hi, i am running a lxd 5.17 on a Hyper-V Ubuntu VM for development purposes,
i enabled nested virtualization on hyper-v and i can create VM with lxd,
but with a windows server 2012 , if i set the cpu.limits to more then “1”, vm crash with the following error , after the “getting ready” screen of windows, it happens every time i install the windows,it works fine with limits.cpu=1,
my cpu is intel i7-9750H
vt-d is enabled
kvm also says virtulization is enabled inside the Ubuntu Machine
microcode.ctl and intel-microcode is installed
$ lxc info win2k12 --show-log
KVM: entry failed, hardware error 0x80000021
If you're running a guest on an Intel machine without unrestricted mode
support, the failure can be most likely due to the guest entering an invalid
state for Intel VT. For example, the guest maybe running in big real mode
which is not supported on less recent Intel processors.
EAX=ffffffff EBX=f3afe880 ECX=00979194 EDX=296e787d
ESI=f6f2d080 EDI=42d73180 EBP=fa9f5f1d ESP=ddd4c900
EIP=00008000 EFL=00000002 [-------] CPL=0 II=0 A20=1 SMM=1 HLT=0
ES =0000 00000000 ffffffff 00809300
CS =ba00 7ffba000 ffffffff 00809300
SS =0000 00000000 ffffffff 00809300
DS =0000 00000000 ffffffff 00809300
FS =0000 00000000 ffffffff 00809300
GS =0000 00000000 ffffffff 00809300
LDT=0000 00000000 ffffffff 00c00000
TR =0040 46b8a080 00000067 00008b00
GDT= 46b89000 0000007f
IDT= 00000000 00000000
CR0=00050032 CR2=407ec010 CR3=001b9000 CR4=00000000
DR0=0000000000000000 DR1=0000000000000000 DR2=0000000000000000 DR3=0000000000000000
DR6=00000000ffff0ff0 DR7=0000000000000400
EFER=0000000000000000
Code=qemu-system-x86_64: ../hw/core/cpu-sysemu.c:76: cpu_asidx_from_attrs: Assertion `ret < cpu->num_ases && ret >= 0' failed.
dmesg:
rooot@lxd0:~$ dmesg
[ 0.000000] Linux version 5.4.0-162-generic (buildd@lcy02-amd64-069) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #179-Ubuntu SMP Mon Aug 14 08:51:31 UTC 2023 (Ubuntu 5.4.0-162.179-generic 5.4.246)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-162-generic root=UUID=20207418-5f32-4b49-ad60-b25e0ddf251b ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000f7feffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000f7ff0000-0x00000000f7ffefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000f7fff000-0x00000000f7ffffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001fbffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Microsoft Corporation Virtual Machine/Virtual Machine, BIOS 090008 12/07/2018
[ 0.000000] Hypervisor detected: Microsoft Hyper-V
[ 0.000000] Hyper-V: features 0x2e7f, hints 0x24c2c, misc 0xbed7b2
[ 0.000000] Hyper-V Host Build:19041-10.0-2-0.2846
[ 0.000000] Hyper-V: LAPIC Timer Frequency: 0xc3500
[ 0.000000] tsc: Marking TSC unstable due to running on Hyper-V
[ 0.000000] Hyper-V: Using hypercall for remote TLB flush
[ 0.000000] clocksource: hyperv_clocksource_tsc_page: mask: 0xffffffffffffffff max_cycles: 0x24e6a1710, max_idle_ns: 440795202120 ns
[ 0.000002] tsc: Detected 2592.008 MHz processor
[ 0.001543] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001545] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001549] last_pfn = 0x1fc000 max_arch_pfn = 0x400000000
[ 0.001572] MTRR default type: uncachable
[ 0.001573] MTRR fixed ranges enabled:
[ 0.001574] 00000-9FFFF write-back
[ 0.001575] A0000-DFFFF uncachable
[ 0.001575] E0000-FFFFF write-back
[ 0.001576] MTRR variable ranges enabled:
[ 0.001577] 0 base 0000000000 mask 7F00000000 write-back
[ 0.001578] 1 base 0100000000 mask 7000000000 write-back
[ 0.001579] 2 disabled
[ 0.001579] 3 disabled
[ 0.001580] 4 disabled
[ 0.001580] 5 disabled
[ 0.001580] 6 disabled
[ 0.001581] 7 disabled
[ 0.001589] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001609] last_pfn = 0xf7ff0 max_arch_pfn = 0x400000000
[ 0.010398] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.010476] check: Scanning 1 areas for low memory corruption
[ 0.010557] Using GB pages for direct mapping
[ 0.010677] RAMDISK: [mem 0x30c4d000-0x3461dfff]
[ 0.010682] ACPI: Early table checksum verification disabled
[ 0.010686] ACPI: RSDP 0x00000000000F5C00 000014 (v00 ACPIAM)
[ 0.010689] ACPI: RSDT 0x00000000F7FF0000 000040 (v01 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010695] ACPI: FACP 0x00000000F7FF0200 000081 (v02 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010699] ACPI: DSDT 0x00000000F7FF1D24 003CD5 (v01 MSFTVM MSFTVM02 00000002 INTL 02002026)
[ 0.010703] ACPI: FACS 0x00000000F7FFF000 000040
[ 0.010705] ACPI: WAET 0x00000000F7FF1A80 000028 (v01 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010708] ACPI: SLIC 0x00000000F7FF1AC0 000176 (v01 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010711] ACPI: OEM0 0x00000000F7FF1CC0 000064 (v01 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010714] ACPI: SRAT 0x00000000F7FF0800 000150 (v02 VRTUAL MICROSFT 00000001 MSFT 00000001)
[ 0.010716] ACPI: APIC 0x00000000F7FF0300 000092 (v01 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010719] ACPI: OEMB 0x00000000F7FFF040 000064 (v01 VRTUAL MICROSFT 12001807 MSFT 00000097)
[ 0.010722] ACPI: Reserving FACP table memory at [mem 0xf7ff0200-0xf7ff0280]
[ 0.010723] ACPI: Reserving DSDT table memory at [mem 0xf7ff1d24-0xf7ff59f8]
[ 0.010723] ACPI: Reserving FACS table memory at [mem 0xf7fff000-0xf7fff03f]
[ 0.010724] ACPI: Reserving WAET table memory at [mem 0xf7ff1a80-0xf7ff1aa7]
[ 0.010725] ACPI: Reserving SLIC table memory at [mem 0xf7ff1ac0-0xf7ff1c35]
[ 0.010725] ACPI: Reserving OEM0 table memory at [mem 0xf7ff1cc0-0xf7ff1d23]
[ 0.010726] ACPI: Reserving SRAT table memory at [mem 0xf7ff0800-0xf7ff094f]
[ 0.010727] ACPI: Reserving APIC table memory at [mem 0xf7ff0300-0xf7ff0391]
[ 0.010727] ACPI: Reserving OEMB table memory at [mem 0xf7fff040-0xf7fff0a3]
[ 0.010797] ACPI: Local APIC address 0xfee00000
[ 0.010856] SRAT: PXM 0 -> APIC 0x00 -> Node 0
[ 0.010857] SRAT: PXM 0 -> APIC 0x01 -> Node 0
[ 0.010858] SRAT: PXM 0 -> APIC 0x02 -> Node 0
[ 0.010858] SRAT: PXM 0 -> APIC 0x03 -> Node 0
[ 0.010859] SRAT: PXM 0 -> APIC 0x04 -> Node 0
[ 0.010859] SRAT: PXM 0 -> APIC 0x05 -> Node 0
[ 0.010860] SRAT: PXM 0 -> APIC 0x06 -> Node 0
[ 0.010860] SRAT: PXM 0 -> APIC 0x07 -> Node 0
