To activate the trans codification for jellyfin I need to activate VAAPI on my container.
For now I have a privileged container (I launched it as root with lxc-start) working perfectly.
Is it possible to activate VAAPI on this type of container or do I need to create unprivileged container?
If the second solution is the way, is anyone as a decent tuto create unprivileged container? I am on debian 11 and it is a pain.
Thanks
It should be fine but I don’t know exactly what VAAPI uses to access the GPU.
My guess would be the /dev/dri nodes which would then need to be passed through with either the gpu device type or individually with unix-char.
