Hello, I would like to use an bind an Arduino serial interface ( /dev/ttyACM0 ) to a LXD container. I have successfully done the pass-through while the container is running with this command :
sudo lxc config device add dev ttyACM0 unix-char path=/dev/ttyACM0 mode=0777 required=false
I do not care about the permissions yet but I plan to map the dialout group when it will work fine. By the way this works and I can read and write the serial interface inside the container. The problem is if I stop the container I cannot start it again because I get the error :
$ sudo lxc start dev
Error: not a directory
Trylxc info --show-log dev
for more info
The info command is not really helpful by the way :
~$ sudo lxc info --show-log dev
Remote: unix://
Created: 2018/01/02 06:36 UTC
Status: Stopped
Type: persistent
Profiles: default
Log:
lxc 20180410192959.939 WARN lxc_conf - conf.c:lxc_map_ids:2831 - newuidmap binary is missing
lxc 20180410192959.939 WARN lxc_conf - conf.c:lxc_map_ids:2837 - newgidmap binary is missing
lxc 20180410192959.941 WARN lxc_conf - conf.c:lxc_map_ids:2831 - newuidmap binary is missing
lxc 20180410192959.941 WARN lxc_conf - conf.c:lxc_map_ids:2837 - newgidmap binary is missing
lxc 20180410193114.606 WARN lxc_conf - conf.c:lxc_map_ids:2831 - newuidmap binary is missing
lxc 20180410193114.606 WARN lxc_conf - conf.c:lxc_map_ids:2837 - newgidmap binary is missing
Maybe it’s a bug and I should fill one? Maybe I miss something? Thank you for helping!
