Howdy,
I have tried several ways to give Incus instances, both VMs and containers, full control over some of the hardware in my machine. TL;DR: Debian-based MX Linux 23 using Liquorix kernel 6.3 on Xeon E3-1270v6 and Quadro P1000. The other pertinent hardware are two PCIe networking cards, one for ethernet and one for wireless.
System:
Kernel: 6.3.9-1-liquorix-amd64 [6.3-9~mx23+1] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 parameters: audit=0
intel_pstate=disable hpet=disable rcupdate.rcu_expedited=1
BOOT_IMAGE=/BOOT-VOL/misty-mx-bootfs@/vmlinuz-6.3.9-1-liquorix-amd64
root=ZFS=/ROOT-VOL/misty-mx-rootfs ro root=ZFS=misty-mx-root-pool/ROOT-VOL/misty-mx-rootfs
quiet splash rd.driver.pre=vfio-pci intel_iommu=on init=/lib/systemd/systemd
Desktop: KDE Plasma v: 5.27.5 wm: kwin_wayland vt: 2 dm: SDDM Distro: MX-23.2_KDE_x64 Libretto
July 31 2023 base: Debian GNU/Linux 12 (bookworm)
Machine:
Type: Desktop System: HP product: HP Z240 SFF Workstation v: N/A serial: <superuser required>
Chassis: type: 4 serial: <superuser required>
Mobo: HP model: 802E serial: <superuser required> UEFI: HP v: N51 Ver. 01.89 date: 07/28/2023
CPU:
Info: model: Intel Xeon E3-1270 v6 bits: 64 type: MT MCP arch: Kaby Lake level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xF4
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 985 high: 1400 min/max: 800/3801 boost: enabled scaling: driver: acpi-cpufreq
governor: ondemand cores: 1: 1400 2: 1285 3: 800 4: 800 5: 1200 6: 800 7: 800 8: 800
bogomips: 60798
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: itlb_multihit status: KVM: Split huge pages
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: mds mitigation: Clear CPU buffers; SMT vulnerable
Type: meltdown mitigation: PTI
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: retbleed mitigation: IBRS
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Type: srbds mitigation: Microcode
Type: tsx_async_abort mitigation: TSX disabled
Graphics:
Device-1: NVIDIA GP107GL [Quadro P1000] driver: nvidia v: 535.129.03
alternate: nouveau,nvidia_drm,nvidia_vgpu_vfio non-free: 530.xx+ status: current (as of 2023-03)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-1,DP-2,DP-4 bus-ID: 01:00.0 chip-ID: 10de:1cb1
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.9 compositor: kwin_wayland
driver: X: loaded: nvidia gpu: nvidia display-ID: 0
Monitor-1: DP-3 res: 1280x1024 size: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.129.03 renderer: Quadro P1000/PCIe/SSE2 direct-render: Yes
Audio:
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.3.9-1-liquorix-amd64 status: kernel-api tools: alsamixer,amixer
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
tools: pactl,pw-cat,pw-cli,wpctl
Network:
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: eth1 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel modules: wl pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 168c:0042 class-ID: 0280
IF: wlan0 state: down mac: <filter>
IF-ID-1: anvilbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: tap750e3856 state: up speed: 10000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-12:3 chip-ID: 0cf3:e009
class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Info: acl-mtu: 1024:8 sco-mtu: 50:8 link-policy: rswitch hold sniff
link-mode: peripheral accept
RAID:
Device-1: backup-bottom-pool type: zfs status: ONLINE level: linear raw: size: 29 GiB
