3:/home/ic2000# sudo apt-get clean
root@Q3:/home/ic2000# sudo apt-get update
root@Q3:/home/ic2000# sudo apt-get install incus-base incus
incus-base is already the newest version (0.5-202401260134-ubuntu20.04).
incus-base set to manually installed.
incus
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 25.0 MB of archives.
After this operation, 68.3 MB of additional disk space will be used.
Get:1 Index of /incus/stable/ focal/main amd64 incus amd64 0.5-202401260134-ubuntu20.04 [25.0 MB]
Fetched 25.0 MB in 2s (16.2 MB/s)
Selecting previously unselected package incus.
(Reading database … 196573 files and directories currently installed.)
Unpacking incus (0.5-202401260134-ubuntu20.04) …
incus-base
incus
root@Q3:/home/ic2000# journalctl -xe
Jan 28 04:28:24 Q3 sshd[222211]: Invalid user user from 23.94.143.132 port 55210
Jan 28 04:28:24 Q3 sshd[222211]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:28:24 Q3 sshd[222211]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=23.94.143.132
Jan 28 04:28:25 Q3 incusd[7335]: time=“2024-01-28T04:28:25-05:00” level=warning msg=“Failed adding member event listener client” err="read >
Jan 28 04:28:25 Q3 sshd[222213]: Invalid user sftpuser from 221.214.2.98 port 2462
Jan 28 04:28:25 Q3 sshd[222213]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:28:25 Q3 sshd[222213]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=221.214.2.98
Jan 28 04:28:25 Q3 smbd[222210]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:28:26 Q3 smbd[222209]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:28:26 Q3 sshd[222211]: Failed password for invalid user user from 23.94.143.132 port 55210 ssh2
Jan 28 04:28:27 Q3 sshd[222213]: Failed password for invalid user sftpuser from 221.214.2.98 port 2462 ssh2
Jan 28 04:28:27 Q3 sshd[222211]: Received disconnect from 23.94.143.132 port 55210:11: Bye Bye [preauth]
Jan 28 04:28:27 Q3 sshd[222211]: Disconnected from invalid user user 23.94.143.132 port 55210 [preauth]
Jan 28 04:28:27 Q3 sshd[222213]: Received disconnect from 221.214.2.98 port 2462:11: Bye Bye [preauth]
Jan 28 04:28:27 Q3 sshd[222213]: Disconnected from invalid user sftpuser 221.214.2.98 port 2462 [preauth]
Jan 28 04:28:30 Q3 incusd[7335]: time=“2024-01-28T04:28:30-05:00” level=warning msg=“Could not rebalance cluster member roles” err="Daemon >
Jan 28 04:28:32 Q3 sshd[222217]: Invalid user postgres from 189.4.10.114 port 33474
Jan 28 04:28:32 Q3 sshd[222217]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:28:32 Q3 sshd[222217]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=189.4.10.114
Jan 28 04:28:32 Q3 smbd[222219]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:28:33 Q3 smbd[222222]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:28:33 Q3 sshd[222217]: Failed password for invalid user postgres from 189.4.10.114 port 33474 ssh2
Jan 28 04:28:34 Q3 sshd[222220]: Invalid user admin from 196.0.120.211 port 54906
Jan 28 04:28:34 Q3 sshd[222220]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:28:34 Q3 sshd[222220]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=196.0.120.211
Jan 28 04:28:34 Q3 sshd[222217]: Received disconnect from 189.4.10.114 port 33474:11: Bye Bye [preauth]
Jan 28 04:28:34 Q3 sshd[222217]: Disconnected from invalid user postgres 189.4.10.114 port 33474 [preauth]
Jan 28 04:28:35 Q3 smbd[222224]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:28:35 Q3 incusd[7335]: time=“2024-01-28T04:28:35-05:00” level=warning msg=“Failed adding member event listener client” err="read >
Jan 28 04:28:36 Q3 sshd[222220]: Failed password for invalid user admin from 196.0.120.211 port 54906 ssh2
Jan 28 04:28:36 Q3 sshd[222225]: error: kex_exchange_identification: Connection closed by remote host
Jan 28 04:21:45 Q3 sshd[220686]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:21:45 Q3 sshd[220686]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=123.207.59.181
Jan 28 04:21:45 Q3 smbd[220692]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:21:47 Q3 incusd[7335]: time=“2024-01-28T04:21:47-05:00” level=warning msg=“Failed adding member event listener client” err="read >
Jan 28 04:21:47 Q3 sshd[220694]: Invalid user test from 221.214.2.98 port 2443
Jan 28 04:21:47 Q3 sshd[220694]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:21:47 Q3 sshd[220694]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=221.214.2.98
Jan 28 04:21:47 Q3 sshd[220686]: Failed password for invalid user botuser from 123.207.59.181 port 48114 ssh2
Jan 28 04:21:47 Q3 smbd[220696]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:21:48 Q3 smbd[220688]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:21:49 Q3 smbd[220693]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:21:50 Q3 sshd[220694]: Failed password for invalid user test from 221.214.2.98 port 2443 ssh2
Jan 28 04:21:50 Q3 sshd[220686]: Received disconnect from 123.207.59.181 port 48114:11: Bye Bye [preauth]
Jan 28 04:21:50 Q3 sshd[220686]: Disconnected from invalid user botuser 123.207.59.181 port 48114 [preauth]
Jan 28 04:21:50 Q3 smbd[220698]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:21:52 Q3 sshd[220694]: Received disconnect from 221.214.2.98 port 2443:11: Bye Bye [preauth]
Jan 28 04:21:52 Q3 sshd[220694]: Disconnected from invalid user test 221.214.2.98 port 2443 [preauth]
Jan 28 04:21:53 Q3 incusd[7335]: time=“2024-01-28T04:21:53-05:00” level=warning msg=“Could not rebalance cluster member roles” err="Daemon >
Jan 28 04:21:55 Q3 smbd[220699]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:21:58 Q3 incusd[7335]: time=“2024-01-28T04:21:58-05:00” level=warning msg=“Failed adding member event listener client” err="read >
Jan 28 04:22:05 Q3 incusd[7335]: time=“2024-01-28T04:22:05-05:00” level=warning msg=“Could not rebalance cluster member roles” err="Daemon >
Jan 28 04:22:08 Q3 smbd[220705]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:22:09 Q3 sshd[220706]: Invalid user server from 221.214.2.98 port 2444
Jan 28 04:22:09 Q3 sshd[220706]: pam_unix(sshd:auth): check pass; user unknown
Jan 28 04:22:09 Q3 sshd[220706]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=221.214.2.98
Jan 28 04:22:10 Q3 incusd[7335]: time=“2024-01-28T04:22:10-05:00” level=warning msg=“Failed adding member event listener client” err="read >
Jan 28 04:22:10 Q3 incusd[7335]: time=“2024-01-28T04:22:10-05:00” level=warning msg="Heartbeat round duration greater than heartbeat interv>
Jan 28 04:22:10 Q3 smbd[220704]: pam_unix(samba:session): session closed for user nobody
Jan 28 04:22:11 Q3 sshd[220706]: Failed password for invalid user server from 221.214.2.98 port 2444 ssh2
root@Q3:/home/ic2000# mc
X11 connection rejected because of wrong authentication.
2.31-0ubuntu9.14) …
incus-base
incus
incus is already the newest version (0.5-202401260134-ubuntu20.04).
incus-base
incus
incus
