After an automatic refresh of LXD, my VM seems to be stopped:
root@n3:/home/ubuntu# lxc info v1
Remote: unix://
Created: 2020/01/23 11:41 UTC
Status: Stopped
Type: virtual-machine
Profiles: vm
I get this error when I try to start it:
root@n3:/home/ubuntu# lxc start v1
Error: Failed to run: /snap/lxd/current/bin/lxd forklimits limit=memlock:unlimited:unlimited – /snap/lxd/13439/bin/qemu-system-x86_64 -S -name v1 -uuid 8e085ed3-6437-4166-9707-548d725ab638 -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-reboot -no-user-config -sandbox on,obsolete=deny,elevateprivileges=allow,spawn=deny,resourcecontrol=deny -readconfig /var/snap/lxd/common/lxd/logs/v1/qemu.conf -pidfile /var/snap/lxd/common/lxd/logs/v1/qemu.pid -D /var/snap/lxd/common/lxd/logs/v1/qemu.log -chroot /var/snap/lxd/common/lxd/virtual-machines/v1 -runas lxd: : exit status 1
Trylxc info --show-log v1
for more info
The logs says:
qemu-system-x86_64:/var/snap/lxd/common/lxd/logs/v1/qemu.conf:115: vhost-vsock: unable to set guest cid: Address already in use
And indeed the address is in use because I can still find the qemu process:
root@n3:/home/ubuntu# ps aux | grep v1
lxd 11045 44.5 3.5 20563560 7015600 ? Sl Feb05 12823:09 qemu-system-x86_64 -S -name v1 -uuid 8e085ed3-6437-4166-9707-548d725ab638 -daemonize -cpu host -nographic -serial chardev:console -nodefaults -no-reboot -no-user-config -readconfig /var/snap/lxd/common/lxd/logs/v1/qemu.conf -pidfile /var/snap/lxd/common/lxd/logs/v1/qemu.pid -D /var/snap/lxd/common/lxd/logs/v1/qemu.log -chroot /var/snap/lxd/common/lxd/virtual-machines/v1 -runas lxd
Is this normal behavior ? How can I make LXC aware that the VM is still running without having to kill the process and restart the VM ?
Thanks for your help.
Léo