[ 0.010863] ACPI: SRAT: Node 0 PXM 0 [mem 0x00000000-0xf7ffffff] hotplug
[ 0.010864] ACPI: SRAT: Node 0 PXM 0 [mem 0x100000000-0x1fbffffff] hotplug
[ 0.010865] ACPI: SRAT: Node 0 PXM 0 [mem 0x1fc000000-0xfdfffffff] hotplug
[ 0.010866] ACPI: SRAT: Node 0 PXM 0 [mem 0x1000000000-0xffffffffff] hotplug
[ 0.010868] NUMA: Node 0 [mem 0x00000000-0xf7ffffff] + [mem 0x100000000-0x1fbffffff] -> [mem 0x00000000-0x1fbffffff]
[ 0.010876] NODE_DATA(0) allocated [mem 0x1fbfd5000-0x1fbffffff]
[ 0.011052] Zone ranges:
[ 0.011053] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.011054] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.011055] Normal [mem 0x0000000100000000-0x00000001fbffffff]
[ 0.011056] Device empty
[ 0.011057] Movable zone start for each node
[ 0.011060] Early memory node ranges
[ 0.011060] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.011061] node 0: [mem 0x0000000000100000-0x00000000f7feffff]
[ 0.011062] node 0: [mem 0x0000000100000000-0x00000001fbffffff]
[ 0.011168] Zeroed struct page in unavailable ranges: 16498 pages
[ 0.011169] Initmem setup node 0 [mem 0x0000000000001000-0x00000001fbffffff]
[ 0.011170] On node 0 totalpages: 2047886
[ 0.011171] DMA zone: 64 pages used for memmap
[ 0.011172] DMA zone: 21 pages reserved
[ 0.011173] DMA zone: 3998 pages, LIFO batch:0
[ 0.011211] DMA32 zone: 16320 pages used for memmap
[ 0.011212] DMA32 zone: 1011696 pages, LIFO batch:63
[ 0.020508] Normal zone: 16128 pages used for memmap
[ 0.020509] Normal zone: 1032192 pages, LIFO batch:63
[ 0.032228] ACPI: PM-Timer IO Port: 0x408
[ 0.032230] ACPI: Local APIC address 0xfee00000
[ 0.032237] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
[ 0.032565] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
[ 0.032569] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.032570] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.032572] ACPI: IRQ0 used by override.
[ 0.032572] ACPI: IRQ9 used by override.
[ 0.032574] Using ACPI (MADT) for SMP configuration information
[ 0.032580] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ 0.032589] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.032590] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.032591] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.032591] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.032592] PM: Registered nosave memory: [mem 0xf7ff0000-0xf7ffefff]
[ 0.032593] PM: Registered nosave memory: [mem 0xf7fff000-0xf7ffffff]
[ 0.032593] PM: Registered nosave memory: [mem 0xf8000000-0xffffffff]
[ 0.032595] [mem 0xf8000000-0xffffffff] available for PCI devices
[ 0.032595] Booting paravirtualized kernel on Hyper-V
[ 0.032598] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.032602] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.032780] percpu: Embedded 60 pages/cpu s208896 r8192 d28672 u262144
[ 0.032785] pcpu-alloc: s208896 r8192 d28672 u262144 alloc=1*2097152
[ 0.032786] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ 0.032802] Hyper-V: PV spinlocks enabled
[ 0.032805] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.032808] Built 1 zonelists, mobility grouping on. Total pages: 2015353
[ 0.032808] Policy zone: Normal
[ 0.032810] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4.0-162-generic root=UUID=20207418-5f32-4b49-ad60-b25e0ddf251b ro quiet splash vt.handoff=7
[ 0.033280] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.033482] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.033571] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.037050] Calgary: detecting Calgary via BIOS EBDA area
[ 0.037052] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.052484] Memory: 7873664K/8191544K available (14339K kernel code, 2394K rwdata, 9280K rodata, 2764K init, 17232K bss, 317880K reserved, 0K cma-reserved)
[ 0.052749] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.052765] Kernel/User page tables isolation: enabled
[ 0.052812] ftrace: allocating 44701 entries in 175 pages
[ 0.070254] rcu: Hierarchical RCU implementation.
[ 0.070256] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[ 0.070257] Tasks RCU enabled.
[ 0.070258] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.070258] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.073135] NR_IRQS: 524544, nr_irqs: 488, preallocated irqs: 16
[ 0.074057] random: crng init done
[ 0.074076] vt handoff: transparent VT on vt#7
[ 0.074083] Console: colour dummy device 80x25
[ 0.074086] printk: console [tty0] enabled
[ 0.074103] ACPI: Core revision 20190816
[ 0.074283] APIC: Switch to symmetric I/O mode setup
[ 0.074448] Hyper-V: Using IPI hypercalls
[ 0.074449] Hyper-V: Using enlightened APIC (xapic mode)
[ 0.087631] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.087964] Calibrating delay loop (skipped), value calculated using timer frequency.. 5184.01 BogoMIPS (lpj=10368032)
[ 0.088116] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.088117] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.088121] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.088123] Spectre V2 : Mitigation: IBRS
[ 0.088123] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.088124] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.088125] RETBleed: Mitigation: IBRS
[ 0.088126] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.088127] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.088128] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.088135] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.088136] MMIO Stale Data: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.088138] SRBDS: Unknown: Dependent on hypervisor status
[ 0.088139] GDS: Unknown: Dependent on hypervisor status
[ 0.088153] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.088154] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.088155] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.088161] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.088162] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[ 0.088478] Freeing SMP alternatives memory: 40K
[ 0.090363] pid_max: default: 32768 minimum: 301
[ 0.090401] LSM: Security Framework initializing
[ 0.090414] Yama: becoming mindful.
