Hello ,
i just trying to make some containers to access from network and finded this tutorial :
but facing error when launch container
Error: Failed to start device “eth0”: Parent device ‘enp2s0’ doesn’t exist
this is fresh installation ubuntu-22.04.3-live-server-amd64
$ lxd init --minimal
$ lxc profile copy default macvlan-profile
$ lxc profile device remove macvlan-profile eth0
Device eth0 removed from macvlan-profile
$ lxc profile device add macvlan-profile eth0 nic nictype=macvlan parent=enp2s0
Device eth0 added to macvlan-profile
$ lxc launch images:ubuntu/22.04 cPanel --profile macvlan-profile
Creating cPanel
Starting cPanel
Error: Failed to start device "eth0": Parent device 'enp2s0' doesn't exist
Try `lxc info --show-log local:cPanel` for more info
$ lxc info --show-log local:cPanel
Status: STOPPED
Type: container
Created: 2023/10/09 19:48 UTC
Log:
$ ifconfig
enp0s25: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.1 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::223:24ff:fe12:d147 prefixlen 64 scopeid 0x20<link>
ether 00:23:24:12:d1:47 txqueuelen 1000 (Ethernet)
RX packets 93643 bytes 136594271 (136.5 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 46551 bytes 3349163 (3.3 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 19 memory 0xf0500000-f0520000
enp0s25.1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 0 bytes 0 (0.0 B)
TX packets 75 bytes 20894 (20.8 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 174 bytes 15421 (15.4 KB)
TX packets 174 bytes 15421 (15.4 KB)
lxdbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 10.134.3.1 netmask 255.255.255.0 broadcast 0.0.0.0
inet6 fd42:2f46:32ae:ba6a::1 prefixlen 64 scopeid 0x0<global>
ether 00:16:3e:b2:76:4b txqueuelen 1000 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
$ lxc profile show default
config: {}
network: lxdbr0
pool: default
used_by: []
$ lxc network show lxdbr0
ipv4.address: 10.134.3.1/24
ipv4.nat: "true"
ipv6.address: fd42:2f46:32ae:ba6a::1/64
ipv6.nat: "true"
type: bridge
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
that’s all
