What can cause an "Error: Failed instance creation: Failed loading project: Project not found"?
I try to initialize incus with the following command, and that’s what I get:
~ $ incus launch images:debian/12 mydeb
Launching mydeb
It’s worth to mention that on my system (Debian 13) the incus log is located under /var/log/incus/incus.log and that this very file is empty.
When running it with --debug, that’s what I get:
time="2025-12-14T17:08:10+02:00" level=debug msg="Connecting to a local Incus over a Unix socket"
time="2025-12-14T17:08:10+02:00" level=debug msg="Sending request to Incus" etag= method=GET url="http://unix.socket/1.0"
time="2025-12-14T17:08:10+02:00" level=debug msg="Got response struct from Incus"
time="2025-12-14T17:08:10+02:00" level=debug msg="\n\t{\n\t\t\"config\": {},\n\t\t\"api_extensions\": [\n\t\t\t\"storage_zfs_remove_snapshots\",\n\t\t\t\"container_host_shutdown_timeout\",\n\t\t\t\"container_stop_priority\",\n\t\t\t\"container_syscall_filtering\",\n\t\t\t\"auth_pki\",\n\t\t\t\"container_last_used_at\",\n\t\t\t\"etag\",\n\t\t\t\"patch\",\n\t\t\t\"usb_devices\",\n\t\t\t\"https_allowed_credentials\",\n\t\t\t\"image_compression_algorithm\",\n\t\t\t\"directory_manipulation\",\n\t\t\t\"container_cpu_time\",\n\t\t\t\"storage_zfs_use_refquota\",\n\t\t\t\"storage_lvm_mount_options\",\n\t\t\t\"network\",\n\t\t\t\"profile_usedby\",\n\t\t\t\"container_push\",\n\t\t\t\"container_exec_recording\",\n\t\t\t\"certificate_update\",\n\t\t\t\"container_exec_signal_handling\",\n\t\t\t\"gpu_devices\",\n\t\t\t\"container_image_properties\",\n\t\t\t\"migration_progress\",\n\t\t\t\"id_map\",\n\t\t\t\"network_firewall_filtering\",\n\t\t\t\"network_routes\",\n\t\t\t\"storage\",\n\t\t\t\"file_delete\",\n\t\t\t\"file_append\",\n\t\t\t\"network_dhcp_expiry\",\n\t\t\t\"storage_lvm_vg_rename\",\n\t\t\t\"storage_lvm_thinpool_rename\",\n\t\t\t\"network_vlan\",\n\t\t\t\"image_create_aliases\",\n\t\t\t\"container_stateless_copy\",\n\t\t\t\"container_only_migration\",\n\t\t\t\"storage_zfs_clone_copy\",\n\t\t\t\"unix_device_rename\",\n\t\t\t\"storage_lvm_use_thinpool\",\n\t\t\t\"storage_rsync_bwlimit\",\n\t\t\t\"network_vxlan_interface\",\n\t\t\t\"storage_btrfs_mount_options\",\n\t\t\t\"entity_description\",\n\t\t\t\"image_force_refresh\",\n\t\t\t\"storage_lvm_lv_resizing\",\n\t\t\t\"id_map_base\",\n\t\t\t\"file_symlinks\",\n\t\t\t\"container_push_target\",\n\t\t\t\"network_vlan_physical\",\n\t\t\t\"storage_images_delete\",\n\t\t\t\"container_edit_metadata\",\n\t\t\t\"container_snapshot_stateful_migration\",\n\t\t\t\"storage_driver_ceph\",\n\t\t\t\"storage_ceph_user_name\",\n\t\t\t\"resource_limits\",\n\t\t\t\"storage_volatile_initial_source\",\n\t\t\t\"storage_ceph_force_osd_reuse\",\n\t\t\t\"storage_block_filesystem_btrfs\",\n\t\t\t\"resources\",\n\t\t\t\"kernel_limits\",\n\t\t\t\"storage_api_volume_rename\",\n\t\t\t\"network_sriov\",\n\t\t\t\"console\",\n\t\t\t\"restrict_dev_incus\",\n\t\t\t\"migration_pre_copy\",\n\t\t\t\"infiniband\",\n\t\t\t\"dev_incus_events\",\n\t\t\t\"proxy\",\n\t\t\t\"network_dhcp_gateway\",\n\t\t\t\"file_get_symlink\",\n\t\t\t\"network_leases\",\n\t\t\t\"unix_device_