Just a simple question.
Is it possible to add to container an usb device from remote host. By cluster?
Plan:
Host1:
- Home automation container
Host2
- USB Dongles
Home automation container retrieve from dongles plugs on host2 datas.
Thanks.
Plan:
Host1:
Host2
Thanks.
Hi!
Normally, you can expose a USB device from the host to a container on that host. The way this is currently done, is the device disappears from the host and is available exclusively to that container.
You are asking about sharing a resource (a USB device) between two LXD installations, which in effect means to share a USB device over IP.
By setting up usbip, the issue of sharing a USB device becomes an issue of setting up a network connection between the two hosts.
The pieces in doing all these are there (usbip client software, usbip kernel module, etc).
Have a look on putting them together. If you can find a good guide on this to recommend, would be great.
In general, this is USB over IP
Thanks, not necessary sharing device, It can stay exclusively to a container.
I’ll try to find solution about network.
Thanks.