[ 0.090441] AppArmor: AppArmor initialized
[ 0.090484] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.090493] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.090505] *** VALIDATE tmpfs ***
[ 0.090651] *** VALIDATE proc ***
[ 0.090700] *** VALIDATE cgroup1 ***
[ 0.090701] *** VALIDATE cgroup2 ***
[ 0.090974] smpboot: CPU0: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz (family: 0x6, model: 0x9e, stepping: 0xa)
[ 0.091073] Performance Events: unsupported p6 CPU model 158 no PMU driver, software events only.
[ 0.091103] rcu: Hierarchical SRCU implementation.
[ 0.091687] NMI watchdog: Perf NMI watchdog permanently disabled
[ 0.091772] smp: Bringing up secondary CPUs ...
[ 0.091893] x86: Booting SMP configuration:
[ 0.091893] .... node #0, CPUs: #1
[ 0.091961] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.091961] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.091961] #2 #3 #4 #5 #6 #7
[ 0.096133] smp: Brought up 1 node, 8 CPUs
[ 0.096134] smpboot: Max logical packages: 1
[ 0.096136] smpboot: Total of 8 processors activated (41472.12 BogoMIPS)
[ 0.096503] devtmpfs: initialized
[ 0.096503] x86/mm: Memory block size: 128MB
[ 0.096961] PM: Registering ACPI NVS region [mem 0xf7fff000-0xf7ffffff] (4096 bytes)
[ 0.096961] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.096961] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.096961] pinctrl core: initialized pinctrl subsystem
[ 0.096961] PM: RTC time: 21:28:46, date: 2023-09-15
[ 0.099976] NET: Registered protocol family 16
[ 0.100084] audit: initializing netlink subsys (disabled)
[ 0.100113] audit: type=2000 audit(1694813326.020:1): state=initialized audit_enabled=0 res=1
[ 0.100115] EISA bus registered
[ 0.100123] cpuidle: using governor ladder
[ 0.100126] cpuidle: using governor menu
[ 0.100178] ACPI: bus type PCI registered
[ 0.100179] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.100655] PCI: Using configuration type 1 for base access
[ 0.104039] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.104039] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.116071] ACPI: Added _OSI(Module Device)
[ 0.116072] ACPI: Added _OSI(Processor Device)
[ 0.116073] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.116074] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.116075] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.116076] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.116077] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.120105] ACPI: 1 ACPI AML tables successfully acquired and loaded
[ 0.123625] ACPI: Interpreter enabled
[ 0.123636] ACPI: (supports S0 S5)
[ 0.123637] ACPI: Using IOAPIC for interrupt routing
[ 0.123664] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.124049] ACPI: Enabled 1 GPEs in block 00 to 0F
[ 0.153063] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.153068] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI HPX-Type3]
[ 0.153081] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[ 0.153271] PCI host bridge to bus 0000:00
[ 0.153274] pci_bus 0000:00: root bus resource [mem 0xfe0000000-0xfffffffff window]
[ 0.153275] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.153276] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.153278] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.153279] pci_bus 0000:00: root bus resource [mem 0xf8000000-0xfffbffff window]
[ 0.153280] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.153567] pci 0000:00:00.0: [8086:7192] type 00 class 0x060000
[ 0.157753] pci 0000:00:07.0: [8086:7110] type 00 class 0x060100
[ 0.161725] pci 0000:00:07.1: [8086:7111] type 00 class 0x010180
[ 0.164800] pci 0000:00:07.1: reg 0x20: [io 0xffa0-0xffaf]
[ 0.165952] pci 0000:00:07.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.165953] pci 0000:00:07.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.165954] pci 0000:00:07.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.165955] pci 0000:00:07.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.166774] pci 0000:00:07.3: [8086:7113] type 00 class 0x068000
[ 0.166830] * Found PM-Timer Bug on the chipset. Due to workarounds for a bug,
* this clock source is slow. Consider trying other clock sources
[ 0.170163] pci 0000:00:07.3: quirk: [io 0x0400-0x043f] claimed by PIIX4 ACPI
[ 0.171650] pci 0000:00:08.0: [1414:5353] type 00 class 0x030000
[ 0.172970] pci 0000:00:08.0: reg 0x10: [mem 0xf8000000-0xfbffffff]
[ 0.203563] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12 14 15)
[ 0.203898] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.204255] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.204690] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.205029] iommu: Default domain type: Translated
[ 0.205029] SCSI subsystem initialized
[ 0.205029] libata version 3.00 loaded.
[ 0.205029] pci 0000:00:08.0: vgaarb: setting as boot VGA device
[ 0.205029] pci 0000:00:08.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.205029] pci 0000:00:08.0: vgaarb: bridge control possible
[ 0.205029] vgaarb: loaded
[ 0.205029] ACPI: bus type USB registered
[ 0.205029] usbcore: registered new interface driver usbfs
[ 0.205029] usbcore: registered new interface driver hub
[ 0.205029] usbcore: registered new device driver usb
[ 0.205029] pps_core: LinuxPPS API ver. 1 registered
[ 0.205029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.205029] PTP clock support registered
[ 0.205029] EDAC MC: Ver: 3.0.0
[ 0.205029] PCI: Using ACPI for IRQ routing
[ 0.205029] PCI: pci_cache_line_size set to 64 bytes
[ 0.205029] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.205029] e820: reserve RAM buffer [mem 0xf7ff0000-0xf7ffffff]
[ 0.205029] NetLabel: Initializing
[ 0.205029] NetLabel: domain hash size = 128
[ 0.205029] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.205029] NetLabel: unlabeled traffic allowed by default
[ 0.209476] clocksource: Switched to clocksource hyperv_clocksource_tsc_page
[ 0.221086] *** VALIDATE bpf ***
[ 0.221147] VFS: Disk quotas dquot_6.6.0
[ 0.221162] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.221183] *** VALIDATE ramfs ***
[ 0.221186] *** VALIDATE hugetlbfs ***
[ 0.221272] AppArmor: AppArmor Filesystem Enabled
[ 0.221295] pnp: PnP ACPI init
[ 0.221387] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.221456] pnp 00:01: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.221524] pnp 00:02: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.222534] pnp 00:03: [dma 0 disabled]
[ 0.222565] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.223543] pnp 00:04: [dma 0 disabled]
[ 0.223575] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.224671] pnp 00:05: [dma 2]
[ 0.224712] pnp 00:05: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.224760] system 00:06: [io 0x01e0-0x01ef] has been reserved
[ 0.224762] system 00:06: [io 0x0160-0x016f] has been reserved
[ 0.224763] system 00:06: [io 0x0278-0x027f] has been reserved
[ 0.224766] system 00:06: [io 0x0378-0x037f] has been reserved
[ 0.224767] system 00:06: [io 0x0678-0x067f] has been reserved
[ 0.224769] system 00:06: [io 0x0778-0x077f] has been reserved
[ 0.224770] system 00:06: [io 0x04d0-0x04d1] has been reserved
[ 0.224774] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225004] system 00:07: [io 0x0400-0x043f] has been reserved
[ 0.225006] system 00:07: [io 0x0370-0x0371] has been reserved
[ 0.225007] system 00:07: [io 0x0440-0x044f] has been reserved