free: 29 GiB allocated: 1.9 MiB zfs-fs: size: 28.09 GiB free: 28.09 GiB
Components: Online:
1: sdd4 maj-min: 8:52 size: 29.3 GiB
Device-2: lakitu-pool type: zfs status: ONLINE level: linear raw: size: 1.86 TiB free: 1.81 TiB
allocated: 59.8 GiB zfs-fs: size: 1.8 TiB free: 1.74 TiB
Components: Online:
1: sda1 maj-min: 8:1 size: 1.86 TiB
Device-3: misty-incus-backup-pool type: zfs status: ONLINE level: linear raw: size: 29 GiB
free: 29 GiB allocated: 600 KiB zfs-fs: size: 28.09 GiB free: 28.09 GiB
Components: Online:
1: nvme1n1p6 maj-min: 259:6 size: 29.3 GiB
Device-4: misty-mx-boot-pool type: zfs status: ONLINE level: linear raw: size: 960 MiB
free: 542 MiB allocated: 418 MiB zfs-fs: size: 831.7 MiB free: 413.8 MiB
Components: Online:
1: nvme1n1p4 maj-min: 259:4 size: 1000 MiB
Device-5: misty-mx-root-pool type: zfs status: ONLINE level: linear raw: size: 48.5 GiB
free: 38.3 GiB allocated: 10.2 GiB zfs-fs: size: 47 GiB free: 36.81 GiB
Components: Online:
1: nvme1n1p5 maj-min: 259:5 size: 48.83 GiB
Device-6: special type: zfs status: - level: mirror-1 zfs-fs: size: 1.8 TiB free: raw:
size: 5.86 GiB free: 5.5 GiB allocated: 578 KiB
Components: Online:
1: nvme0n1p2 maj-min: 259:9 size: 5.86 GiB
2: nvme1n1p2 maj-min: 259:2 size: 5.86 GiB
Device-7: special type: zfs status: - level: mirror-2 zfs-fs: size: 94 GiB free: raw:
size: 22.5 GiB free: 22 GiB allocated: 513 KiB
Components: Online:
1: nvme0n1p1 maj-min: 259:8 size: 22.46 GiB
2: nvme1n1p1 maj-min: 259:1 size: 22.46 GiB
Device-8: zippy-top-pool type: zfs status: ONLINE level: linear raw: size: 29 GiB
free: 23.4 GiB allocated: 5.6 GiB zfs-fs: size: 28.09 GiB free: 22.5 GiB
Components: Online:
1: nvme0n1p3 maj-min: 259:10 size: 29.3 GiB
Device-9: zkiff-pool type: zfs status: ONLINE level: linear raw: size: 119 GiB free: 119 GiB
allocated: 558 KiB zfs-fs: size: 94 GiB free: 94 GiB
Components: Online:
1: sdb1 maj-min: 8:17 size: 48.83 GiB
2: sdc1 maj-min: 8:33 size: 48.83 GiB
Drives:
Local Storage: total: raw: 13.36 TiB usable: 13.32 TiB used: 69.45 GiB (0.5%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: SSSTC model: CL1-3D128-Q11 NVMe SSSTC 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 22301116 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW512G7 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: PSF109C temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T2532TB size: 1.86 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8A0 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000NM0033-9ZM170 size: 3.64 TiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: SN07 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000NM0033-9ZM170 size: 3.64 TiB
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST4000LM024-2U817V size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: SPS5 scheme: GPT
Partition:
ID-1: / raw-size: N/A size: 44.29 GiB used: 7.48 GiB (16.9%) fs: zfs
logical: misty-mx-root-pool/ROOT-VOL/misty-mx-rootfs
ID-2: /boot raw-size: N/A size: 538.5 MiB used: 124.8 MiB (23.2%) fs: zfs
logical: misty-mx-boot-pool/BOOT-VOL/misty-mx-bootfs
ID-3: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 512 KiB (0.1%) fs: vfat
dev: /dev/nvme1n1p3 maj-min: 259:3
ID-4: /home raw-size: N/A size: 38.62 GiB used: 1.81 GiB (4.7%) fs: zfs
logical: misty-mx-root-pool/HOME-VOL/home
ID-5: /var/log raw-size: N/A size: 22.56 GiB used: 68.1 MiB (0.3%) fs: zfs
logical: zippy-top-pool/CACHE-VOL/misty-mx-vlog
Swap:
Alert: No swap data was found.
