I tried with config v1 and v2. None of them has worked so far.
# -*- mode: ruby -*-
# vi: set ft=ruby :
# All Vagrant configuration is done below. The "2" in Vagrant.configure
# configures the configuration version (we support older styles for
# backwards compatibility). Please don't change it unless you know what
# you're doing.
Vagrant.configure("2") do |config|
config.vm.network "public_network"
#config.vm.network "bridged"
config.vm.provider "virtualbox" do |vb|
vb.gui = true
vb.memory = "3333"
vb.cpus = "1"
end
config.vm.define "rockyVM" do |subconfig|
subconfig.vm.box = "rockylinux/9"
subconfig.vm.hostname = "rockyVM"
end
config.vm.provision "shell", path: "provision.sh"
end
This is how my Vagrantfile looks like. I think vagrant is perhaps not the right tool for the job on Windows machine to create VMs inside virtualbox.