[ 0.225010] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.225011] system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.225015] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.225209] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.225211] system 00:08: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.225212] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.225228] system 00:08: [mem 0x00100000-0xf7ffffff] could not be reserved
[ 0.225230] system 00:08: [mem 0xfffc0000-0xffffffff] has been reserved
[ 0.225235] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.225606] pnp: PnP ACPI: found 9 devices
[ 0.235185] thermal_sys: Registered thermal governor 'fair_share'
[ 0.235186] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.235187] thermal_sys: Registered thermal governor 'step_wise'
[ 0.235188] thermal_sys: Registered thermal governor 'user_space'
[ 0.235189] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.239728] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.239769] pci_bus 0000:00: resource 4 [mem 0xfe0000000-0xfffffffff window]
[ 0.239770] pci_bus 0000:00: resource 5 [io 0x0000-0x0cf7 window]
[ 0.239772] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff window]
[ 0.239773] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff window]
[ 0.239774] pci_bus 0000:00: resource 8 [mem 0xf8000000-0xfffbffff window]
[ 0.239837] NET: Registered protocol family 2
[ 0.239920] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.241099] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.241159] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.241313] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.241407] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.241447] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.241469] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.241519] NET: Registered protocol family 1
[ 0.241524] NET: Registered protocol family 44
[ 0.241528] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 0.241947] pci 0000:00:08.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.242002] PCI: CLS 0 bytes, default 64
[ 0.242047] Trying to unpack rootfs image as initramfs...
[ 0.393547] Freeing initrd memory: 59204K
[ 0.393582] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.393583] software IO TLB: mapped [mem 0xf3ff0000-0xf7ff0000] (64MB)
[ 0.393798] check: Scanning for low memory corruption every 60 seconds
[ 0.394811] Initialise system trusted keyrings
[ 0.394819] Key type blacklist registered
[ 0.395121] workingset: timestamp_bits=36 max_order=21 bucket_order=0
[ 0.396838] zbud: loaded
[ 0.397392] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.397937] fuse: init (API version 7.31)
[ 0.397961] *** VALIDATE fuse ***
[ 0.397963] *** VALIDATE fuse ***
[ 0.398228] Platform Keyring initialized
[ 0.401867] Key type asymmetric registered
[ 0.401869] Asymmetric key parser 'x509' registered
[ 0.401880] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.402153] io scheduler mq-deadline registered
[ 0.403339] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.403410] vesafb: mode is 800x600x32, linelength=3200, pages=0
[ 0.403411] vesafb: scrolling: redraw
[ 0.403412] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.403424] vesafb: framebuffer at 0xf8000000, mapped to 0x000000007fd8e913, using 1920k, total 1920k
[ 0.403610] fbcon: Deferring console take-over
[ 0.403611] fb0: VESA VGA frame buffer device
[ 0.403625] intel_idle: Please enable MWAIT in BIOS SETUP
[ 0.403756] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 0.403794] ACPI: Power Button [PWRF]
[ 0.404793] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.435064] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.465403] 00:04: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[ 0.471293] Linux agpgart interface v0.103
[ 0.606031] loop: module loaded
[ 0.606319] ata_piix 0000:00:07.1: version 2.13
[ 0.606643] ata_piix 0000:00:07.1: Hyper-V Virtual Machine detected, ATA device ignore set
[ 0.609637] scsi host0: ata_piix
[ 0.610144] scsi host1: ata_piix
[ 0.610187] ata1: PATA max UDMA/33 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 0.610188] ata2: PATA max UDMA/33 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 0.610375] tun: Universal TUN/TAP device driver, 1.6
[ 0.610514] PPP generic driver version 2.4.2
[ 0.610878] VFIO - User Level meta-driver version: 0.3
[ 0.611129] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.611140] ehci-pci: EHCI PCI platform driver
[ 0.611150] ehci-platform: EHCI generic platform driver
[ 0.611157] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.611159] ohci-pci: OHCI PCI platform driver
[ 0.611165] ohci-platform: OHCI generic platform driver
[ 0.611171] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.611248] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.615273] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.615279] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.615587] mousedev: PS/2 mouse device common for all mice
[ 0.616114] rtc_cmos 00:00: RTC can wake from S4
[ 0.618521] rtc_cmos 00:00: registered as rtc0
[ 0.618540] rtc_cmos 00:00: alarms up to one month, 114 bytes nvram
[ 0.618548] i2c /dev entries driver
[ 0.618595] device-mapper: uevent: version 1.0.3
[ 0.618802] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[ 0.618826] platform eisa.0: Probing EISA bus 0
[ 0.618827] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 0.618829] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 0.618830] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 0.618831] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 0.618832] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 0.618833] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 0.618834] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 0.618835] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 0.618836] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 0.618837] platform eisa.0: EISA: Detected 0 cards
[ 0.618840] intel_pstate: CPU model not supported
[ 0.619821] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.619929] drop_monitor: Initializing network drop monitor service
[ 0.620113] NET: Registered protocol family 10
[ 0.623352] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 0.629691] Segment Routing with IPv6
[ 0.629718] NET: Registered protocol family 17
[ 0.629861] Key type dns_resolver registered
[ 0.630903] RAS: Correctable Errors collector initialized.
[ 0.630909] IPI shorthand broadcast: enabled
[ 0.631028] registered taskstats version 1
[ 0.631036] Loading compiled-in X.509 certificates
[ 0.631992] Loaded X.509 cert 'Build time autogenerated kernel key: 09459b98d5765ada5ec703713cd00df8d920d79d'
[ 0.632631] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
[ 0.633208] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
[ 0.633209] blacklist: Loading compiled-in revocation X.509 certificates
[ 0.633227] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[ 0.633241] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
[ 0.633255] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
[ 0.633269] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
[ 0.633283] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
[ 0.633297] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
[ 0.633331] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
[ 0.633353] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
[ 0.633389] zswap: loaded using pool lzo/zbud
[ 0.633957] Key type ._fscrypt registered
[ 0.633958] Key type .fscrypt registered
[ 0.643312] Key type big_key registered
[ 0.647854] Key type encrypted registered
[ 0.647857] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.647866] ima: No TPM chip found, activating TPM-bypass!
