Wait for incus agent
$ incus start outer   # this was created with --vm
$ incus shell outer
Error while executing alias expansion: incus exec outer -- su -l
Error: VM agent isn't currently running
I have to keep repeating the command until it works.
It would be really nice to have a way to wait until the incus agent is running; perhaps a --wait flag to incus start and incus launch. Or am I missing some feature that already exists? I’m using 6.0.3 LTS
Cheers,
Brian.
I second this. I actually use a little script to achieve this, but --wait would be MUCH better.
Here’s me starting a stopped vm, and gaining a shell. Once you exit, it takes you back to your prompt as usual. Simple. Not elegant. But it stops me guessing and spamming my terminal when I am impatient. :slight_smile:
andrew@Yoda:~$ incus list vm
| NAME |  STATE  | IPV4 | IPV6 |      TYPE       | SNAPSHOTS |
| vm   | STOPPED |      |      | VIRTUAL-MACHINE | 0         |
andrew@Yoda:~$ launch vm
vm
Waiting for incus agent to become active...
root@vm:~# #User your shell as normal
root@vm:~# exit
logout
Here’s my simple script:
#!/bin/bash
incus start "$1"
echo "Waiting for incus agent to become active..."
running=false
while ! $running; do
	incus exec $1  -- echo  2>/dev/null
	if [ $? -eq 0 ]; then
		sleep 1
		break;
	else
		sleep 0.5
	fi
done
incus shell "$1"
The loop checks for the shell access every half a second and won’t quit until it works.
V/R
Andrew
I think I mentioned this a few times on the forum as this is a pretty common question, but basically Incus itself has no idea whether the agent is running or not.
There is no persistent connection going on between the agent and Incus as otherwise we’d have some scalability issues when systems run thousands or tens of thousands of VMs as that would lead to a LOT of go routines, open files, …
So basically whenever you ask for data that involves the Incus agent, Incus tries to connect to it at that point, but it otherwise doesn’t touch the agent and so can’t get you a convenient “wait” type endpoint (other than have itself do the loop internally).
I think that’s what we’re asking for :slight_smile:
So because it’s raining in Florida today, I played at my terminal and modified my lazy script to be potentially more useful. This is it in action:
andrew@Yoda:~$ launch images:debian/12 vz --vm -c limits.cpu=2 -c limits.memory=4GiB --profile=br0
Waiting for incus agent to become active in Instance vz......................
root@vz:~# exit
logout
And with my limited testing it seems to pull the parameters over properly:
andrew@Yoda:~$ incus config show vz
  image.architecture: amd64
  image.description: Debian bookworm amd64 (20250224_05:24)
  image.os: Debian
  image.release: bookworm
  image.serial: "20250224_05:24"
  image.type: disk-kvm.img
  image.variant: default
  limits.cpu: "2"
  limits.memory: 4GiB
  volatile.base_image: 33459dcfec716681ec94e4c5068dba3c9163cb4735c508db3eed80e92b23cae6
  volatile.cloud-init.instance-id: ac541576-7316-413c-a403-4622dd48ffaa
  volatile.eth0.host_name: tap2adb79d0
  volatile.eth0.hwaddr: 00:16:3e:38:e7:4e
  volatile.uuid: 77dacc82-031e-4b29-b356-b90e6c08fbfc
  volatile.uuid.generation: 77dacc82-031e-4b29-b356-b90e6c08fbfc
  volatile.vsock_id: "2730131791"
devices: {}
- br0
The script is shown below. You can save it as a bash script or even add it to your .bashrc file as a function (which is what I have done). It’s still not as a good as a --wait feature, but I think Stephane does a lot for us, so this is maybe at least somewhat useful in the interim and allows him to focus on the big ticket items.
#!/bin/bash
# No warranty!
output=$(incus launch $@)
instance=$(echo "$output" | grep -o "Launching.*" | cut -d " " -f 2)
echo -n "Waiting for incus agent to become active in Instance $instance..."
running=false
        incus exec $instance  -- echo  2>/dev/null
                break;
        else
                echo -n "."
                sleep 0.5
        fi
done
incus shell "$instance"
V/R
Andrew
I did read several similar request in this forum in past already. This means this problem is valued not for the single person and it probably needs more attention from the Incus team.
Inability to know the status of VM forces to prepare client based workarounds which increases client side complexity and decrease supportability.
However, adding agent-status object to /1.0/instances/{name}/state API call, incus-agent status output in incus info <instance> command and adding agent-status field into incus terraform resource "incus_instance" "<instance>"could help to solving such problems in more simple manner.
The common way to get the agent status from /1.0/instances/NAME/state is to look for the processes field, if it’s > 0 then the agent is running.
That’s the same logic that’s used by the Terraform provider and others to check on the agent.
Thank you Stephane for the confirmation that processes field could be used as incus-agent ready with the RestAPI and cli calls.
However, terraform provider does not check communication with the incus-agent yet and report Running status when qemu reports that VM is running or when IP address is received by any interface if wait_for_network argument is true.
Steps to reproduce:
  • prepare configuration for terraform or OpenTofu
main.tf
terraform {
  required_providers {
    incus = {
      source = "lxc/incus"
      version = "0.2.0"
provider "incus" {
  # Configuration options
resource "incus_instance" "instance1" {
  name     = "instance1"
  image    = "images:alpine/edge/amd64"
  profiles = ["default"]
  type = "virtual-machine"
  wait_for_network ="true"
  config = {
    "security.secureboot" = "false"
    "user.access_interface" = "eth0"
  • Apply configuration using terraform apply or tofu apply command. Configuration will be applied when IPv4 address is assigned to eth0 interface (I use default settings for incusbr0 network)
  • Disable incus-agent and incus-agent-services for startup in the VM using incus exec instance1 -- sh -c "rc-update del incus-agent; rc-update del incus-agent-setup and stop the VM after that. (Note: Access to the VM will be lost after reboot. Please set root password before reboot if you need access to VM using incus console instance1).
