Using kubespray I have formed k8s cluster. The cluster works fine with containerd as container runtime endpoint. But if I change the endpoint to use lxe, all the pods of kube-system are going down and claiming that the images are missing. If I try to create a new pod it says the image alias is missing. I want all the containers of kube-system namespace use containerd image and my created pod uses lxe image. Is it possible?
lxd-remote-config is using the following config.yml
default-remote: local
remotes:
images:
ubuntu:
addr: Ubuntu Cloud Images
public: true
protocol: simplestreams
My pod creation config content:
apiVersion: v1
kind: Pod
metadata:
namespace: default
spec:
tolerations:
- key: node-role.kubernetes.io/master
operator: Exists
containers:
- name: nginx
image: “ubuntu/xenial/amd64”