[ 0.647870] ima: Allocated hash algorithm: sha1
[ 0.647875] ima: No architecture policies found
[ 0.647882] evm: Initialising EVM extended attributes:
[ 0.647882] evm: security.selinux
[ 0.647883] evm: security.SMACK64
[ 0.647883] evm: security.SMACK64EXEC
[ 0.647884] evm: security.SMACK64TRANSMUTE
[ 0.647884] evm: security.SMACK64MMAP
[ 0.647885] evm: security.apparmor
[ 0.647885] evm: security.ima
[ 0.647886] evm: security.capability
[ 0.647887] evm: HMAC attrs: 0x1
[ 0.648128] PM: Magic number: 7:301:500
[ 0.648771] rtc_cmos 00:00: setting system clock to 2023-09-15T21:28:46 UTC (1694813326)
[ 0.649180] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 1.130065] ata1.01: NODEV after polling detection
[ 1.248978] ata2.01: NODEV after polling detection
[ 1.325992] ata1.00: host indicates ignore ATA devices, ignored
[ 1.326718] ata2.00: ATAPI: Virtual CD, , max MWDMA2
[ 1.331133] scsi 1:0:0:0: CD-ROM Msft Virtual CD/ROM 1.0 PQ: 0 ANSI: 5
[ 1.364841] sr 1:0:0:0: [sr0] scsi3-mmc drive: 0x/0x tray
[ 1.364843] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.378258] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.378509] sr 1:0:0:0: Attached scsi generic sg0 type 5
[ 1.380078] Freeing unused decrypted memory: 2040K
[ 1.380805] Freeing unused kernel image memory: 2764K
[ 1.394074] Write protecting the kernel read-only data: 26624k
[ 1.395303] Freeing unused kernel image memory: 2036K
[ 1.395935] Freeing unused kernel image memory: 960K
[ 1.409809] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.409811] x86/mm: Checking user space page tables
[ 1.424241] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.424244] Run /init as init process
[ 1.534384] Floppy drive(s): fd0 is 1.44M
[ 1.538061] piix4_smbus 0000:00:07.3: SMBus base address uninitialized - upgrade BIOS or use force_addr=0xaddr
[ 1.541244] hv_vmbus: Vmbus version:5.0
[ 1.557359] FDC 0 is an 82078.
[ 1.602892] hv_utils: Registering HyperV Utility Driver
[ 1.602893] hv_vmbus: registering driver hv_utils
[ 1.603913] hv_vmbus: registering driver hyperv_keyboard
[ 1.604336] hv_utils: Heartbeat IC version 3.0
[ 1.604375] hv_utils: Shutdown IC version 3.0
[ 1.604530] hv_utils: TimeSync IC version 4.0
[ 1.604563] hv_utils: VSS IC version 5.0
[ 1.605019] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.605109] hv_vmbus: registering driver hv_netvsc
[ 1.606436] hv_vmbus: registering driver hid_hyperv
[ 1.606941] hv_vmbus: registering driver hv_storvsc
[ 1.607076] input: Microsoft Vmbus HID-compliant Mouse as /devices/0006:045E:0621.0001/input/input4
[ 1.607363] hid 0006:045E:0621.0001: input: VIRTUAL HID v0.01 Mouse [Microsoft Vmbus HID-compliant Mouse] on
[ 1.609294] scsi host3: storvsc_host_t
[ 1.610067] scsi host2: storvsc_host_t
[ 1.613686] scsi 2:0:0:0: Direct-Access Msft Virtual Disk 1.0 PQ: 0 ANSI: 5
[ 1.614209] sd 2:0:0:0: Attached scsi generic sg1 type 0
[ 1.615352] sd 2:0:0:0: [sda] 266338304 512-byte logical blocks: (136 GB/127 GiB)
[ 1.615354] sd 2:0:0:0: [sda] 4096-byte physical blocks
[ 1.615606] sd 2:0:0:0: [sda] Write Protect is off
[ 1.615609] sd 2:0:0:0: [sda] Mode Sense: 0f 00 00 00
[ 1.615889] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.646868] sda: sda1
[ 1.671819] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.974099] psmouse serio1: trackpoint: failed to get extended button data, assuming 3 buttons
[ 2.314000] raid6: avx2x4 gen() 24784 MB/s
[ 2.361998] raid6: avx2x4 xor() 15809 MB/s
[ 2.409966] raid6: avx2x2 gen() 21512 MB/s
[ 2.457998] raid6: avx2x2 xor() 13435 MB/s
[ 2.506017] raid6: avx2x1 gen() 17614 MB/s
[ 2.553968] raid6: avx2x1 xor() 12165 MB/s
[ 2.601996] raid6: sse2x4 gen() 9634 MB/s
[ 2.650012] raid6: sse2x4 xor() 6688 MB/s
[ 2.698000] raid6: sse2x2 gen() 8904 MB/s
[ 2.746001] raid6: sse2x2 xor() 6035 MB/s
[ 2.794013] raid6: sse2x1 gen() 7710 MB/s
[ 2.841983] raid6: sse2x1 xor() 4666 MB/s
[ 2.841984] raid6: using algorithm avx2x4 gen() 24784 MB/s
[ 2.841984] raid6: .... xor() 15809 MB/s, rmw enabled
[ 2.841986] raid6: using avx2x2 recovery algorithm
[ 2.843703] xor: measuring software checksum speed
[ 2.882011] prefetch64-sse: 14982.000 MB/sec
[ 2.922022] generic_sse: 14754.000 MB/sec
[ 2.922023] xor: using function: prefetch64-sse (14982.000 MB/sec)
[ 2.923759] async_tx: api initialized (async)
[ 2.972743] Btrfs loaded, crc32c=crc32c-intel
[ 3.162159] blk_update_request: I/O error, dev fd0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 3.162163] floppy: error 10 while reading block 0
[ 3.854748] fbcon: Taking over console
[ 3.854827] Console: switching to colour frame buffer device 100x37
[ 6.106004] psmouse serio1: trackpoint: IBM TrackPoint firmware: 0x01, buttons: 3/3
[ 6.108029] input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio1/input/input3
[ 6.108868] input: AT Translated Set 2 keyboard as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:07/VMBUS:01/d34b2567-b9b6-42b9-8778-0a4ec0b955bf/serio2/input/input5
[ 6.414304] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.298563] systemd[1]: Inserted module 'autofs4'
[ 9.458175] systemd[1]: systemd 245.4-4ubuntu3.22 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 9.458262] systemd[1]: Detected virtualization microsoft.
[ 9.458267] systemd[1]: Detected architecture x86-64.