  • re-apply configuration using terraform apply or tofu apply command. Configuration will be applied when IPv4 address is assigned to eth0 interface (even incus-agent is not run).
  • Check whether incus-agent run or not using incus info instance1.
P.S.
Terraform now is less usable now than RestAPI or cli as it still not support exec configuration attribute (Allow executing commands following creation in incus_instance).
running = true in Terraform uses isInstanceOperational which does check for processes > 0.
But anyway, the entire waiting mechanism in Terraform is being reworked now ahead of the 1.0 of the provider and will have the ability to specifically wait for the agent (as well as network on specific interfaces and more).
I’m glad to hear you are heading to a stable release of terraform provider! That would be nice to get working features like:
  • commands execution in the containers/VMs
  • managing files in offline VMs and Storage Volumes (with ability to populate files and symlinks before instance starts)
  • etc.
Unfortunately, the incus_instance.<instance>.running resource always return true when VM started successfuly even though the incus-agent does not run or incusd can’t communicate with it.
Should I create bug for this?
Probably best to hold off until after this entire logic is replaced with the new wait_for syntax. @maveonair was saying he’s hoping to get the remaining bits sorted this weekend.
Using your logic I created a bash function to wait for the agent to start.
# Wait for instance to start function
wait_for_processes() {
  local instance="$1"
  echo "Waiting for agent to start..."
  while true; do
    local processes
    processes=$(incus query /1.0/instances/$instance/state | jq '.processes')
    if [ $processes -gt 0 ]; then
      echo "Agent is running for instance '$instance'."
      break
    fi
    sleep 1
  done
So I’m using it to create a vm instance, install incus, stop it, snapshot, restart and shell which comes out to the following.
image="images:debian/12"
instance="server"
  local instance="$1"
  while true; do
    local processes
      break
    fi
    sleep 1
  done
echo "Launching '$instance' vm instance."
incus launch $image $instance --vm
wait_for_processes $instance
echo "Running Zabbly install script in '$instance' instance."
incus exec $instance -- apt update
incus exec $instance -- apt install curl -y
incus exec $instance -- mkdir -p /etc/apt/keyrings/
incus exec $instance -- curl -fsSL https://pkgs.zabbly.com/key.asc -o /etc/apt/keyrings/zabbly.asc
incus exec $instance -- sh -c 'cat <<EOF > /etc/apt/sources.list.d/zabbly-incus-stable.sources
Enabled: yes
Types: deb
URIs: https://pkgs.zabbly.com/incus/stable
Suites: $(. /etc/os-release && echo ${VERSION_CODENAME})
Components: main
Architectures: $(dpkg --print-architecture)
Signed-By: /etc/apt/keyrings/zabbly.asc
EOF'
incus exec $instance -- apt install incus -y
echo "Initializing incus in '$instance' instance."
incus exec $instance -- incus admin init --auto
echo "Stopping '$instance' to create incus snapshot."
incus stop $instance
incus snapshot create $instance incus
echo "Restarting '$instance' vm instance."
incus start $instance
echo "Shell into '$instance' instance."
incus shell $instance
Aside: cloud-init is quite neat for this sort of scripted setup, once you’ve got your head around it a bit.
#!/bin/bash -eu
image="images:debian/12/cloud"
instance="server"
  local instance="$1"
  while true; do
    local processes
      break
    fi
    sleep 1
  done
incus launch $image $instance --vm <<EOS
  cloud-init.user-data: |
    #cloud-config
    disable_root: false
    users: []
    #ssh_authorized_keys:
    #  - ssh-rsa blah....
    #write_files:
    #  - path: /etc/blah
    #    content: |
    #      Blah
    #      Blah
    package_update: true
    packages:
      - curl
    runcmd:
      - # etc
EOS
# Wait for cloud-init to finish
rc=0
incus exec "$instance" -- cloud-init status --wait || rc="$?"
if [ "$rc" -ne 0 -a "$rc" -ne 2 ]; then
  echo "*** cloud-init failed ($rc) ***"
  exit 1
fi
If you add --format json after --wait then instead of a series of dots, you get a detailed report of cloud-init status:
# ./test.sh
Launching 'server' vm instance.
Launching server
Agent is running for instance 'server'.
  "_schema_version": "1",
  "boot_status_code": "enabled-by-generator",
  "datasource": "nocloud",
  "detail": "DataSourceNoCloud [seed=/var/lib/cloud/seed/nocloud-net][dsmode=net]",
  "errors": [],
  "last_update": "Fri, 11 Jul 2025 19:48:57 +0000",
  "schemas": {
    "1": {
      "errors": [],
      "status": "done"
  "status": "done"
Note that cloud-init status can give a return code of 2 for partial success, which in some cases may be a warning you can ignore. e.g.
  "recoverable_errors": {
    "WARNING": [
      "Device '/dev/a9b3ae14-6fde-4a11-826e-45f8d766ee67' did not exist. cannot resize: dev=a9b3ae14-6fde-4a11-826e-45f8d766ee67 mnt_point=/ path=rpool"
For these, who has a VM in a non-default project:
Error: Failed to fetch instance “my-vm” in project “default”: Instance not found
Change the line with incus query to:
    processes="$(incus query "/1.0/instances/$instance/state?filter=&project=your-project-name" | jq '.processes')"
