Had a couple of Fedora 39 VMs, running 6.7.11-200.fc39.x86_64 kernel, with identical configuration done through ansible. Upgraded one of the VMs to the latest kernel, 6.8.4-200.fc39.x86_64, today. After restarting, it never finished booting and stood stuck at Job dev-loop0p2.device/start running (4min 53s / no limit). Not sure if this is an incus issue, hoping it is not, or the upgraded kernel issue.
Steps to reproduce
- Create a Fedora 39 VM using
06bb4305f08fVM images from remote (https://images.linuxcontainers.org) - Exec into VM and upgrade to kernel (dnf distro-sync --refresh)
- Restart VM
- Check VM console for boot progress.
Required information
- Distribution: Fedora (x86_64)
- Distribution version: 39
- The output of “incus info”
core.https_address: <redacted>:8443
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- network_sriov
- console
- restrict_dev_incus
- migration_pre_copy
- infiniband
- dev_incus_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- dev_incus_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- backup_compression
- nvidia_runtime_config
- storage_unmapped
- projects
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- images_all_projects
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- zfs_delegate
- storage_api_remote_volume_snapshot_copy
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- image_restriction_privileged
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
- ovn_ssl_config
- certificate_description
- disk_io_bus_virtio_blk
- loki_config_instance
- instance_create_start
- clustering_evacuation_stop_options
- boot_host_shutdown_action
- agent_config_drive
- network_state_ovn_lr
- image_template_permissions
- storage_bucket_backup
- storage_lvm_cluster
- shared_custom_block_volumes
- auth_tls_jwt
- oidc_claim
- device_usb_serial
- numa_cpu_balanced
- image_restriction_nesting
- network_integrations
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: srvadmin
auth_user_method: unix
environment:
addresses:
- <redacted>:8443
architectures:
- x86_64
- i686
certificate: <redacted>
certificate_fingerprint: <redacted>
driver: lxc | qemu
driver_version: 5.0.3 | 8.1.3
firewall: nftables
kernel: Linux
kernel_architecture: x86_64
kernel_features:
idmapped_mounts: "true"
netnsid_getifaddrs: "true"
seccomp_listener: "true"
uevent_injection: "true"
unpriv_binfmt: "true"
unpriv_fscaps: "true"
kernel_version: 6.7.10-200.fc39.x86_64
lxc_features:
cgroup2: "true"
core_scheduling: "true"
devpts_fd: "true"
idmapped_mounts_v2: "true"
mount_injection_file: "true"
network_ipvlan: "true"
network_l2proxy: "true"
network_veth_router: "true"
pidfd: "true"
seccomp_notify: "true"
os_name: Fedora Linux
os_version: "39"
project: default
server: incus
server_clustered: false
server_event_mode: full-mesh
server_name: <redacted>
server_pid: 1586
server_version: "0.7"
storage: lvm
storage_version: 2.03.23(2) (2023-11-21) / 1.02.197 (2023-11-21) / 4.48.0
storage_supported_drivers:
- name: btrfs
version: "6.8"
remote: false
- name: dir
version: "1"
remote: false
- name: lvm
remote: false
- name: lvmcluster
remote: true
- Incus VM console
BdsDxe: loading Boot0007 "Fedora" from HD(1,GPT,AD52830E-57C2-47FA-A1B2-C7E3989A80A8,0x800,0x32000)/\EFI\fedora\shimx64.efi
BdsDxe: starting Boot0007 "Fedora" from HD(1,GPT,AD52830E-57C2-47FA-A1B2-C7E3989A80A8,0x800,0x32000)/\EFI\fedora\shimx64.efi
error: ../../grub-core/fs/fshelp.c:257:file `/EFI/fedora/grubenv' not found.
Booting `Fedora Linux (6.8.4-200.fc39.x86_64) 39'
[ 0.000000] Linux version 6.8.4-200.fc39.x86_64 (mockbuild@ea9727ef4ac046558fb6c0e9fa407113) (gcc (GCC) 13.2.1 20240316 (Red Hat 13.2.1-7), GNU ld version 2.40-14.fc39) #1 SMP PREEMPT_DYNAMIC Thu Apr 4 20:45:21 UTC 2024
[ 0.000000] Command line: BOOT_IMAGE=(hd0,gpt2)/boot/vmlinuz-6.8.4-200.fc39.x86_64 root=/dev/loop0p2 ro console=tty1 console=ttyS0
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007f8ecfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007f8ed000-0x000000007fb6cfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007fb6d000-0x000000007fb7efff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000007fb7f000-0x000000007fbfefff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000007fbff000-0x000000007ffdffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007ffe0000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffe00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] extended physical RAM map:
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000007e247017] usable
[ 0.000000] reserve setup_data: [mem 0x00007e247018-0x000000007e27c657] usable
[ 0.000000] reserve setup_data: [mem 0x000000007e27c658-0x000000007e27d017] usable
[ 0.000000] reserve setup_data: [mem 0x000000007e27d018-0x000000007e286a57] usable
[ 0.000000] reserve setup_data: [mem 0x000000007e286a58-0x000000007f8ecfff] usable
[ 0.000000] reserve setup_data: [mem 0x000000007f8ed000-0x000000007fb6cfff] reserved
[ 0.000000] reserve setup_data: [mem 0x000000007fb6d000-0x000000007fb7efff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x000000007fb7f000-0x000000007fbfefff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000007fbff000-0x000000007ffdffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000007ffe0000-0x000000007fffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000feffc000-0x00000000feffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x00000000ffe00000-0x00000000ffffffff] reserved
[ 0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000027fffffff] usable
[ 0.000000] reserve setup_data: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] efi: EFI v2.7 by EDK II
[ 0.000000] efi: SMBIOS=0x7f8f9000 SMBIOS 3.0=0x7f8f7000 ACPI=0x7fb7e000 ACPI 2.0=0x7fb7e014 MEMATTR=0x7e9ab198 MOKvar=0x7f8f3000 RNG=0x7fb70018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem109: MMIO range=[0xffe00000-0xffffffff] (2MB) from e820 map
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] SMBIOS 3.0.0 present.