[ 9.509654] systemd[1]: Set hostname to <lxd0>.
[ 13.755155] systemd[1]: Created slice system-modprobe.slice.
[ 13.755505] systemd[1]: Created slice User and Session Slice.
[ 13.755579] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.755899] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.755933] systemd[1]: Reached target User and Group Name Lookups.
[ 13.755943] systemd[1]: Reached target Remote File Systems.
[ 13.755953] systemd[1]: Reached target Slices.
[ 13.755964] systemd[1]: Reached target Mounting snaps.
[ 13.756047] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 13.756139] systemd[1]: Listening on LVM2 poll daemon socket.
[ 13.756241] systemd[1]: Listening on Syslog Socket.
[ 13.756320] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.756372] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.756570] systemd[1]: Listening on Journal Audit Socket.
[ 13.756653] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.756757] systemd[1]: Listening on Journal Socket.
[ 13.756970] systemd[1]: Listening on udev Control Socket.
[ 13.757036] systemd[1]: Listening on udev Kernel Socket.
[ 13.758164] systemd[1]: Mounting Huge Pages File System...
[ 13.759517] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.760941] systemd[1]: Mounting Kernel Debug File System...
[ 13.762329] systemd[1]: Mounting Kernel Trace File System...
[ 13.765390] systemd[1]: Starting Journal Service...
[ 13.766698] systemd[1]: Starting Availability of block devices...
[ 13.768205] systemd[1]: Starting Set the console keyboard layout...
[ 13.769704] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 13.771144] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 13.772344] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 13.773478] systemd[1]: Starting Load Kernel Module drm...
[ 13.774972] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 13.776519] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 13.778136] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 13.779656] systemd[1]: Starting Load Kernel Module ramoops...
[ 13.787913] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 13.787970] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 13.888926] systemd[1]: Starting Load Kernel Modules...
[ 13.890118] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 13.891367] systemd[1]: Starting udev Coldplug all Devices...
[ 13.892579] systemd[1]: Starting Uncomplicated firewall...
[ 13.894649] systemd[1]: Mounted Huge Pages File System.
[ 13.894788] systemd[1]: Mounted POSIX Message Queue File System.
[ 13.894957] systemd[1]: Mounted Kernel Debug File System.
[ 13.895079] systemd[1]: Mounted Kernel Trace File System.
[ 13.895747] systemd[1]: Finished Availability of block devices.
[ 13.896512] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 13.899161] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 13.899538] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 13.899917] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 13.900275] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 13.948796] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 13.949210] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 13.952023] systemd[1]: Finished Uncomplicated firewall.
[ 13.963606] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 13.980068] systemd[1]: modprobe@drm.service: Succeeded.
[ 13.980473] systemd[1]: Finished Load Kernel Module drm.
[ 13.993808] systemd[1]: Started Journal Service.
[ 14.033451] lp: driver loaded but no devices found
[ 14.100663] ppdev: user-space parallel port driver
[ 14.458074] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.534064] systemd-journald[337]: Received client request to flush runtime journal.
[ 14.658093] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k FS
[ 16.749610] KVM: vmx: using Hyper-V Enlightened VMCS
[ 17.044372] audit: type=1400 audit(1694813346.378:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=450 comm="apparmor_parser"
[ 17.044375] audit: type=1400 audit(1694813346.378:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=450 comm="apparmor_parser"
[ 17.050985] audit: type=1400 audit(1694813346.386:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=449 comm="apparmor_parser"
[ 17.053142] audit: type=1400 audit(1694813346.386:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=447 comm="apparmor_parser"
[ 17.053145] audit: type=1400 audit(1694813346.386:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=447 comm="apparmor_parser"
[ 17.053147] audit: type=1400 audit(1694813346.386:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=447 comm="apparmor_parser"
[ 17.056969] audit: type=1400 audit(1694813346.390:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=444 comm="apparmor_parser"
[ 17.056973] audit: type=1400 audit(1694813346.390:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=444 comm="apparmor_parser"
[ 17.056975] audit: type=1400 audit(1694813346.390:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=448 comm="apparmor_parser"
[ 17.102618] audit: type=1400 audit(1694813346.438:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=451 comm="apparmor_parser"
[ 17.890064] hv_vmbus: registering driver hv_balloon
[ 17.890410] hv_balloon: Using Dynamic Memory protocol version 2.0
[ 17.892810] hv_vmbus: registering driver hyperv_fb
[ 17.893266] hyperv_fb: Screen resolution: 1152x864, Color depth: 32
[ 17.893691] checking generic (f8000000 1e0000) vs hw (f8000000 4000000)
[ 17.893693] fb0: switching to hyperv_fb from VESA VGA
[ 17.893796] Console: switching to colour dummy device 80x25
[ 17.894053] Console: switching to colour frame buffer device 144x54
[ 18.003777] RAPL PMU: API unit is 2^-32 Joules, 0 fixed counters, 10737418240 ms ovfl timer
[ 18.054555] cryptd: max_cpu_qlen set to 1000
[ 18.073628] AVX2 version of gcm_enc/dec engaged.
[ 18.073629] AES CTR mode by8 optimization enabled
[ 22.284378] kauditd_printk_skb: 51 callbacks suppressed
[ 22.284379] audit: type=1400 audit(1694813351.618:63): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=794 comm="cups-browsed" capability=23 capname="sys_nice"
[ 22.734225] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.758024] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 40.630100] new mount options do not match the existing superblock, will be ignored
[ 42.047639] NET: Registered protocol family 40
[ 44.756708] L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
[ 49.472426] bpfilter: Loaded bpfilter_umh pid 1641
[ 49.472728] Started bpfilter
[ 49.990502] rfkill: input handler disabled
[ 52.987442] spl: loading out-of-tree module taints kernel.
[ 52.996538] znvpair: module license 'CDDL' taints kernel.
[ 52.996540] Disabling lock debugging due to kernel taint
[ 54.846804] ZFS: Loaded module v0.8.3-1ubuntu12.15, ZFS pool version 5000, ZFS filesystem version 5
[ 62.752684] rfkill: input handler enabled
[ 65.974189] hv_balloon: Max. dynamic memory size: 8000 MB
[ 67.188607] rfkill: input handler disabled
[ 90.279611] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 90.462762] audit: type=1400 audit(1694813419.798:64): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd_dnsmasq-lxdbr0_</var/snap/lxd/common/lxd>" pid=4223 comm="apparmor_parser"
[ 118.589193] HTB: quantum of class 10010 is big. Consider r2q change.