Sensors:
System Temperatures: cpu: 51.0 C pch: 87.0 C mobo: N/A
Fan Speeds (RPM): N/A
Repos:
Packages: pm: dpkg pkgs: 2429 libs: 1294 tools: apt,apt-get,aptitude,nala pm: rpm pkgs: 0
pm: flatpak pkgs: 0
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
1: deb http://mirror.keystealth.org/debian bookworm-updates main contrib non-free non-free-firmware
Active apt repos in: /etc/apt/sources.list.d/debian.list
1: deb http://mirror.keystealth.org/debian bookworm main contrib non-free non-free-firmware
2: deb http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware
Active apt repos in: /etc/apt/sources.list.d/librewolf.list
1: deb [arch=amd64] http://deb.librewolf.net bullseye main
Active apt repos in: /etc/apt/sources.list.d/mx.list
1: deb http://la.mxrepo.com/mx/repo/ bookworm main non-free
2: deb http://la.mxrepo.com/mx/repo/ bookworm ahs
Active apt repos in: /etc/apt/sources.list.d/rdiffweb.list
1: deb [arch=amd64 signed-by=/usr/share/keyrings/rdiffweb-keyring.gpg] https://nexus.ikus-soft.com/repository/apt-release-bookworm/ bookworm main
Active apt repos in: /etc/apt/sources.list.d/zrepl.list
1: deb [arch=amd64 signed-by=/usr/share/keyrings/zrepl.gpg] https://zrepl.cschwarz.com/apt/debian bookworm main
Active apt repos in: /etc/apt/sources.list.d/zabbly-incus-stable.sources
1: deb [arch=amd64] https://pkgs.zabbly.com/incus/stable bookworm main
Info:
Processes: 646 Uptime: 19m wakeups: 0 Memory: 62.73 GiB used: 4.4 GiB (7.0%) Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 12 Client: shell wrapper
v: 5.2.15-release inxi: 3.3.26
Boot Mode: UEFI
I followed this guide to boot from ZFS, then this guide to install my GPU driver. The driver I’m using is ‘merged,’ meaning that it should simultaneously support host usage desktop applications, as well as the KVM NVIDIA vGPU feature, which uses VFIO to share the card’s resources with virtual machines. I intend to use Incus to spin up a couple of VMs with just a little video RAM for AI, transcoding, and whatever. Eventually, it might also be nice to set up SR-IOV on the host GPU driver with an Arch container for gaming.
I would like a container to ‘own’ the wireless adapter and the onboard ethernet adapter, as well as run the license server, then share the GPU with some VMs via mdev/vgpu. There are myriad snippets online for enabling vfio-pci–or, vfio_pci–I can’t tell which, anymore. I found similar posts for AMD GPUs on the MX Forum and with mkinitcpio on the Arch Forum, but I still don’t see the vfio-pci kernel driver in use for any of these devices on my machine! Perhaps Incus works some magic that doesn’t require this to be enabled? Every time I have tried a physical nictype, the VM/container has been unable to use the interface–or, at least, could not detect any wireless adapter. If it’s magic, my machine seems not to be under the spell.
$ lspci -nnvvk
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5918] (rev 05)
Subsystem: Hewlett-Packard Company Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [103c:802e]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 0
IOMMU group: 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
Kernel modules: ie31200_edac
00:01.0 PCI bridge [0604]: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 05) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company 6th-10th Gen Core Processor PCIe Controller (x16) [103c:802e]
Physical Slot: 1
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 121
IOMMU group: 1
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 4000-4fff [size=4K] [16-bit]
Memory behind bridge: d2000000-d30fffff [size=17M] [32-bit]
Prefetchable memory behind bridge: c0000000-d1ffffff [size=288M] [32-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:14.0 USB controller [0c03]: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller [8086:a12f] (rev 31) (prog-if 30 [XHCI])
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller [103c:802e]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 146
IOMMU group: 2
Region 0: Memory at d3720000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 Signal processing controller [1180]: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem [8086:a131] (rev 31)
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family Thermal Subsystem [103c:802e]
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin C routed to IRQ 18