[ 0.000000] DMI: QEMU Standard PC (Q35 + ICH9, 2009)/Incus, BIOS edk2-20240214-2.fc39 02/14/2024
[ 0.000000] Hypervisor detected: KVM
[ 0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
[ 0.000000] kvm-clock: using sched offset of 8894725213 cycles
[ 0.000001] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
[ 0.000003] tsc: Detected 4491.540 MHz processor
[ 0.000078] last_pfn = 0x280000 max_arch_pfn = 0x400000000
[ 0.000101] MTRR map: 4 entries (2 fixed + 2 variable; max 18), built from 8 variable MTRRs
[ 0.000103] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000131] last_pfn = 0x7ffe0 max_arch_pfn = 0x400000000
[ 0.003011] Using GB pages for direct mapping
[ 0.003183] secureboot: Secure boot disabled
[ 0.003183] RAMDISK: [mem 0x7c741000-0x7d939fff]
[ 0.003187] ACPI: Early table checksum verification disabled
[ 0.003189] ACPI: RSDP 0x000000007FB7E014 000024 (v02 BOCHS )
[ 0.003192] ACPI: XSDT 0x000000007FB7D0E8 000064 (v01 BOCHS BXPC 00000001 01000013)
[ 0.003195] ACPI: FACP 0x000000007FB78000 0000F4 (v03 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003199] ACPI: DSDT 0x000000007FB79000 003426 (v01 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003202] ACPI: FACS 0x000000007FBDC000 000040
[ 0.003204] ACPI: APIC 0x000000007FB77000 000170 (v03 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003207] ACPI: SSDT 0x000000007FB76000 0000CA (v01 BOCHS VMGENID 00000001 BXPC 00000001)
[ 0.003209] ACPI: HPET 0x000000007FB75000 000038 (v01 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003211] ACPI: SRAT 0x000000007FB74000 0002A8 (v01 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003214] ACPI: MCFG 0x000000007FB73000 00003C (v01 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003216] ACPI: WAET 0x000000007FB72000 000028 (v01 BOCHS BXPC 00000001 BXPC 00000001)
[ 0.003218] ACPI: BGRT 0x000000007FB71000 000038 (v01 INTEL EDK2 00000002 01000013)
[ 0.003219] ACPI: Reserving FACP table memory at [mem 0x7fb78000-0x7fb780f3]
[ 0.003220] ACPI: Reserving DSDT table memory at [mem 0x7fb79000-0x7fb7c425]
[ 0.003221] ACPI: Reserving FACS table memory at [mem 0x7fbdc000-0x7fbdc03f]
[ 0.003221] ACPI: Reserving APIC table memory at [mem 0x7fb77000-0x7fb7716f]
[ 0.003221] ACPI: Reserving SSDT table memory at [mem 0x7fb76000-0x7fb760c9]
[ 0.003222] ACPI: Reserving HPET table memory at [mem 0x7fb75000-0x7fb75037]
[ 0.003222] ACPI: Reserving SRAT table memory at [mem 0x7fb74000-0x7fb742a7]
[ 0.003223] ACPI: Reserving MCFG table memory at [mem 0x7fb73000-0x7fb7303b]
[ 0.003223] ACPI: Reserving WAET table memory at [mem 0x7fb72000-0x7fb72027]
[ 0.003223] ACPI: Reserving BGRT table memory at [mem 0x7fb71000-0x7fb71037]
[ 0.003248] SRAT: PXM 0 -> APIC 0x00 -> Node 0
[ 0.003249] SRAT: PXM 0 -> APIC 0x01 -> Node 0
[ 0.003249] SRAT: PXM 0 -> APIC 0x02 -> Node 0
[ 0.003250] SRAT: PXM 0 -> APIC 0x03 -> Node 0
[ 0.003250] SRAT: PXM 0 -> APIC 0x04 -> Node 0
[ 0.003250] SRAT: PXM 0 -> APIC 0x05 -> Node 0
[ 0.003251] SRAT: PXM 0 -> APIC 0x06 -> Node 0
[ 0.003251] SRAT: PXM 0 -> APIC 0x07 -> Node 0
[ 0.003251] SRAT: PXM 0 -> APIC 0x08 -> Node 0
[ 0.003252] SRAT: PXM 0 -> APIC 0x09 -> Node 0
[ 0.003252] SRAT: PXM 0 -> APIC 0x0a -> Node 0
[ 0.003252] SRAT: PXM 0 -> APIC 0x0b -> Node 0
[ 0.003253] SRAT: PXM 0 -> APIC 0x0c -> Node 0
[ 0.003253] SRAT: PXM 0 -> APIC 0x0d -> Node 0
[ 0.003253] SRAT: PXM 0 -> APIC 0x0e -> Node 0
[ 0.003254] SRAT: PXM 0 -> APIC 0x0f -> Node 0
[ 0.003254] SRAT: PXM 0 -> APIC 0x10 -> Node 0
[ 0.003254] SRAT: PXM 0 -> APIC 0x11 -> Node 0
[ 0.003255] SRAT: PXM 0 -> APIC 0x12 -> Node 0
[ 0.003255] SRAT: PXM 0 -> APIC 0x13 -> Node 0
[ 0.003256] SRAT: PXM 0 -> APIC 0x14 -> Node 0
[ 0.003256] SRAT: PXM 0 -> APIC 0x15 -> Node 0
[ 0.003256] SRAT: PXM 0 -> APIC 0x16 -> Node 0
[ 0.003257] SRAT: PXM 0 -> APIC 0x17 -> Node 0
[ 0.003257] SRAT: PXM 0 -> APIC 0x18 -> Node 0
[ 0.003257] SRAT: PXM 0 -> APIC 0x19 -> Node 0
[ 0.003258] SRAT: PXM 0 -> APIC 0x1a -> Node 0
[ 0.003258] SRAT: PXM 0 -> APIC 0x1b -> Node 0
[ 0.003258] SRAT: PXM 0 -> APIC 0x1c -> Node 0
[ 0.003259] SRAT: PXM 0 -> APIC 0x1d -> Node 0
[ 0.003259] SRAT: PXM 0 -> APIC 0x1e -> Node 0
[ 0.003259] SRAT: PXM 0 -> APIC 0x1f -> Node 0
[ 0.003260] ACPI: SRAT: Node 0 PXM 0 [mem 0x00000000-0x0009ffff]
[ 0.003261] ACPI: SRAT: Node 0 PXM 0 [mem 0x00100000-0x7fffffff]
[ 0.003262] ACPI: SRAT: Node 0 PXM 0 [mem 0x100000000-0x27fffffff]
[ 0.003264] NUMA: Node 0 [mem 0x00000000-0x0009ffff] + [mem 0x00100000-0x7fffffff] -> [mem 0x00000000-0x7fffffff]
[ 0.003265] NUMA: Node 0 [mem 0x00000000-0x7fffffff] + [mem 0x100000000-0x27fffffff] -> [mem 0x00000000-0x27fffffff]
[ 0.003269] NODE_DATA(0) allocated [mem 0x27ffd5000-0x27fffffff]
[ 0.003502] Zone ranges:
[ 0.003502] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.003503] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.003504] Normal [mem 0x0000000100000000-0x000000027fffffff]
[ 0.003505] Device empty
[ 0.003506] Movable zone start for each node
[ 0.003507] Early memory node ranges
[ 0.003507] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.003508] node 0: [mem 0x0000000000100000-0x000000007f8ecfff]
[ 0.003508] node 0: [mem 0x000000007fbff000-0x000000007ffdffff]
[ 0.003509] node 0: [mem 0x0000000100000000-0x000000027fffffff]
[ 0.003510] Initmem setup node 0 [mem 0x0000000000001000-0x000000027fffffff]
[ 0.003523] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.003683] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.024600] On node 0, zone DMA32: 786 pages in unavailable ranges
[ 0.086871] On node 0, zone Normal: 32 pages in unavailable ranges
[ 0.087419] ACPI: PM-Timer IO Port: 0x608
[ 0.087432] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
[ 0.087453] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
[ 0.087455] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.087456] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
[ 0.087456] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.087457] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
[ 0.087458] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
[ 0.087460] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.087461] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.087485] TSC deadline timer available
[ 0.087485] smpboot: Allowing 32 CPUs, 28 hotplug CPUs
[ 0.087502] kvm-guest: APIC: eoi() replaced with kvm_guest_apic_eoi_write()
[ 0.087515] kvm-guest: KVM setup pv remote TLB flush
[ 0.087517] kvm-guest: setup PV sched yield
[ 0.087524] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.087525] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.087526] PM: hibernation: Registered nosave memory: [mem 0x7e247000-0x7e247fff]
[ 0.087527] PM: hibernation: Registered nosave memory: [mem 0x7e27c000-0x7e27cfff]
[ 0.087527] PM: hibernation: Registered nosave memory: [mem 0x7e27d000-0x7e27dfff]
[ 0.087528] PM: hibernation: Registered nosave memory: [mem 0x7e286000-0x7e286fff]
[ 0.087528] PM: hibernation: Registered nosave memory: [mem 0x7e287000-0x7e28ffff]
[ 0.087529] PM: hibernation: Registered nosave memory: [mem 0x7f8ed000-0x7fb6cfff]
[ 0.087529] PM: hibernation: Registered nosave memory: [mem 0x7fb6d000-0x7fb7efff]
[ 0.087530] PM: hibernation: Registered nosave memory: [mem 0x7fb7f000-0x7fbfefff]
[ 0.087533] PM: hibernation: Registered nosave memory: [mem 0x7ffe0000-0x7fffffff]
[ 0.087533] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[ 0.087533] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.087534] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfeffbfff]
[ 0.087534] PM: hibernation: Registered nosave memory: [mem 0xfeffc000-0xfeffffff]
[ 0.087535] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.087536] [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.087537] Booting paravirtualized kernel on KVM
[ 0.087538] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.090936] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
[ 0.096286] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u262144
[ 0.096322] kvm-guest: PV spinlocks enabled
[ 0.096323] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.096325] Kernel command line: BOOT_IMAGE=(hd0,gpt2)/boot/vmlinuz-6.8.4-200.fc39.x86_64 root=/dev/loop0p2 ro console=tty1 console=ttyS0
[ 0.096368] Unknown kernel command line parameters "BOOT_IMAGE=(hd0,gpt2)/boot/vmlinuz-6.8.4-200.fc39.x86_64", will be passed to user space.