[ 118.765635] u32 classifier
[ 118.765636] input device check on
[ 118.765636] Actions configured
[ 118.868670] lxdbr0: port 1(tap439ecfe7) entered blocking state
[ 118.868672] lxdbr0: port 1(tap439ecfe7) entered disabled state
[ 118.868834] device tap439ecfe7 entered promiscuous mode
[ 119.690556] audit: type=1400 audit(1694813449.026:65): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win10_</var/snap/lxd/common/lxd>" pid=4964 comm="apparmor_parser"
[ 120.226412] lxdbr0: port 1(tap439ecfe7) entered blocking state
[ 120.226414] lxdbr0: port 1(tap439ecfe7) entered forwarding state
[ 120.226524] IPv6: ADDRCONF(NETDEV_CHANGE): lxdbr0: link becomes ready
[ 124.714762] lxdbr0: port 2(tap9895bdf0) entered blocking state
[ 124.714764] lxdbr0: port 2(tap9895bdf0) entered disabled state
[ 124.714913] device tap9895bdf0 entered promiscuous mode
[ 126.213883] audit: type=1400 audit(1694813455.546:66): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=5278 comm="apparmor_parser"
[ 126.575103] lxdbr0: port 2(tap9895bdf0) entered blocking state
[ 126.575106] lxdbr0: port 2(tap9895bdf0) entered forwarding state
[ 294.454724] lxdbr0: port 1(tap439ecfe7) entered disabled state
[ 314.178260] device tap439ecfe7 left promiscuous mode
[ 314.178361] lxdbr0: port 1(tap439ecfe7) entered disabled state
[ 316.142808] audit: type=1400 audit(1694813645.478:67): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win10_</var/snap/lxd/common/lxd>" pid=9487 comm="apparmor_parser"
[ 323.819782] HTB: quantum of class 10010 is big. Consider r2q change.
[ 323.848864] lxdbr0: port 1(tapf7123007) entered blocking state
[ 323.848866] lxdbr0: port 1(tapf7123007) entered disabled state
[ 323.849013] device tapf7123007 entered promiscuous mode
[ 325.368781] audit: type=1400 audit(1694813654.702:68): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win10_</var/snap/lxd/common/lxd>" pid=9781 comm="apparmor_parser"
[ 331.377247] lxdbr0: port 1(tapf7123007) entered blocking state
[ 331.377250] lxdbr0: port 1(tapf7123007) entered forwarding state
[ 335.253904] audit: type=1400 audit(1694813664.586:69): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=5339 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 361.514746] lxdbr0: port 2(tap9895bdf0) entered disabled state
[ 362.425762] device tap9895bdf0 left promiscuous mode
[ 362.425865] lxdbr0: port 2(tap9895bdf0) entered disabled state
[ 365.383677] audit: type=1400 audit(1694813694.718:70): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=11001 comm="apparmor_parser"
[ 368.693766] lxdbr0: port 2(tapd971bb8d) entered blocking state
[ 368.693767] lxdbr0: port 2(tapd971bb8d) entered disabled state
[ 368.693891] device tapd971bb8d entered promiscuous mode
[ 369.335683] audit: type=1400 audit(1694813698.670:71): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=11637 comm="apparmor_parser"
[ 369.708988] lxdbr0: port 2(tapd971bb8d) entered blocking state
[ 369.708990] lxdbr0: port 2(tapd971bb8d) entered forwarding state
[ 370.136225] audit: type=1400 audit(1694813699.470:72): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=11647 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 491.727195] audit: type=1400 audit(1694813821.062:73): apparmor="DENIED" operation="open" profile="lxd-win10_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=9907 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 568.850814] lxdbr0: port 1(tapf7123007) entered disabled state
[ 586.216862] device tapf7123007 left promiscuous mode
[ 586.216967] lxdbr0: port 1(tapf7123007) entered disabled state
[ 741.848761] audit: type=1400 audit(1694814071.182:74): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win10_</var/snap/lxd/common/lxd>" pid=44152 comm="apparmor_parser"
[ 898.510607] lxdbr0: port 2(tapd971bb8d) entered disabled state
[ 914.103809] device tapd971bb8d left promiscuous mode
[ 914.103924] lxdbr0: port 2(tapd971bb8d) entered disabled state
[ 941.750533] audit: type=1400 audit(1694814271.086:75): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=54946 comm="apparmor_parser"
[ 951.713516] lxdbr0: port 1(tap5ec754fe) entered blocking state
[ 951.713518] lxdbr0: port 1(tap5ec754fe) entered disabled state
[ 951.713755] device tap5ec754fe entered promiscuous mode
[ 954.589234] audit: type=1400 audit(1694814283.922:76): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=55193 comm="apparmor_parser"
[ 958.848862] lxdbr0: port 1(tap5ec754fe) entered blocking state
[ 958.848864] lxdbr0: port 1(tap5ec754fe) entered forwarding state
[ 985.608482] audit: type=1400 audit(1694814314.942:77): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=55295 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 1016.572144] set kvm_intel.dump_invalid_vmcs=1 to dump internal KVM state.
[ 1050.050906] lxdbr0: port 1(tap5ec754fe) entered disabled state
[ 1060.934238] device tap5ec754fe left promiscuous mode
[ 1060.934245] lxdbr0: port 1(tap5ec754fe) entered disabled state
[ 1063.668511] audit: type=1400 audit(1694814393.002:78): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=64638 comm="apparmor_parser"
[ 1092.205738] lxdbr0: port 1(tapfb3a3b04) entered blocking state
[ 1092.205739] lxdbr0: port 1(tapfb3a3b04) entered disabled state
[ 1092.205912] device tapfb3a3b04 entered promiscuous mode
[ 1092.252306] audit: type=1400 audit(1694814421.586:79): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=64987 comm="apparmor_parser"
[ 1092.586273] lxdbr0: port 1(tapfb3a3b04) entered blocking state
[ 1092.586274] lxdbr0: port 1(tapfb3a3b04) entered forwarding state
[ 1093.134409] audit: type=1400 audit(1694814422.466:80): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=65007 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 1186.220393] set kvm_intel.dump_invalid_vmcs=1 to dump internal KVM state.
