Hello, my plan was to build a container which contains an Archlinux system to run a full wayland plasma desktop environment (DE).
I’ve been able to run a fully working instance thanks to the configuration detailed below AND the use of the ‘security.privileged=true’ mode starting the plasma session directly from TTY2.
My problem is that I don’t want to leave the ‘security.privileged=true’ mode always activated to replace it by the only permissions needed.
To achieve this, I’ve been trying to reproduce the ‘privileged’ mode with a dedicated profile(see below) to then reduce it to the strict minimum but every of my (numerous) attempts failed like this:
user@PLASMA>startplasma-wayland
startplasma-wayland: Shutting down...
startplasmacompositor: Shutting down...
startplasmacompositor: Done.
With the ‘journalctl’ error:
user@PLASMA>journalctl -b0 | grep "kwin_wayland\|systemd-logind"
PLASMA kwin_wayland[497]: No backend specified, automatically choosing drm
PLASMA systemd-logind[402]: Cannot set K_OFF on /dev/tty2: Operation not permitted
PLASMA systemd-logind[402]: Failed to restore VT, ignoring: Operation not permitted
PLASMA kwin_wayland[497]: kwin_core: Failed to take control of /org/freedesktop/login1/session/c1 session. Maybe another compositor is running?
PLASMA kwin_wayland[497]: kwin_wayland_drm: failed to open drm device at "/dev/dri/card2"
PLASMA kwin_wayland[497]: kwin_wayland_drm: failed to open drm device at "/dev/dri/card1"
PLASMA kwin_wayland[497]: kwin_wayland_drm: No suitable DRM devices have been found
Here is the profile used attempting to simulate the ‘privileged’ option:
>incus profile show dbg
raw.lxc: |
lxc.mount.auto=proc sys cgroup
lxc.apparmor.profile=unconfined
lxc.cap.keep = chown dac_override fsetid fowner mknod net_raw setgid setuid setfcap setpcap mac_admin net_admin net_bind_service sys_admin sys_chroot kill audit_control audit_read audit_write syslog bpf dac_read_search ipc_lock ipc_owner linux_immutable mac_admin mac_override net_broadcast sys_nice sys_pacct sys_resource sys_time sys_tty_config sys_ptrace sys_boot lease wake_alarm block_suspend perfmon
security.nesting: "true"
security.syscalls.intercept.bpf: "true"
security.syscalls.intercept.bpf.devices: "true"
security.syscalls.intercept.mount: "true"
security.syscalls.intercept.mount.shift: "true"
security.syscalls.intercept.setxattr: "true"
dev-kfd:
gid: "989"
mode: "0666"
path: /dev/kfd
required: "false"
type: unix-char
- /1.0/instances/plasma
project: default
The configuration of the container is:
>incus config show -e
boot.autostart: "false"
environment.PULSE_COOKIE: /tmp/pulseaudio.cookie
environment.PULSE_SERVER: unix:/home/user/.tmp/pulseaudio.socket
image.architecture: x86_64
image.description: arc-rdgvpa + plasma & utilities for desktop use
image.name: archlinux-x86_64
image.os: archlinux
image.release: arc-plasma-256
image.serial: "20250926_2031"
image.variant: default
linux.kernel_modules: amdgpu,fuse
raw.idmap: both 0-65536 0-65536
raw.lxc: lxc.apparmor.profile=unconfined
volatile.base_image: 3de8f062179f9c6264a051b0caf2919ba0ceb663015b87fddc911c564da94760
volatile.cloud-init.instance-id: bb8e75c2-07a3-4897-aa35-fe5a8afe4d7a
volatile.eth0.host_name: veth60f4ed54
volatile.eth0.hwaddr: 10:66:6a:ed:bc:81
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":true,"Hostid":0,"Nsid":0,"Maprange":65537}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":true,"Hostid":0,"Nsid":0,"Maprange":65537}]'
volatile.uuid: aa4914a8-f71a-4e26-b27e-1f2a739c2e48
volatile.uuid.generation: aa4914a8-f71a-4e26-b27e-1f2a739c2e48
dev-dri-rd128:
gid: "989"
major: "226"
minor: "128"
mode: "0666"
path: /dev/dri/renderD128
type: unix-char
uid: "0"
dev-dri-rd129:
gid: "989"
major: "226"
minor: "129"
mode: "0666"
path: /dev/dri/renderD129
type: unix-char
uid: "0"
dev-input-evt0:
gid: "994"
mode: "0666"
path: /dev/input/event0
required: "false"
type: unix-char
dev-input-evt1:
gid: "994"
mode: "0666"
path: /dev/input/event1
required: "false"
type: unix-char
dev-input-evt2:
gid: "994"
mode: "0666"
path: /dev/input/event2
required: "false"
type: unix-char
dev-input-js0:
gid: "994"
mode: "0666"
path: /dev/input/js0
required: "false"
type: unix-char
dev-input-mice:
gid: "994"
mode: "0666"
path: /dev/input/mice
required: "false"
type: unix-char
dev-input-mouse0:
gid: "994"
mode: "0666"
