Use a single LXD container on multiple hosts
There are different use cases in which you want to share one container between
multiple hosts. I am not talking about simultaneous access. I stop the container
before opening it on another host. I have a dual boot laptop with two Linux
systems. I also would like to carry a container on a USB stick. In other words,
the hosts don’t have network access to each other but they can share disk space.
I suppose the obvious way of doing it is to export an image and import it on the
other system but that takes too much time and it is easy to forget and overwrite
something.
On my multiboot laptop I configured a btrfs subvolume that I mount under
/var/lib/lxd/storage-pools/ on both systems. I ran “lxd import ”.
It seems to work but I have a few concerns:
- In the documentation it describes “lxd import” as:
This recovery mechanism is mostly meant for emergency recoveries…
The document does not say that you need to place your imported container
storage pool in /var/lib/lxd/storage-pools. I found it in a reply that Stephane
Graber made in a conversation with somebody else. It was after multiple attempts
to call lxd import in other directories. -
Calling the deamon lxd instead of lxc is unusual because all other storage
manipulation commands are done with lxc.
Does the container have any host specific information that can cause some
conflict on a different host? What prevents you from moving this feature beyond
“emergency recoveries”? How can the clustering in 3.0 help with my use case?