[ 0.101691] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.104212] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.104474] Fallback order for Node 0: 0
[ 0.104477] Built 1 zonelists, mobility grouping on. Total pages: 2061304
[ 0.104478] Policy zone: Normal
[ 0.106000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.106005] software IO TLB: area num 32.
[ 0.139919] Memory: 8047144K/8384948K available (20480K kernel code, 3275K rwdata, 14800K rodata, 4620K init, 4824K bss, 337544K reserved, 0K cma-reserved)
[ 0.140140] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.140199] ftrace: allocating 54724 entries in 214 pages
[ 0.149086] ftrace: allocated 214 pages with 5 groups
[ 0.149905] Dynamic Preempt: voluntary
[ 0.150039] rcu: Preemptible hierarchical RCU implementation.
[ 0.150040] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=32.
[ 0.150041] Trampoline variant of Tasks RCU enabled.
[ 0.150041] Rude variant of Tasks RCU enabled.
[ 0.150042] Tracing variant of Tasks RCU enabled.
[ 0.150042] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.150043] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.151969] NR_IRQS: 524544, nr_irqs: 680, preallocated irqs: 16
[ 0.152177] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.152313] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.152358] Console: colour dummy device 80x25
[ 0.152360] printk: legacy console [tty1] enabled
[ 0.152556] printk: legacy console [ttyS0] enabled
[ 0.371680] ACPI: Core revision 20230628
[ 0.372095] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[ 0.372874] APIC: Switch to symmetric I/O mode setup
[ 0.373379] x2apic enabled
[ 0.373773] APIC: Switched APIC routing to: physical x2apic
[ 0.374212] kvm-guest: APIC: send_IPI_mask() replaced with kvm_send_ipi_mask()
[ 0.374791] kvm-guest: APIC: send_IPI_mask_allbutself() replaced with kvm_send_ipi_mask_allbutself()
[ 0.375489] kvm-guest: setup PV IPIs
[ 0.376348] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.376873] tsc: Marking TSC unstable due to TSCs unsynchronized
[ 0.377370] Calibrating delay loop (skipped) preset value.. 8983.08 BogoMIPS (lpj=4491540)
[ 0.378421] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.379011] Last level iTLB entries: 4KB 512, 2MB 255, 4MB 127
[ 0.379371] Last level dTLB entries: 4KB 512, 2MB 255, 4MB 127, 1GB 0
[ 0.379914] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.380373] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.381370] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.382060] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.382371] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.383371] Speculative Return Stack Overflow: IBPB-extending microcode not applied!
[ 0.384016] Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
[ 0.384016] Speculative Return Stack Overflow: Vulnerable: Safe RET, no microcode
[ 0.385385] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.386370] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.386899] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.387370] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[ 0.387993] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[ 0.388370] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[ 0.389370] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.390023] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.390370] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.390886] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.391370] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.391884] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.392370] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
[ 0.410225] Freeing SMP alternatives memory: 48K
[ 0.410373] pid_max: default: 32768 minimum: 301
[ 0.412516] LSM: initializing lsm=lockdown,capability,yama,selinux,bpf,landlock,integrity
[ 0.413219] Yama: becoming mindful.
[ 0.413373] SELinux: Initializing.
[ 0.413696] LSM support for eBPF active
[ 0.414027] landlock: Up and running.
[ 0.414475] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.415192] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.416418] smpboot: CPU0: AMD Ryzen 9 7950X 16-Core Processor (family: 0x19, model: 0x61, stepping: 0x2)
[ 0.417556] RCU Tasks: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.418264] RCU Tasks Rude: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.418409] RCU Tasks Trace: Setting shift to 5 and lim to 1 rcu_task_cb_adjust=1.
[ 0.419093] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.419375] ... version: 0
[ 0.419712] ... bit width: 48
[ 0.420054] ... generic registers: 6
[ 0.420372] ... value mask: 0000ffffffffffff
[ 0.420813] ... max period: 00007fffffffffff
[ 0.421260] ... fixed-purpose events: 0
[ 0.421372] ... event mask: 000000000000003f
[ 0.421894] signal: max sigframe size: 3376
[ 0.422294] rcu: Hierarchical SRCU implementation.
[ 0.422373] rcu: Max phase no-delay instances is 400.
[ 0.425535] smp: Bringing up secondary CPUs ...
[ 0.426179] smpboot: x86: Booting SMP configuration:
[ 0.426374] .... node #0, CPUs: #1 #2 #3
[ 0.427417] smp: Brought up 1 node, 4 CPUs
[ 0.428374] smpboot: Max logical packages: 8
[ 0.428749] smpboot: Total of 4 processors activated (35932.32 BogoMIPS)
[ 0.429600] devtmpfs: initialized
[ 0.429677] x86/mm: Memory block size: 128MB
[ 0.431382] ACPI: PM: Registering ACPI NVS region [mem 0x7fb7f000-0x7fbfefff] (524288 bytes)
[ 0.432135] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffff, max_idle_ns: 1911260446275000 ns
[ 0.432377] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.433323] pinctrl core: initialized pinctrl subsystem
[ 0.433514] PM: RTC time: 14:00:31, date: 2024-04-06
[ 0.435451] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.436052] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.436382] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.437008] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.437396] audit: initializing netlink subsys (disabled)
[ 0.437873] audit: type=2000 audit(1712412032.173:1): state=initialized audit_enabled=0 res=1
[ 0.437873] thermal_sys: Registered thermal governor 'fair_share'
[ 0.438375] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.438867] thermal_sys: Registered thermal governor 'step_wise'
[ 0.439346] thermal_sys: Registered thermal governor 'user_space'
[ 0.439490] cpuidle: using governor menu
[ 0.440543] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.441315] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[ 0.441369] PCI: ECAM [mem 0xe0000000-0xefffffff] reserved as E820 entry