path: /dev/input/mouse0
required: "false"
type: unix-char
dev-input-mouse1:
gid: "994"
mode: "0666"
required: "false"
type: unix-char
dev-kfd:
gid: "989"
mode: "0666"
path: /dev/kfd
required: "false"
type: unix-char
dri_card1:
gid: "985"
major: "226"
minor: "1"
mode: "0660"
path: /dev/dri/card1
type: unix-char
uid: "0"
dri_card2:
gid: "985"
major: "226"
minor: "2"
mode: "0660"
path: /dev/dri/card2
type: unix-char
uid: "0"
network: incusbr0
host:
path: /host
recursive: "true"
source: /guest/plasma
pasocket:
path: /home/user/.tmp/pulseaudio.socket
source: /run/user/1000/pulse/native
pool: main
tty:
gid: "5"
mode: "0620"
path: /dev/tty
source: /dev/tty
type: unix-char
tty2:
gid: "5"
mode: "0620"
path: /dev/tty2
source: /dev/tty2
type: unix-char
tty7:
gid: "5"
mode: "0620"
path: /dev/tty7
source: /dev/tty7
type: unix-char
udev:
path: /run/udev/data
source: /run/udev/data
- dbg
- run-udev-data
(please note that ‘/run/udev/data’ profile is mounted after the start of the instance since it’s located in a ramfs mount)
The container’s log is empty:
>incus info plasma --show-log
Description:
Status: RUNNING
Type: container
PID: 1547
Created: 2025/10/15 13:28 CEST
Last Used: 2025/10/15 13:28 CEST
Started: 2025/10/15 13:28 CEST
Resources:
Processes: 30
CPU usage:
CPU usage (in seconds): 3
Memory usage:
Memory (current): 1.02GiB
Network usage:
Type: broadcast
State: UP
Host interface: veth4442a63d
MAC address: 10:66:6a:4c:4c:cf
MTU: 1500
Bytes received: 15.88kB
Bytes sent: 14.94kB
Packets received: 86
Packets sent: 113
IP addresses:
inet: 10.177.1.93/24 (global)
inet6: fe80::1266:6aff:fe4c:4ccf/64 (link)
lo:
Type: loopback
State: UP
MTU: 65536
Bytes received: 0B
Bytes sent: 0B
Packets received: 0
Packets sent: 0
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
Log:
%s
Additionally, the environment once the user session is started and when ‘startplasma_wayland’ is issued is:
user@plasma>env|sort
container=lxc
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
DEBUGINFOD_URLS=https://debuginfod.archlinux.org
EDITOR=/usr/bin/nano
HOME=/home/user
LANG=en_US.UTF-8
LANGUAGE=en_US:en
LOGNAME=user
MAIL=/var/spool/mail/user
MOTD_SHOWN=pam
OLDPWD=/home/user
PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
PULSE_COOKIE=/tmp/pulseaudio.cookie
PULSE_SERVER=unix:/home/user/.tmp/pulseaudio.socket
PWD=/host
SHELL=/usr/bin/bash
SHLVL=2
SUDO_EDITOR=/usr/bin/nano
TERM=linux
USER=user
_=/usr/bin/env
XDG_DATA_DIRS=/home/user/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share
XDG_RUNTIME_DIR=/run/user/1000
XDG_SEAT=seat0
XDG_SESSION_CLASS=user
XDG_SESSION_ID=c1
XDG_SESSION_TYPE=tty
XDG_VTNR=2
Finally, the host hw/sw version:
OS: Arch Linux x86_64
Host: ASUS TUF Gaming A16 FA617NS_FA617NS 1.0
Kernel: 6.14.10-arch1-1
Packages: 1275 (pacman)
Shell: bash 5.2.37
CPU: AMD Ryzen 7 7735HS with Radeon Graphics (16) @ 4.830GHz
GPU: AMD ATI Radeon 680M
GPU: AMD ATI Radeon RX 7600/7600 XT/7600M XT/7600S/7700S / PRO W7600
Memory: 801MiB / 15219MiB
>pacman -Q | grep 'incus\|lxc'
incus 6.13.0-1
lxc 1:6.0.4-2
lxcfs 6.0.4-1
And the container packages:
>lxc exec plasma -- su - user -c "pacman -Q" | grep 'plasma\|wayland'
egl-wayland 4:1.1.19-1
kdeplasma-addons 6.3.5-1
kwayland 6.3.5-1
kwayland-integration 6.3.5-1
kwayland5 5.116.0-1
lib32-wayland 1.23.1-1
libplasma 6.3.5-1
plasma-activities 6.3.5-1
plasma-activities-stats 6.3.5-1
plasma-browser-integration 6.3.5-1
plasma-desktop 6.3.5-1
plasma-integration 6.3.5-2
plasma-nm 6.3.5-1
plasma-workspace 6.3.5-2
plasma5support 6.3.5-2
qt5-wayland 5.15.17+kde+r57-1
qt6-wayland 6.9.1-1
wayland 1.23.1-2
xorg-xwayland 24.1.6-1
xwayland-satellite 0.5.1-1
Using a ‘gpu’ type instead of the ‘/dev/dri’ unix-char device doesn’t work either.
I’ve also tried various ‘udevadm trigger’, ‘systemctl restart systemd-login.service’ commands from inside the container but it ended with no results.
After days of trying to solve around this ‘unprivileged’ issue, my main question will be:
Is reproducing the ‘privileged’ mode something that can be achieved using a configuration/profile?
If yes, can someone provide a reference for this ‘privileged’ profile (or a document which summarizes what this mode exactly do)?
Moreover, if somebody sees an error or has any hint on how to run this wayland DE container in ‘unprivileged’ mode, he will be my hero ![]()
