VM won't boot after power cut / restart on Incus 6.17
I’m facing issue with VM that don’t boot after power cut by mistake
the VM freeze to
 Booting \`Rocky Linux (5.14.0-427.24.1.el9_4.x86_64) 9.4 (Blue Onyx)'
!!!! X64 Exception Type - 0E(#PF - Page-Fault)  CPU Apic ID - 00000000 !!!!
ExceptionData - 0000000000000003  I:0 R:0 U:0 W:1 P:1 PK:0 SS:0 SGX:0
RIP  - 000000007529A920, CS  - 0000000000000038, RFLAGS - 0000000000210006
RAX  - 00000000752B3000, RCX - 00000000752B3000, RDX - 0000000000024000
RBX  - 000000007C9A9500, RSP - 000000007EE9C228, RBP - 000000007D437A18
RSI  - 0000000000000000, RDI - 00000000752B3000
R8   - 00000000752D7000, R9  - 000000007AC8B6FD, R10 - 000000007C42EDB9
R11  - 0000000000000077, R12 - 000000007E9EC018, R13 - 000000007D106000
R14  - 000000007C9A8768, R15 - 000000007C9A8770
DS   - 0000000000000030, ES  - 0000000000000030, FS  - 0000000000000030
GS   - 0000000000000030, SS  - 0000000000000030
CR0  - 0000000080010033, CR2 - 00000000752B3000, CR3 - 000000007EC01000
CR4  - 0000000000000668, CR8 - 0000000000000000
DR0  - 0000000000000000, DR1 - 0000000000000000, DR2 - 0000000000000000
DR3  - 0000000000000000, DR6 - 00000000FFFF0FF0, DR7 - 0000000000000400
GDTR - 000000007E9E1000 0000000000000047, LDTR - 0000000000000000
IDTR - 000000007E025018 0000000000000FFF,   TR - 0000000000000000
FXSAVE_STATE - 000000007EE9BE80
!!!! Find image based on IP(0x7529A920) (No PDB)  (ImageBase=0000000001091170, EntryPoint=0000000001091997) !!!!
I didn’t change anything in VM configuration and incus version is
Client version: 6.17
Server version: 6.17
VM config:
  image.architecture: amd64
  image.description: Rockylinux 9 amd64 (20240717_02:06)
  image.os: Rockylinux
  image.release: '9'
  image.requirements.cdrom_agent: 'true'
  image.serial: '20240717_02:06'
  image.type: disk-kvm.img
  image.variant: cloud
  limits.cpu: '2'
  limits.memory: 4GiB
  volatile.base_image: 673712181ebe86f060a0170257841c7507b773e4a1e2df3d502d3cd26a3b5aab
  volatile.cloud-init.instance-id: 99bc53d7-60e4-41f8-ab52-c7a47a32f233
  volatile.eth0.host_name: tap7a0b7a13
  volatile.eth0.hwaddr: 00:16:3e:9b:ca:4f
  volatile.last_state.ready: 'false'
  volatile.uuid: 6c547028-d137-4405-bd60-c4813f9af9bd
  volatile.uuid.generation: 6c547028-d137-4405-bd60-c4813f9af9bd
  volatile.vm.definition: pc-q35-9.0
  volatile.vm.rtc_adjustment: '-13'
  volatile.vm.rtc_offset: '-1'
  volatile.vsock_id: '2861442233'
  agent:
    source: agent:config
description: ''
created_at: '2024-07-18T01:08:25.789231116Z'
status: Running
status_code: 103
last_used_at: '2025-09-27T14:01:04.776600152Z'
type: virtual-machine
project: default
Actually I don’t know if this related to recent versions of incus, VM packages or Power cut
I know power cut happen many times before and I didn’t face this issue
Got the same issue here, so I’m suspecting EDK2.
We bumped the version of EDK2 following some cherry-picks to try to handle RedHat based guests, but apparently the cherry-picks weren’t sufficient…
I think I found the issue in our packaging of the workaround.
I just pushed a new daily build now, after that’s built and is confirmed to fix it here, I’ll push it to stable too.
fix confirmed, I just upgraded (somehow apt display it as downgrade) to 1:0~debian13~202509281046 and it resolve the issue
thank you @stgraber
Yep, confirmed it working here too on the daily builds. I’m now pushing this to stable too.
The stable update has been pushed now and should be hitting users within the next 30 minutes