[ 1186.655843] device tapfb3a3b04 left promiscuous mode
[ 1186.655850] lxdbr0: port 1(tapfb3a3b04) entered disabled state
[ 1187.003561] audit: type=1400 audit(1694814516.338:81): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=78683 comm="apparmor_parser"
[ 1190.307012] lxdbr0: port 1(tapb9afe1e5) entered blocking state
[ 1190.307014] lxdbr0: port 1(tapb9afe1e5) entered disabled state
[ 1190.307235] device tapb9afe1e5 entered promiscuous mode
[ 1190.352904] audit: type=1400 audit(1694814519.686:82): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=78967 comm="apparmor_parser"
[ 1190.674122] lxdbr0: port 1(tapb9afe1e5) entered blocking state
[ 1190.674124] lxdbr0: port 1(tapb9afe1e5) entered forwarding state
[ 1191.167498] audit: type=1400 audit(1694814520.502:83): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=79029 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 1245.718480] lxdbr0: port 1(tapb9afe1e5) entered disabled state
[ 1245.939371] device tapb9afe1e5 left promiscuous mode
[ 1245.939377] lxdbr0: port 1(tapb9afe1e5) entered disabled state
[ 1246.355001] audit: type=1400 audit(1694814575.690:84): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=88797 comm="apparmor_parser"
[ 1246.982211] lxdbr0: port 1(tap9d69e591) entered blocking state
[ 1246.982214] lxdbr0: port 1(tap9d69e591) entered disabled state
[ 1246.982371] device tap9d69e591 entered promiscuous mode
[ 1246.982382] lxdbr0: port 1(tap9d69e591) entered blocking state
[ 1246.982383] lxdbr0: port 1(tap9d69e591) entered forwarding state
[ 1247.020157] audit: type=1400 audit(1694814576.354:85): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=88967 comm="apparmor_parser"
[ 1251.131455] audit: type=1400 audit(1694814580.466:86): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=88987 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 1272.748690] set kvm_intel.dump_invalid_vmcs=1 to dump internal KVM state.
[ 1273.179130] lxdbr0: port 1(tap9d69e591) entered disabled state
[ 1273.208821] device tap9d69e591 left promiscuous mode
[ 1273.208830] lxdbr0: port 1(tap9d69e591) entered disabled state
[ 1273.577096] audit: type=1400 audit(1694814602.910:87): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=89356 comm="apparmor_parser"
[ 1439.543121] lxdbr0: port 1(tap6ce6673e) entered blocking state
[ 1439.543123] lxdbr0: port 1(tap6ce6673e) entered disabled state
[ 1439.543369] device tap6ce6673e entered promiscuous mode
[ 1439.728430] audit: type=1400 audit(1694814769.062:88): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=92051 comm="apparmor_parser"
[ 1440.127499] lxdbr0: port 1(tap6ce6673e) entered blocking state
[ 1440.127501] lxdbr0: port 1(tap6ce6673e) entered forwarding state
[ 1440.728950] audit: type=1400 audit(1694814770.062:89): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=92063 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 1440.893004] kvm: vcpu 5: requested 83800 ns lapic timer period limited to 200000 ns
[ 1440.893184] kvm: vcpu 6: requested 83800 ns lapic timer period limited to 200000 ns
[ 1440.895142] kvm: vcpu 7: requested 83800 ns lapic timer period limited to 200000 ns
[ 1742.490357] lxdbr0: port 1(tap6ce6673e) entered disabled state
[ 1742.811735] device tap6ce6673e left promiscuous mode
[ 1742.811743] lxdbr0: port 1(tap6ce6673e) entered disabled state
[ 1743.350058] audit: type=1400 audit(1694815072.682:90): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=129783 comm="apparmor_parser"
[ 1744.054135] lxdbr0: port 1(tapf752a228) entered blocking state
[ 1744.054137] lxdbr0: port 1(tapf752a228) entered disabled state
[ 1744.054300] device tapf752a228 entered promiscuous mode
[ 1744.054309] lxdbr0: port 1(tapf752a228) entered blocking state
[ 1744.054311] lxdbr0: port 1(tapf752a228) entered forwarding state
[ 1744.104190] audit: type=1400 audit(1694815073.438:91): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=130010 comm="apparmor_parser"
[ 1744.530443] lxdbr0: port 1(tapf752a228) entered disabled state
[ 1744.901139] lxdbr0: port 1(tapf752a228) entered blocking state
[ 1744.901141] lxdbr0: port 1(tapf752a228) entered forwarding state
[ 1747.879168] audit: type=1400 audit(1694815077.214:92): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=130031 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 1818.128066] set kvm_intel.dump_invalid_vmcs=1 to dump internal KVM state.
[ 1818.522500] device tapf752a228 left promiscuous mode
[ 1818.522508] lxdbr0: port 1(tapf752a228) entered disabled state
[ 1818.852550] audit: type=1400 audit(1694815148.186:93): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=144080 comm="apparmor_parser"
[ 2588.410128] blk_update_request: I/O error, dev fd0, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 2588.410132] floppy: error 10 while reading block 0
[ 2674.015249] lxdbr0: port 1(tape55cb3d3) entered blocking state
[ 2674.015250] lxdbr0: port 1(tape55cb3d3) entered disabled state
[ 2674.015406] device tape55cb3d3 entered promiscuous mode
[ 2674.191237] audit: type=1400 audit(1694816003.526:94): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=146604 comm="apparmor_parser"
[ 2674.429353] lxdbr0: port 1(tape55cb3d3) entered blocking state
[ 2674.429355] lxdbr0: port 1(tape55cb3d3) entered forwarding state
[ 2674.926851] audit: type=1400 audit(1694816004.262:95): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=146635 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 2923.555089] lxdbr0: port 1(tape55cb3d3) entered disabled state
[ 2924.566370] device tape55cb3d3 left promiscuous mode
[ 2924.566376] lxdbr0: port 1(tape55cb3d3) entered disabled state
[ 2925.200096] audit: type=1400 audit(1694816254.534:96): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=187265 comm="apparmor_parser"
[ 2925.907927] lxdbr0: port 1(tape119ef59) entered blocking state
[ 2925.907929] lxdbr0: port 1(tape119ef59) entered disabled state
[ 2925.908196] device tape119ef59 entered promiscuous mode
[ 2925.956030] audit: type=1400 audit(1694816255.290:97): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=187514 comm="apparmor_parser"
[ 2927.181693] lxdbr0: port 1(tape119ef59) entered blocking state
[ 2927.181696] lxdbr0: port 1(tape119ef59) entered forwarding state
[ 2931.832008] audit: type=1400 audit(1694816261.166:98): apparmor="DENIED" operation="open" profile="lxd-win2k12_</var/snap/lxd/common/lxd>" name="/var/lib/snapd/hostfs/etc/ssl/openssl.cnf" pid=187534 comm="qemu-system-x86" requested_mask="r" denied_mask="r" fsuid=999 ouid=0
[ 2993.317529] set kvm_intel.dump_invalid_vmcs=1 to dump internal KVM state.
[ 2993.802930] device tape119ef59 left promiscuous mode
[ 2993.802936] lxdbr0: port 1(tape119ef59) entered disabled state
[ 2994.118884] audit: type=1400 audit(1694816323.454:99): apparmor="STATUS" operation="profile_remove" profile="unconfined" name="lxd-win2k12_</var/snap/lxd/common/lxd>" pid=203106 comm="apparmor_parser"