[ 0.441369] PCI: Using configuration type 1 for base access
[ 0.443408] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.444485] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.444995] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.445369] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.445369] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.447443] cryptd: max_cpu_qlen set to 1000
[ 0.448421] raid6: skipped pq benchmark and selected avx512x4
[ 0.448421] raid6: using avx512x2 recovery algorithm
[ 0.448952] fbcon: Taking over console
[ 0.449374] ACPI: Added _OSI(Module Device)
[ 0.449771] ACPI: Added _OSI(Processor Device)
[ 0.450187] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.450373] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.452598] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.461031] ACPI: _OSC evaluation for CPUs failed, trying _PDC
[ 0.461557] ACPI: Interpreter enabled
[ 0.461899] ACPI: PM: (supports S0 S5)
[ 0.462246] ACPI: Using IOAPIC for interrupt routing
[ 0.462564] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.463374] PCI: Ignoring E820 reservations for host bridge windows
[ 0.464055] ACPI: Enabled 3 GPEs in block 00 to 3F
[ 0.467559] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.468137] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.469405] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug LTR DPC]
[ 0.470139] acpi PNP0A08:00: _OSC: OS now controls [SHPCHotplug PME AER PCIeCapability]
[ 0.470548] PCI host bridge to bus 0000:00
[ 0.470923] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.472374] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.472984] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.473373] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 0.474054] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfebfffff window]
[ 0.474374] pci_bus 0000:00: root bus resource [mem 0x380000000000-0x3847ffffffff window]
[ 0.475119] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.475407] pci 0000:00:00.0: [8086:29c0] type 00 class 0x060000 conventional PCI endpoint
[ 0.476411] pci 0000:00:01.0: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.480037] pci 0000:00:01.0: BAR 0 [mem 0x81a49000-0x81a49fff]
[ 0.483376] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.483901] pci 0000:00:01.0: bridge window [mem 0x81800000-0x819fffff]
[ 0.485158] pci 0000:00:01.0: bridge window [mem 0x380000000000-0x3807ffffffff 64bit pref]
[ 0.486157] pci 0000:00:01.1: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.489318] pci 0000:00:01.1: BAR 0 [mem 0x81a48000-0x81a48fff]
[ 0.491376] pci 0000:00:01.1: PCI bridge to [bus 02]
[ 0.491851] pci 0000:00:01.1: bridge window [mem 0x81600000-0x817fffff]
[ 0.492745] pci 0000:00:01.1: bridge window [mem 0x380800000000-0x380fffffffff 64bit pref]
[ 0.493932] pci 0000:00:01.2: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.496373] pci 0000:00:01.2: BAR 0 [mem 0x81a47000-0x81a47fff]
[ 0.500371] pci 0000:00:01.2: PCI bridge to [bus 03]
[ 0.500845] pci 0000:00:01.2: bridge window [mem 0x81400000-0x815fffff]
[ 0.501653] pci 0000:00:01.2: bridge window [mem 0x381000000000-0x3817ffffffff 64bit pref]
[ 0.502888] pci 0000:00:01.3: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.506390] pci 0000:00:01.3: BAR 0 [mem 0x81a46000-0x81a46fff]
[ 0.509417] pci 0000:00:01.3: PCI bridge to [bus 04]
[ 0.509994] pci 0000:00:01.3: bridge window [mem 0x80000000-0x808fffff]
[ 0.511684] pci 0000:00:01.3: bridge window [mem 0x381800000000-0x381fffffffff 64bit pref]
[ 0.513259] pci 0000:00:01.4: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.514372] pci 0000:00:01.4: BAR 0 [mem 0x81a45000-0x81a45fff]
[ 0.517307] pci 0000:00:01.4: PCI bridge to [bus 05]
[ 0.517391] pci 0000:00:01.4: bridge window [mem 0x81200000-0x813fffff]
[ 0.518294] pci 0000:00:01.4: bridge window [mem 0x382000000000-0x3827ffffffff 64bit pref]
[ 0.520066] pci 0000:00:01.5: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.521134] pci 0000:00:01.5: BAR 0 [mem 0x81a44000-0x81a44fff]
[ 0.523372] pci 0000:00:01.5: PCI bridge to [bus 06]
[ 0.523845] pci 0000:00:01.5: bridge window [mem 0x81000000-0x811fffff]
[ 0.524669] pci 0000:00:01.5: bridge window [mem 0x382800000000-0x382fffffffff 64bit pref]
[ 0.525908] pci 0000:00:01.6: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.528095] pci 0000:00:01.6: BAR 0 [mem 0x81a43000-0x81a43fff]
[ 0.529266] pci 0000:00:01.6: PCI bridge to [bus 07]
[ 0.530396] pci 0000:00:01.6: bridge window [mem 0x80e00000-0x80ffffff]
[ 0.531276] pci 0000:00:01.6: bridge window [mem 0x383000000000-0x3837ffffffff 64bit pref]
[ 0.531915] pci 0000:00:01.7: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.534088] pci 0000:00:01.7: BAR 0 [mem 0x81a42000-0x81a42fff]
[ 0.535834] pci 0000:00:01.7: PCI bridge to [bus 08]
[ 0.536292] pci 0000:00:01.7: bridge window [mem 0x80c00000-0x80dfffff]
[ 0.538658] pci 0000:00:01.7: bridge window [mem 0x383800000000-0x383fffffffff 64bit pref]
[ 0.539885] pci 0000:00:02.0: [1b36:000c] type 01 class 0x060400 PCIe Root Port
[ 0.541123] pci 0000:00:02.0: BAR 0 [mem 0x81a41000-0x81a41fff]
[ 0.542308] pci 0000:00:02.0: PCI bridge to [bus 09]
[ 0.543391] pci 0000:00:02.0: bridge window [mem 0x80a00000-0x80bfffff]
[ 0.544281] pci 0000:00:02.0: bridge window [mem 0x384000000000-0x3847ffffffff 64bit pref]
[ 0.544997] pci 0000:00:1f.0: [8086:2918] type 00 class 0x060100 conventional PCI endpoint
[ 0.546598] pci 0000:00:1f.0: quirk: [io 0x0600-0x067f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.547391] pci 0000:00:1f.2: [8086:2922] type 00 class 0x010601 conventional PCI endpoint
[ 0.550589] pci 0000:00:1f.2: BAR 4 [io 0x6040-0x605f]
[ 0.551371] pci 0000:00:1f.2: BAR 5 [mem 0x81a40000-0x81a40fff]
[ 0.552481] pci 0000:00:1f.3: [8086:2930] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.556156] pci 0000:00:1f.3: BAR 4 [io 0x6000-0x603f]
[ 0.558396] acpiphp: Slot [0] registered
[ 0.558839] pci 0000:01:00.0: [1af4:1045] type 00 class 0x00ff00 PCIe Endpoint
[ 0.562928] pci 0000:01:00.0: BAR 4 [mem 0x380000014000-0x380000017fff 64bit pref]
[ 0.564512] pci 0000:01:00.1: [1af4:1044] type 00 class 0x00ff00 PCIe Endpoint
[ 0.566302] pci 0000:01:00.1: BAR 1 [mem 0x81808000-0x81808fff]
[ 0.567851] pci 0000:01:00.1: BAR 4 [mem 0x380000010000-0x380000013fff 64bit pref]
[ 0.569733] pci 0000:01:00.2: [1af4:1052] type 00 class 0x090000 PCIe Endpoint
[ 0.572824] pci 0000:01:00.2: BAR 1 [mem 0x81807000-0x81807fff]
