Hi folks,
As the topic title suggests, I’m trying to pass a USB webcam through to an unprivileged LXC container.
On the HOST machine (running Arch Linux)
[root@IXTREME ~]# ls -lh /dev/vid*
crw-rw----+ 1 root video 81, 0 Jul 6 05:48 /dev/video0
[root@IXTREME ~]# v4l2-ctl -l -d /dev/video0
brightness 0x00980900 (int) : min=0 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=0 max=255 step=1 default=128 value=128
saturation 0x00980902 (int) : min=0 max=255 step=1 default=128 value=128
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gain 0x00980913 (int) : min=0 max=255 step=1 default=0 value=0
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=2 value=2
white_balance_temperature 0x0098091a (int) : min=2000 max=6500 step=1 default=4000 value=6102 flags=inactive
sharpness 0x0098091b (int) : min=0 max=255 step=1 default=128 value=128
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=0 value=0
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
exposure_absolute 0x009a0902 (int) : min=3 max=2047 step=1 default=250 value=83 flags=inactive
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
pan_absolute 0x009a0908 (int) : min=-36000 max=36000 step=3600 default=0 value=0
tilt_absolute 0x009a0909 (int) : min=-36000 max=36000 step=3600 default=0 value=0
focus_absolute 0x009a090a (int) : min=0 max=250 step=5 default=0 value=0 flags=inactive
focus_auto 0x009a090c (bool) : default=1 value=1
zoom_absolute 0x009a090d (int) : min=100 max=500 step=1 default=100 value=100
[root@IXTREME ~]#
In my container config file I have this …
#USB Camera Passthrough
lxc.mount.entry = /dev/video0 dev/video0 none bind,optional,create=file
lxc.cgroup.devices.allow = c 81:* rwm
and I also have …
lxc.idmap = u 0 100000 65536
lxc.idmap = g 0 100000 65536
Also, both /etc/subuid & /etc/subgid contain …
root:100000:65536
Inside the container …
[root@zm ~]# ls -lh /dev/vid*
crw-rw----+ 1 nobody nobody 81, 0 Jul 6 05:48 /dev/video0
[root@zm ~]# v4l2-ctl -l -d /dev/video0
Failed to open /dev/video0: Permission denied
How can I allow the container to access the camera? Is there anything I can add to the container config, or do with device file permissions?
Thanks!
