I am currently using a snap lxd 3.0 stable channel. I am not able to view the rootfs of the running container. My usecase is to access some custom log files present inside the rootfs.
It currently seems to located in /var/snap/lxd/common/lxd/containers/. The doesn’t seem to be a directory nor a file. This seems to be due to snap lxd intentionally hiding it’s mount space as mentioned in Rootfs mount locations on the host with snap lxd
Is there anything i can do to disable snap lxd intentionally hiding it’s mount space or any alternatives to access the data inside it?