[ 0.575371] pci 0000:01:00.2: BAR 4 [mem 0x38000000c000-0x38000000ffff 64bit pref]
[ 0.577187] pci 0000:01:00.3: [1af4:1052] type 00 class 0x098000 PCIe Endpoint
[ 0.578321] pci 0000:01:00.3: BAR 1 [mem 0x81806000-0x81806fff]
[ 0.581372] pci 0000:01:00.3: BAR 4 [mem 0x380000008000-0x38000000bfff 64bit pref]
[ 0.585390] pci 0000:01:00.4: [1af4:1053] type 00 class 0x078000 PCIe Endpoint
[ 0.586808] pci 0000:01:00.4: BAR 1 [mem 0x81805000-0x81805fff]
[ 0.588371] pci 0000:01:00.4: BAR 4 [mem 0x380000004000-0x380000007fff 64bit pref]
[ 0.591168] pci 0000:01:00.5: [1af4:1043] type 00 class 0x078000 PCIe Endpoint
[ 0.592308] pci 0000:01:00.5: BAR 1 [mem 0x81804000-0x81804fff]
[ 0.594365] pci 0000:01:00.5: BAR 4 [mem 0x380000000000-0x380000003fff 64bit pref]
[ 0.598639] pci 0000:01:00.6: [1b36:000d] type 00 class 0x0c0330 PCIe Endpoint
[ 0.599518] pci 0000:01:00.6: BAR 0 [mem 0x81800000-0x81803fff 64bit]
[ 0.601988] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.602774] acpiphp: Slot [0-2] registered
[ 0.603209] pci 0000:02:00.0: [1af4:1048] type 00 class 0x010000 PCIe Endpoint
[ 0.604312] pci 0000:02:00.0: BAR 1 [mem 0x81600000-0x81600fff]
[ 0.606626] pci 0000:02:00.0: BAR 4 [mem 0x380800000000-0x380800003fff 64bit pref]
[ 0.609698] pci 0000:00:01.1: PCI bridge to [bus 02]
[ 0.610466] acpiphp: Slot [0-3] registered
[ 0.610937] pci 0000:03:00.0: [1af4:1049] type 00 class 0x000200 PCIe Endpoint
[ 0.612372] pci 0000:03:00.0: BAR 1 [mem 0x81400000-0x81400fff]
[ 0.615327] pci 0000:03:00.0: BAR 4 [mem 0x381000000000-0x381000003fff 64bit pref]
[ 0.616691] pci 0000:00:01.2: PCI bridge to [bus 03]
[ 0.617535] pci 0000:04:00.0: [1af4:1050] type 00 class 0x030000 PCIe Endpoint
[ 0.620450] pci 0000:04:00.0: BAR 0 [mem 0x80000000-0x807fffff pref]
[ 0.623400] pci 0000:04:00.0: BAR 2 [mem 0x381800000000-0x381800003fff 64bit pref]
[ 0.624841] pci 0000:04:00.0: BAR 4 [mem 0x80800000-0x80800fff]
[ 0.627865] pci 0000:04:00.0: ROM [mem 0xffff0000-0xffffffff pref]
[ 0.628599] pci 0000:04:00.0: BAR 0: assigned to efifb
[ 0.630393] pci 0000:04:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.632098] pci 0000:00:01.3: PCI bridge to [bus 04]
[ 0.632829] acpiphp: Slot [0-4] registered
[ 0.633249] pci 0000:05:00.0: [1af4:1041] type 00 class 0x020000 PCIe Endpoint
[ 0.635328] pci 0000:05:00.0: BAR 1 [mem 0x81200000-0x81200fff]
[ 0.637615] pci 0000:05:00.0: BAR 4 [mem 0x382000000000-0x382000003fff 64bit pref]
[ 0.638604] pci 0000:05:00.0: ROM [mem 0xfffc0000-0xffffffff pref]
[ 0.640038] pci 0000:00:01.4: PCI bridge to [bus 05]
[ 0.640767] acpiphp: Slot [0-5] registered
[ 0.642382] pci 0000:00:01.5: PCI bridge to [bus 06]
[ 0.643217] acpiphp: Slot [0-6] registered
[ 0.643381] pci 0000:00:01.6: PCI bridge to [bus 07]
[ 0.644177] acpiphp: Slot [0-7] registered
[ 0.644381] pci 0000:00:01.7: PCI bridge to [bus 08]
[ 0.645176] acpiphp: Slot [0-8] registered
[ 0.645381] pci 0000:00:02.0: PCI bridge to [bus 09]
[ 0.648332] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
[ 0.649423] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[ 0.649972] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[ 0.650418] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
[ 0.650966] ACPI: PCI: Interrupt link LNKE configured for IRQ 10
[ 0.651417] ACPI: PCI: Interrupt link LNKF configured for IRQ 10
[ 0.653419] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[ 0.653960] ACPI: PCI: Interrupt link LNKH configured for IRQ 11
[ 0.654391] ACPI: PCI: Interrupt link GSIA configured for IRQ 16
[ 0.654892] ACPI: PCI: Interrupt link GSIB configured for IRQ 17
[ 0.655379] ACPI: PCI: Interrupt link GSIC configured for IRQ 18
[ 0.655880] ACPI: PCI: Interrupt link GSID configured for IRQ 19
[ 0.656389] ACPI: PCI: Interrupt link GSIE configured for IRQ 20
[ 0.656892] ACPI: PCI: Interrupt link GSIF configured for IRQ 21
[ 0.657379] ACPI: PCI: Interrupt link GSIG configured for IRQ 22
[ 0.657879] ACPI: PCI: Interrupt link GSIH configured for IRQ 23
[ 0.660553] iommu: Default domain type: Translated
[ 0.660788] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.661573] SCSI subsystem initialized
[ 0.661907] ACPI: bus type USB registered
[ 0.662388] usbcore: registered new interface driver usbfs
[ 0.662845] usbcore: registered new interface driver hub
[ 0.663311] usbcore: registered new device driver usb
[ 0.663411] pps_core: LinuxPPS API ver. 1 registered
[ 0.663856] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.664375] PTP clock support registered
[ 0.665419] EDAC MC: Ver: 3.0.0
[ 0.666419] efivars: Registered efivars operations
[ 0.666838] NetLabel: Initializing
[ 0.666838] NetLabel: domain hash size = 128
[ 0.667158] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.668391] NetLabel: unlabeled traffic allowed by default
[ 0.668854] mctp: management component transport protocol core
[ 0.669336] NET: Registered PF_MCTP protocol family
[ 0.669381] PCI: Using ACPI for IRQ routing
[ 0.696455] pci 0000:04:00.0: vgaarb: setting as boot VGA device
[ 0.696893] pci 0000:04:00.0: vgaarb: bridge control possible
[ 0.697367] pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.698372] vgaarb: loaded
[ 0.698601] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.698961] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
[ 0.703453] clocksource: Switched to clocksource kvm-clock
[ 0.705219] VFS: Disk quotas dquot_6.6.0
[ 0.705563] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.706201] pnp: PnP ACPI init
[ 0.706630] system 00:04: [mem 0xe0000000-0xefffffff window] has been reserved
[ 0.707372] pnp: PnP ACPI: found 5 devices
[ 0.713929] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.714785] NET: Registered PF_INET protocol family
[ 0.715902] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.730010] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.730732] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.731374] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.732055] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.733991] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.734781] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.735413] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.736053] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.736808] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.737286] NET: Registered PF_XDP protocol family
[ 0.737686] pci 0000:05:00.0: ROM [mem 0xfffc0000-0xffffffff pref]: can't claim; no compatible bridge window