IOMMU group: 2
Region 0: Memory at d374a000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:16.0 Communication controller [0780]: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 [8086:a13a] (rev 31)
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family MEI Controller [103c:802e]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 126
IOMMU group: 3
Region 0: Memory at d374b000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
00:16.3 Serial controller [0700]: Intel Corporation 100 Series/C230 Series Chipset Family KT Redirection [8086:a13d] (rev 31) (prog-if 02 [16550])
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family KT Redirection [103c:802e]
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin D routed to IRQ 19
IOMMU group: 3
Region 0: I/O ports at 5040 [size=8]
Region 1: Memory at d374f000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: serial
00:17.0 SATA controller [0106]: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] [8086:a102] (rev 31) (prog-if 01 [AHCI 1.0])
Subsystem: Hewlett-Packard Company Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] [103c:802e]
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 127
IOMMU group: 4
Region 0: Memory at d3748000 (32-bit, non-prefetchable) [size=8K]
Region 1: Memory at d374e000 (32-bit, non-prefetchable) [size=256]
Region 2: I/O ports at 5048 [size=8]
Region 3: I/O ports at 5050 [size=4]
Region 4: I/O ports at 5020 [size=32]
Region 5: Memory at d374c000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 [8086:a167] (rev f1) (prog-if 00 [Normal decode])
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family PCI Express Root Port [103c:802e]
Physical Slot: 5
Latency: 0
Interrupt: pin A routed to IRQ 122
IOMMU group: 5
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: d3600000-d36fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
00:1c.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #6 [8086:a115] (rev f1) (prog-if 00 [Normal decode])
Physical Slot: 31
Latency: 0
Interrupt: pin B routed to IRQ 123
IOMMU group: 6
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 3000-3fff [size=4K] [16-bit]
Memory behind bridge: d3500000-d35fffff [size=1M] [32-bit]
00:1c.6 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 [8086:a116] (rev f1) (prog-if 00 [Normal decode])
Physical Slot: 31
Latency: 0
Interrupt: pin C routed to IRQ 124
IOMMU group: 7
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: d3200000-d33fffff [size=2M] [32-bit]
00:1d.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 [8086:a118] (rev f1) (prog-if 00 [Normal decode])
Physical Slot: 4
Latency: 0
Interrupt: pin A routed to IRQ 125
IOMMU group: 8
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
Memory behind bridge: d3400000-d34fffff [size=1M] [32-bit]
00:1f.0 ISA bridge [0601]: Intel Corporation C236 Chipset LPC/eSPI Controller [8086:a149] (rev 31)
Subsystem: Hewlett-Packard Company C236 Chipset LPC/eSPI Controller [103c:802e]
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
IOMMU group: 9
00:1f.2 Memory controller [0580]: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller [8086:a121] (rev 31)
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family Power Management Controller [103c:802e]
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
IOMMU group: 9
Region 0: Memory at d3744000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family HD Audio Controller [103c:802e]
Latency: 64
Interrupt: pin A routed to IRQ 149
IOMMU group: 9
Region 0: Memory at d3740000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at d3730000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs
00:1f.4 SMBus [0c05]: Intel Corporation 100 Series/C230 Series Chipset Family SMBus [8086:a123] (rev 31)
Subsystem: Hewlett-Packard Company 100 Series/C230 Series Chipset Family SMBus [103c:802e]
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
IOMMU group: 9
Region 0: Memory at d374d000 (64-bit, non-prefetchable) [size=256]
Region 4: I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-LM [8086:15b7] (rev 31)
DeviceName: Onboard Lan
Subsystem: Hewlett-Packard Company Ethernet Connection (2) I219-LM [103c:802e]
Latency: 0
Interrupt: pin A routed to IRQ 147
IOMMU group: 10
Region 0: Memory at d3700000 (32-bit, non-prefetchable) [size=128K]