[ 0.738497] pci 0000:00:01.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.739168] pci 0000:00:01.1: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.739843] pci 0000:00:01.2: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.740518] pci 0000:00:01.3: bridge window [io 0x1000-0x0fff] to [bus 04] add_size 1000
[ 0.741205] pci 0000:00:01.4: bridge window [io 0x1000-0x0fff] to [bus 05] add_size 1000
[ 0.741876] pci 0000:00:01.5: bridge window [io 0x1000-0x0fff] to [bus 06] add_size 1000
[ 0.742548] pci 0000:00:01.6: bridge window [io 0x1000-0x0fff] to [bus 07] add_size 1000
[ 0.743226] pci 0000:00:01.7: bridge window [io 0x1000-0x0fff] to [bus 08] add_size 1000
[ 0.743897] pci 0000:00:02.0: bridge window [io 0x1000-0x0fff] to [bus 09] add_size 1000
[ 0.744576] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]: assigned
[ 0.745134] pci 0000:00:01.1: bridge window [io 0x2000-0x2fff]: assigned
[ 0.745860] pci 0000:00:01.2: bridge window [io 0x3000-0x3fff]: assigned
[ 0.746420] pci 0000:00:01.3: bridge window [io 0x4000-0x4fff]: assigned
[ 0.746981] pci 0000:00:01.4: bridge window [io 0x5000-0x5fff]: assigned
[ 0.747541] pci 0000:00:01.5: bridge window [io 0x7000-0x7fff]: assigned
[ 0.748101] pci 0000:00:01.6: bridge window [io 0x8000-0x8fff]: assigned
[ 0.748664] pci 0000:00:01.7: bridge window [io 0x9000-0x9fff]: assigned
[ 0.749225] pci 0000:00:02.0: bridge window [io 0xa000-0xafff]: assigned
[ 0.749785] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.750204] pci 0000:00:01.0: bridge window [io 0x1000-0x1fff]
[ 0.751641] pci 0000:00:01.0: bridge window [mem 0x81800000-0x819fffff]
[ 0.752755] pci 0000:00:01.0: bridge window [mem 0x380000000000-0x3807ffffffff 64bit pref]
[ 0.754532] pci 0000:00:01.1: PCI bridge to [bus 02]
[ 0.754951] pci 0000:00:01.1: bridge window [io 0x2000-0x2fff]
[ 0.756358] pci 0000:00:01.1: bridge window [mem 0x81600000-0x817fffff]
[ 0.757474] pci 0000:00:01.1: bridge window [mem 0x380800000000-0x380fffffffff 64bit pref]
[ 0.759278] pci 0000:00:01.2: PCI bridge to [bus 03]
[ 0.759694] pci 0000:00:01.2: bridge window [io 0x3000-0x3fff]
[ 0.761038] pci 0000:00:01.2: bridge window [mem 0x81400000-0x815fffff]
[ 0.762725] pci 0000:00:01.2: bridge window [mem 0x381000000000-0x3817ffffffff 64bit pref]
[ 0.763977] pci 0000:00:01.3: PCI bridge to [bus 04]
[ 0.764399] pci 0000:00:01.3: bridge window [io 0x4000-0x4fff]
[ 0.765336] pci 0000:00:01.3: bridge window [mem 0x80000000-0x808fffff]
[ 0.766174] pci 0000:00:01.3: bridge window [mem 0x381800000000-0x381fffffffff 64bit pref]
[ 0.767455] pci 0000:05:00.0: ROM [mem 0x81240000-0x8127ffff pref]: assigned
[ 0.768040] pci 0000:00:01.4: PCI bridge to [bus 05]
[ 0.768460] pci 0000:00:01.4: bridge window [io 0x5000-0x5fff]
[ 0.769483] pci 0000:00:01.4: bridge window [mem 0x81200000-0x813fffff]
[ 0.770431] pci 0000:00:01.4: bridge window [mem 0x382000000000-0x3827ffffffff 64bit pref]
[ 0.771995] pci 0000:00:01.5: PCI bridge to [bus 06]
[ 0.773298] pci 0000:00:01.5: bridge window [io 0x7000-0x7fff]
[ 0.774156] pci 0000:00:01.5: bridge window [mem 0x81000000-0x811fffff]
[ 0.774943] pci 0000:00:01.5: bridge window [mem 0x382800000000-0x382fffffffff 64bit pref]
[ 0.776332] pci 0000:00:01.6: PCI bridge to [bus 07]
[ 0.776750] pci 0000:00:01.6: bridge window [io 0x8000-0x8fff]
[ 0.777622] pci 0000:00:01.6: bridge window [mem 0x80e00000-0x80ffffff]
[ 0.778417] pci 0000:00:01.6: bridge window [mem 0x383000000000-0x3837ffffffff 64bit pref]
[ 0.779612] pci 0000:00:01.7: PCI bridge to [bus 08]
[ 0.780032] pci 0000:00:01.7: bridge window [io 0x9000-0x9fff]
[ 0.780907] pci 0000:00:01.7: bridge window [mem 0x80c00000-0x80dfffff]
[ 0.781772] pci 0000:00:01.7: bridge window [mem 0x383800000000-0x383fffffffff 64bit pref]
[ 0.783461] pci 0000:00:02.0: PCI bridge to [bus 09]
[ 0.784694] pci 0000:00:02.0: bridge window [io 0xa000-0xafff]
[ 0.785556] pci 0000:00:02.0: bridge window [mem 0x80a00000-0x80bfffff]
[ 0.786346] pci 0000:00:02.0: bridge window [mem 0x384000000000-0x3847ffffffff 64bit pref]
[ 0.787562] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.788074] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.788586] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.789151] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[ 0.789722] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfebfffff window]
[ 0.790289] pci_bus 0000:00: resource 9 [mem 0x380000000000-0x3847ffffffff window]
[ 0.790911] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff]
[ 0.791373] pci_bus 0000:01: resource 1 [mem 0x81800000-0x819fffff]
[ 0.791890] pci_bus 0000:01: resource 2 [mem 0x380000000000-0x3807ffffffff 64bit pref]
[ 0.792541] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.793001] pci_bus 0000:02: resource 1 [mem 0x81600000-0x817fffff]
[ 0.793520] pci_bus 0000:02: resource 2 [mem 0x380800000000-0x380fffffffff 64bit pref]
[ 0.794171] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.794932] pci_bus 0000:03: resource 1 [mem 0x81400000-0x815fffff]
[ 0.795453] pci_bus 0000:03: resource 2 [mem 0x381000000000-0x3817ffffffff 64bit pref]
[ 0.796108] pci_bus 0000:04: resource 0 [io 0x4000-0x4fff]
[ 0.796573] pci_bus 0000:04: resource 1 [mem 0x80000000-0x808fffff]
[ 0.797093] pci_bus 0000:04: resource 2 [mem 0x381800000000-0x381fffffffff 64bit pref]
[ 0.797751] pci_bus 0000:05: resource 0 [io 0x5000-0x5fff]
[ 0.798216] pci_bus 0000:05: resource 1 [mem 0x81200000-0x813fffff]
[ 0.798745] pci_bus 0000:05: resource 2 [mem 0x382000000000-0x3827ffffffff 64bit pref]
[ 0.799401] pci_bus 0000:06: resource 0 [io 0x7000-0x7fff]
[ 0.799864] pci_bus 0000:06: resource 1 [mem 0x81000000-0x811fffff]
[ 0.800387] pci_bus 0000:06: resource 2 [mem 0x382800000000-0x382fffffffff 64bit pref]
[ 0.801037] pci_bus 0000:07: resource 0 [io 0x8000-0x8fff]
[ 0.801500] pci_bus 0000:07: resource 1 [mem 0x80e00000-0x80ffffff]
[ 0.802023] pci_bus 0000:07: resource 2 [mem 0x383000000000-0x3837ffffffff 64bit pref]
[ 0.802681] pci_bus 0000:08: resource 0 [io 0x9000-0x9fff]
[ 0.803141] pci_bus 0000:08: resource 1 [mem 0x80c00000-0x80dfffff]
[ 0.803665] pci_bus 0000:08: resource 2 [mem 0x383800000000-0x383fffffffff 64bit pref]
[ 0.804321] pci_bus 0000:09: resource 0 [io 0xa000-0xafff]
[ 0.804783] pci_bus 0000:09: resource 1 [mem 0x80a00000-0x80bfffff]
[ 0.805328] pci_bus 0000:09: resource 2 [mem 0x384000000000-0x3847ffffffff 64bit pref]
[ 0.806639] ACPI: \_SB_.GSIF: Enabled at IRQ 21
[ 0.807793] PCI: CLS 0 bytes, default 64
[ 0.808165] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.808261] Trying to unpack rootfs image as initramfs...