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107GL [Quadro P1000] [10de:1cb1] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation GP107GL [Quadro P1000] [10de:11bc]
Latency: 0
Interrupt: pin A routed to IRQ 151
IOMMU group: 1
Region 0: Memory at d2000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at c0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at d0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at 4000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia_vgpu_vfio, nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:0fb9] (rev a1)
Subsystem: NVIDIA Corporation GP107GL High Definition Audio Controller [10de:11bc]
Latency: 0
Interrupt: pin B routed to IRQ 17
IOMMU group: 1
Region 0: Memory at d3000000 (32-bit, non-prefetchable) [size=16K]
02:00.0 Non-Volatile memory controller [0108]: Intel Corporation SSD 600P Series [8086:f1a5] (rev 03) (prog-if 02 [NVM Express])
Subsystem: Intel Corporation SSDPEKKW256G7 256GB [8086:390a]
Latency: 0
IOMMU group: 11
Region 0: Memory at d3600000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
03:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:0123]
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 17
IOMMU group: 12
Region 0: I/O ports at 3000 [size=256]
Region 2: Memory at d3500000 (64-bit, non-prefetchable) [size=64K]
Region 4: Memory at d3510000 (64-bit, non-prefetchable) [size=16K]
Expansion ROM at d3520000 [disabled] [size=64K]
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 Network controller [0280]: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter [168c:0042] (rev 31)
Subsystem: Dell QCA9377 802.11ac Wireless Network Adapter [1028:1810]
Latency: 0
Interrupt: pin A routed to IRQ 150
IOMMU group: 13
Region 0: Memory at d3200000 (64-bit, non-prefetchable) [size=2M]
Kernel driver in use: ath10k_pci
Kernel modules: ath10k_pci, wl
05:00.0 Non-Volatile memory controller [0108]: Solid State Storage Technology Corporation Device [1e95:9100] (rev 03) (prog-if 02 [NVM Express])
Subsystem: Silicon Motion, Inc. Device [126f:2263]
Latency: 0
IOMMU group: 14
Region 0: Memory at d3400000 (64-bit, non-prefetchable) [size=16K]
First, I enabled VT-d and VT-x in the UEFI Firmware Settings, and added rd.driver.pre=vfio-pci intel_iommu=on to my grub switches. I am confident this works because I can spin up VMs and there are IOMMU groups visible in the above lspci output. I added kernel configuration file:
$ cat /etc/modprobe.d/vfio.conf
# create new : for [ids=***], specify [Vendor-ID : Device-ID]
#wifi,ethernet,gpu
options vfio-pci ids=1028:1810,103c:802e,10de:11bc
#options vfio-pci ids=168c:0042,8086:15b7,10de:1cb1
softdep nvidia pre: vfio-pci
options nvidia-drm modeset=1
Just in case, I ran sudo update-initramfs -u -k all; sudo update-grub, and rebooted. There were reboots all over this process. No matter what I do, though, I can’t get vfio-pci take any of the cards. There is a commented-out line where I tried other IDs. Commenting out the last two lines seems not to have any effect on the kernel drivers used, except that I get no GUI without the final line. I’ve also tried using vfio_pci instead of vfio-pci in the vfio.conf. The only other clue I can think of is dmesg:
$ sudo dmesg | grep vfio
[ 0.000000] Command line: BOOT_IMAGE=/BOOT-VOL/misty-mx-bootfs@/vmlinuz-6.3.9-1-liquorix-amd64 root=ZFS=/ROOT-VOL/misty-mx-rootfs ro root=ZFS=misty-mx-root-pool/ROOT-VOL/misty-mx-rootfs quiet splash rd.driver.pre=vfio-pci intel_iommu=on init=/lib/systemd/systemd
[ 0.015725] Kernel command line: audit=0 intel_pstate=disable hpet=disable rcupdate.rcu_expedited=1 BOOT_IMAGE=/BOOT-VOL/misty-mx-bootfs@/vmlinuz-6.3.9-1-liquorix-amd64 root=ZFS=/ROOT-VOL/misty-mx-rootfs ro root=ZFS=misty-mx-root-pool/ROOT-VOL/misty-mx-rootfs quiet splash rd.driver.pre=vfio-pci intel_iommu=on init=/lib/systemd/systemd
[ 4.153782] vfio_pci: add [1028:1810[ffffffff:ffffffff]] class 0x000000/00000000
[ 4.153788] vfio_pci: add [103c:802e[ffffffff:ffffffff]] class 0x000000/00000000
[ 4.153793] vfio_pci: add [10de:11bc[ffffffff:ffffffff]] class 0x000000/00000000
I would like to avoid hacky solutions, like posts I’ve seen with scripts that run after boot to unbind and re-bind the drivers. The least of these evils I’ve seen is in this reddit post. It just seems wonky to install another package to sort out the order of loading drivers/modules.
I appreciate any input you may have, and help, doubly.
Much obliged,
UpsetMOSFET