[ 0.808703] software IO TLB: mapped [mem 0x0000000077f7f000-0x000000007bf7f000] (64MB)
[ 0.812439] Initialise system trusted keyrings
[ 0.812835] Key type blacklist registered
[ 0.813260] workingset: timestamp_bits=36 max_order=21 bucket_order=0
[ 0.813813] zbud: loaded
[ 0.814625] integrity: Platform Keyring initialized
[ 0.815043] integrity: Machine keyring initialized
[ 0.821870] NET: Registered PF_ALG protocol family
[ 0.822280] xor: automatically using best checksumming function avx
[ 0.822867] Key type asymmetric registered
[ 0.823213] Asymmetric key parser 'x509' registered
[ 0.953439] Freeing initrd memory: 18404K
[ 0.957002] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.957739] io scheduler mq-deadline registered
[ 0.958131] io scheduler kyber registered
[ 0.958486] io scheduler bfq registered
[ 0.959879] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 0.961284] pcieport 0000:00:01.0: PME: Signaling with IRQ 24
[ 0.961916] pcieport 0000:00:01.0: AER: enabled with IRQ 24
[ 0.963208] pcieport 0000:00:01.1: PME: Signaling with IRQ 25
[ 0.963796] pcieport 0000:00:01.1: AER: enabled with IRQ 25
[ 0.965015] pcieport 0000:00:01.2: PME: Signaling with IRQ 26
[ 0.965619] pcieport 0000:00:01.2: AER: enabled with IRQ 26
[ 0.966835] pcieport 0000:00:01.3: PME: Signaling with IRQ 27
[ 0.967422] pcieport 0000:00:01.3: AER: enabled with IRQ 27
[ 0.968642] pcieport 0000:00:01.4: PME: Signaling with IRQ 28
[ 0.969238] pcieport 0000:00:01.4: AER: enabled with IRQ 28
[ 0.970470] pcieport 0000:00:01.5: PME: Signaling with IRQ 29
[ 0.971043] pcieport 0000:00:01.5: AER: enabled with IRQ 29
[ 0.972256] pcieport 0000:00:01.6: PME: Signaling with IRQ 30
[ 0.972860] pcieport 0000:00:01.6: AER: enabled with IRQ 30
[ 0.974071] pcieport 0000:00:01.7: PME: Signaling with IRQ 31
[ 0.974666] pcieport 0000:00:01.7: AER: enabled with IRQ 31
[ 0.975479] ACPI: \_SB_.GSIG: Enabled at IRQ 22
[ 0.976338] pcieport 0000:00:02.0: PME: Signaling with IRQ 32
[ 0.976920] pcieport 0000:00:02.0: AER: enabled with IRQ 32
[ 0.977550] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.978200] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 0.978871] ACPI: button: Power Button [PWRF]
[ 0.984739] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.985407] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.988072] Non-volatile memory driver v1.3
[ 0.988812] Linux agpgart interface v0.103
[ 0.989295] ACPI: bus type drm_connector registered
[ 0.990341] ACPI: \_SB_.GSIA: Enabled at IRQ 16
[ 0.991141] ahci 0000:00:1f.2: AHCI 0001.0000 32 slots 6 ports 1.5 Gbps 0x3f impl SATA mode
[ 0.991849] ahci 0000:00:1f.2: flags: 64bit ncq only
[ 0.993168] scsi host0: ahci
[ 0.993616] scsi host1: ahci
[ 0.994058] scsi host2: ahci
[ 0.994439] scsi host3: ahci
[ 0.994807] scsi host4: ahci
[ 0.995190] scsi host5: ahci
[ 0.995490] ata1: SATA max UDMA/133 abar m4096@0x81a40000 port 0x81a40100 irq 35 lpm-pol 0
[ 0.996176] ata2: SATA max UDMA/133 abar m4096@0x81a40000 port 0x81a40180 irq 35 lpm-pol 0
[ 0.996865] ata3: SATA max UDMA/133 abar m4096@0x81a40000 port 0x81a40200 irq 35 lpm-pol 0
[ 0.997548] ata4: SATA max UDMA/133 abar m4096@0x81a40000 port 0x81a40280 irq 35 lpm-pol 0
[ 0.998235] ata5: SATA max UDMA/133 abar m4096@0x81a40000 port 0x81a40300 irq 35 lpm-pol 0
[ 0.998918] ata6: SATA max UDMA/133 abar m4096@0x81a40000 port 0x81a40380 irq 35 lpm-pol 0
[ 1.000509] xhci_hcd 0000:01:00.6: xHCI Host Controller
[ 1.001004] xhci_hcd 0000:01:00.6: new USB bus registered, assigned bus number 1
[ 1.002165] xhci_hcd 0000:01:00.6: hcc params 0x00087001 hci version 0x100 quirks 0x0000000000000010
[ 1.003338] xhci_hcd 0000:01:00.6: xHCI Host Controller
[ 1.003837] xhci_hcd 0000:01:00.6: new USB bus registered, assigned bus number 2
[ 1.004459] xhci_hcd 0000:01:00.6: Host supports USB 3.0 SuperSpeed
[ 1.005032] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[ 1.005722] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.006325] usb usb1: Product: xHCI Host Controller
[ 1.006743] usb usb1: Manufacturer: Linux 6.8.4-200.fc39.x86_64 xhci-hcd
[ 1.007302] usb usb1: SerialNumber: 0000:01:00.6
[ 1.007813] hub 1-0:1.0: USB hub found
[ 1.008151] hub 1-0:1.0: 8 ports detected
[ 1.008731] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.009428] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[ 1.010115] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.010721] usb usb2: Product: xHCI Host Controller
[ 1.011140] usb usb2: Manufacturer: Linux 6.8.4-200.fc39.x86_64 xhci-hcd
[ 1.011699] usb usb2: SerialNumber: 0000:01:00.6
[ 1.012172] hub 2-0:1.0: USB hub found
[ 1.012511] hub 2-0:1.0: 8 ports detected
[ 1.013074] usbcore: registered new interface driver usbserial_generic
[ 1.013625] usbserial: USB Serial support registered for generic
[ 1.014157] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 1.015316] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.015903] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.016388] mousedev: PS/2 mouse device common for all mice
[ 1.016941] rtc_cmos 00:03: RTC can wake from S4
[ 1.017549] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 1.018446] rtc_cmos 00:03: registered as rtc0
[ 1.018864] rtc_cmos 00:03: setting system clock to 2024-04-06T14:00:32 UTC (1712412032)
[ 1.019575] rtc_cmos 00:03: alarms up to one day, y3k, 242 bytes nvram
[ 1.020130] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 1.021154] device-mapper: uevent: version 1.0.3
[ 1.021784] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 1.022642] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input4
[ 1.023511] amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
[ 1.023523] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input3
[ 1.024415] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[ 1.032890] Console: switching to colour frame buffer device 160x50
[ 1.033931] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 1.035053] hid: raw HID events driver (C) Jiri Kosina
[ 1.035650] usbcore: registered new interface driver usbhid
[ 1.036111] usbhid: USB HID core driver
[ 1.036568] drop_monitor: Initializing network drop monitor service
[ 1.037160] Initializing XFRM netlink socket
[ 1.037574] NET: Registered PF_INET6 protocol family
[ 1.041665] Segment Routing with IPv6
[ 1.042000] RPL Segment Routing with IPv6
[ 1.042358] In-situ OAM (IOAM) with IPv6
[ 1.042729] mip6: Mobile IPv6
[ 1.042983] NET: Registered PF_PACKET protocol family
[ 1.043808] IPI shorthand broadcast: enabled
[ 1.044192] AVX2 version of gcm_enc/dec engaged.
[ 1.044627] AES CTR mode by8 optimization enabled
[ 1.047106] sched_clock: Marking stable (824000940, 222186181)->(1169148429, -122961308)
[ 1.048461] registered taskstats version 1
[ 1.049450] Loading compiled-in X.509 certificates
[ 1.054365] Loaded X.509 cert 'Fedora kernel signing key: 850daac805510654994f4e4c7ecd8132257a7c81'
[ 1.058373] page_owner is disabled
[ 1.058784] Key type .fscrypt registered
[ 1.059146] Key type fscrypt-provisioning registered
[ 1.060456] Btrfs loaded, zoned=yes, fsverity=yes
[ 1.060896] Key type big_key registered
[ 1.073576] Key type encrypted registered
[ 1.075245] ima: No TPM chip found, activating TPM-bypass!
[ 1.075957] Loading compiled-in module X.509 certificates
[ 1.076848] Loaded X.509 cert 'Fedora kernel signing key: 850daac805510654994f4e4c7ecd8132257a7c81'
[ 1.078820] ima: Allocated hash algorithm: sha256
[ 1.079838] ima: No architecture policies found
[ 1.080571] evm: Initialising EVM extended attributes:
[ 1.081166] evm: security.selinux
[ 1.081632] evm: security.SMACK64 (disabled)
[ 1.082145] evm: security.SMACK64EXEC (disabled)
[ 1.082693] evm: security.SMACK64TRANSMUTE (disabled)
[ 1.083268] evm: security.SMACK64MMAP (disabled)
[ 1.083810] evm: security.apparmor (disabled)
[ 1.084328] evm: security.ima
[ 1.084729] evm: security.capability
[ 1.085174] evm: HMAC attrs: 0x1
[ 1.113487] alg: No test for 842 (842-scomp)
[ 1.115225] alg: No test for 842 (842-generic)
[ 1.174419] PM: Magic number: 4:882:29
[ 1.175091] memory memory69: hash matches
[ 1.179736] RAS: Correctable Errors collector initialized.
[ 1.180941] clk: Disabling unused clocks
B^[[B^[[B^[[B^[[A^[[A[ 1.308035] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.308927] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.309549] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.310129] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.310699] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.311653] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.313445] Freeing unused decrypted memory: 2028K
[ 1.315189] Freeing unused kernel image (initmem) memory: 4620K
[ 1.315883] Write protecting the kernel read-only data: 36864k
[ 1.317234] Freeing unused kernel image (rodata/data gap) memory: 1584K
[ 1.346232] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.347829] Run /init as init process
[ 1.363154] systemd[1]: systemd 254.10-1.fc39 running in system mode (+PAM +AUDIT +SELINUX -APPARMOR +IMA +SMACK +SECCOMP -GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN -IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 1.365743] systemd[1]: Detected virtualization kvm.
[ 1.367262] systemd[1]: Detected architecture x86-64.
[ 1.367890] systemd[1]: Running in initrd.
Welcome to Fedora Linux 39 dracut-059-16.fc39 (Initramfs)!
[ 1.369212] systemd[1]: Hostname set to <k8s-01-001>.
[ 1.410798] systemd[1]: Queued start job for default target initrd.target.
[ 1.418569] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ OK ] Started systemd-ask-password-conso…equests to Console Directory Watch.
[ 1.420278] systemd[1]: Expecting device dev-loop0p2.device - /dev/loop0p2...
[ 1.421456] systemd[1]: Reached target initrd-usr-fs.target - Initrd /usr File System.
[ OK ] Reached target initrd-usr-fs.target - Initrd /usr File System.
[ 1.422967] systemd[1]: Reached target paths.target - Path Units.
[ OK ] Reached target paths.target - Path Units.
[ 1.424233] systemd[1]: Reached target slices.target - Slice Units.
[ OK ] Reached target slices.target - Slice Units.
[ 1.425495] systemd[1]: Reached target swap.target - Swaps.
[ OK ] Reached target swap.target - Swaps.
[ 1.426668] systemd[1]: Reached target timers.target - Timer Units.
[ OK ] Reached target timers.target - Timer Units.
[ 1.428032] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ OK ] Listening on systemd-journald-dev-…socket - Journal Socket (/dev/log).
[ 1.429784] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ OK ] Listening on systemd-journald.socket - Journal Socket.
[ 1.431315] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ OK ] Listening on systemd-udevd-control.socket - udev Control Socket.
[ 1.432901] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ OK ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 1.434387] systemd[1]: Reached target sockets.target - Socket Units.
[ OK ] Reached target sockets.target - Socket Units.
[ 1.451277] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
Starting kmod-static-nodes.service…eate List of Static Device Nodes...
[ 1.453140] systemd[1]: memstrack.service - Memstrack Anylazing Service was skipped because no trigger condition checks were met.
[ 1.455201] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 1.456512] systemd[1]: systemd-modules-load.service - Load Kernel Modules was skipped because no trigger condition checks were met.
[ 1.458033] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[ 1.459881] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
Starting systemd-tmpfiles-setup-de…eate Static Device Nodes in /dev...
[ 1.462422] systemd[1]: Starting systemd-vconsole-setup.service - Virtual Console Setup...
[ 1.464960] systemd-journald[275]: Collecting audit messages is disabled.
[ 1.466980] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ OK ] Finished kmod-static-nodes.service…Create List of Static Device Nodes.
[ 1.468744] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[ OK ] Finished systemd-sysctl.service - Apply Kernel Variables.
[ 1.471650] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[ OK ] Finished systemd-tmpfiles-setup-de…Create Static Device Nodes in /dev.
[ 1.473354] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[ OK ] Reached target local-fs-pre.target…Preparation for Local File Systems.
[ 1.475231] systemd[1]: Reached target local-fs.target - Local File Systems.
[ OK ] Reached target local-fs.target - Local File Systems.
[ 1.493884] systemd[1]: Started systemd-journald.service - Journal Service.
[ OK ] Started systemd-journald.service - Journal Service.
[ OK ] Finished systemd-vconsole-setup.service - Virtual Console Setup.
Starting dracut-cmdline.service - dracut cmdline hook...
Starting systemd-tmpfiles-setup.se…e Volatile Files and Directories...
[ OK ] Finished systemd-tmpfiles-setup.se…ate Volatile Files and Directories.
[ OK ] Finished dracut-cmdline.service - dracut cmdline hook.
Starting systemd-udevd.service - R…ager for Device Events and Files...
[ OK ] Started systemd-udevd.service - Ru…anager for Device Events and Files.
Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ OK ] Created slice system-modprobe.slice - Slice /system/modprobe.
Starting modprobe@configfs.service - Load Kernel Module configfs...
[ OK ] Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[ OK ] Finished modprobe@configfs.service - Load Kernel Module configfs.
Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ OK ] Reached target remote-fs-pre.targe…reparation for Remote File Systems.
[ OK ] Reached target remote-fs.target - Remote File Systems.
Starting dracut-pre-mount.service - dracut pre-mount hook...
[ OK ] Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ OK ] Reached target sysinit.target - System Initialization.
[ OK ] Reached target basic.target - Basic System.
[ OK ] Finished dracut-pre-mount.service - dracut pre-mount hook.
[ 1.670273] virtio_scsi virtio6: 1/0/0 default/read/poll queues
[ 1.678653] scsi host6: Virtio SCSI HBA
[ 1.687164] scsi 6:0:0:1: Direct-Access QEMU QEMU HARDDISK 2.5+ PQ: 0 ANSI: 5
[ OK ] Stopped systemd-vconsole-setup.service - Virtual Console Setup.
Stopping systemd-vconsole-setup.service - Virtual Console Setup...
[ 1.699612] sd 6:0:0:1: Attached scsi generic sg0 type 0
[ 1.699709] sd 6:0:0:1: Power-on or device reset occurred
[ 1.700832] sd 6:0:0:1: [sda] 268435456 512-byte logical blocks: (137 GB/128 GiB)
[ 1.701699] sd 6:0:0:1: [sda] Write Protect is off
[ 1.702396] sd 6:0:0:1: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ OK ] Stopped systemd-vconsole-setup.service - Virtual Console Setup.[ 1.709975] sda: sda1 sda2
[ 1.710710] sd 6:0:0:1: [sda] Attached SCSI disk
[ *] Job dev-loop0p2.device/start running (4min 53s / no limit)
- Container log
Status: RUNNING
Type: virtual-machine
PID: 385003
Created: 2024/04/05 11:01 EDT
Last Used: 2024/04/06 10:00 EDT
Resources:
Processes: -1
Disk usage:
root: 9.57GiB
Log:
- Container configuration
boot.autostart: "false"
image.architecture: amd64
image.description: Fedora 39 amd64 (20240405_20:33)
image.os: Fedora
image.release: "39"
image.serial: "20240405_20:33"
image.type: disk-kvm.img
image.variant: default
limits.cpu: "4"
limits.memory: 8GiB
volatile.base_image: <redacted>
volatile.cloud-init.instance-id: <redacted>
volatile.eth0.host_name: maca<redacted>
volatile.eth0.hwaddr: <redacted>
volatile.eth0.last_state.created: "false"
volatile.uuid: <redacted>
volatile.uuid.generation: 06473eb7-97f4-451b-b969-fc0cac66c883
volatile.vsock_id: "978000521"
network: <redacted>
pool: ssd0
- <redacted>
- <redacted>