hotplug\",\n\t\t\t\"storage_api_local_volume_handling\",\n\t\t\t\"operation_description\",\n\t\t\t\"clustering\",\n\t\t\t\"event_lifecycle\",\n\t\t\t\"storage_api_remote_volume_handling\",\n\t\t\t\"nvidia_runtime\",\n\t\t\t\"container_mount_propagation\",\n\t\t\t\"container_backup\",\n\t\t\t\"dev_incus_images\",\n\t\t\t\"container_local_cross_pool_handling\",\n\t\t\t\"proxy_unix\",\n\t\t\t\"proxy_udp\",\n\t\t\t\"clustering_join\",\n\t\t\t\"proxy_tcp_udp_multi_port_handling\",\n\t\t\t\"network_state\",\n\t\t\t\"proxy_unix_dac_properties\",\n\t\t\t\"container_protection_delete\",\n\t\t\t\"unix_priv_drop\",\n\t\t\t\"pprof_http\",\n\t\t\t\"proxy_haproxy_protocol\",\n\t\t\t\"network_hwaddr\",\n\t\t\t\"proxy_nat\",\n\t\t\t\"network_nat_order\",\n\t\t\t\"container_full\",\n\t\t\t\"backup_compression\",\n\t\t\t\"nvidia_runtime_config\",\n\t\t\t\"storage_api_volume_snapshots\",\n\t\t\t\"storage_unmapped\",\n\t\t\t\"projects\",\n\t\t\t\"network_vxlan_ttl\",\n\t\t\t\"container_incremental_copy\",\n\t\t\t\"usb_optional_vendorid\",\n\t\t\t\"snapshot_scheduling\",\n\t\t\t\"snapshot_schedule_aliases\",\n\t\t\t\"container_copy_project\",\n\t\t\t\"clustering_server_address\",\n\t\t\t\"clustering_image_replication\",\n\t\t\t\"container_protection_shift\",\n\t\t\t\"snapshot_expiry\",\n\t\t\t\"container_backup_override_pool\",\n\t\t\t\"snapshot_expiry_creation\",\n\t\t\t\"network_leases_location\",\n\t\t\t\"resources_cpu_socket\",\n\t\t\t\"resources_gpu\",\n\t\t\t\"resources_numa\",\n\t\t\t\"kernel_features\",\n\t\t\t\"id_map_current\",\n\t\t\t\"event_location\",\n\t\t\t\"storage_api_remote_volume_snapshots\",\n\t\t\t\"network_nat_address\",\n\t\t\t\"container_nic_routes\",\n\t\t\t\"cluster_internal_copy\",\n\t\t\t\"seccomp_notify\",\n\t\t\t\"lxc_features\",\n\t\t\t\"container_nic_ipvlan\",\n\t\t\t\"network_vlan_sriov\",\n\t\t\t\"storage_cephfs\",\n\t\t\t\"container_nic_ipfilter\",\n\t\t\t\"resources_v2\",\n\t\t\t\"container_exec_user_group_cwd\",\n\t\t\t\"container_syscall_intercept\",\n\t\t\t\"container_disk_shift\",\n\t\t\t\"storage_shifted\",\n\t\t\t\"resources_infiniband\",\n\t\t\t\"daemon_storage\",\n\t\t\t\"instances\",\n\t\t\t\"image_types\",\n\t\t\t\"resources_disk_sata\",\n\t\t\t\"clustering_roles\",\n\t\t\t\"images_expiry\",\n\t\t\t\"resources_network_firmware\",\n\t\t\t\"backup_compression_algorithm\",\n\t\t\t\"ceph_data_pool_name\",\n\t\t\t\"container_syscall_intercept_mount\",\n\t\t\t\"compression_squashfs\",\n\t\t\t\"container_raw_mount\",\n\t\t\t\"container_nic_routed\",\n\t\t\t\"container_syscall_intercept_mount_fuse\",\n\t\t\t\"container_disk_ceph\",\n\t\t\t\"virtual-machines\",\n\t\t\t\"image_profiles\",\n\t\t\t\"clustering_architecture\",\n\t\t\t\"resources_disk_id\",\n\t\t\t\"storage_lvm_stripes\",\n\t\t\t\"vm_boot_priority\",\n\t\t\t\"unix_hotplug_devices\",\n\t\t\t\"api_filtering\",\n\t\t\t\"instance_nic_network\",\n\t\t\t\"clustering_sizing\",\n\t\t\t\"firewall_driver\",\n\t\t\t\"projects_limits\",\n\t\t\t\"container_syscall_intercept_hugetlbfs\",\n\t\t\t\"limits_hugepages\",\n\t\t\t\"container_nic_routed_gateway\",\n\t\t\t\"projects_restrictions\",\n\t\t\t\"custom_volume_snapshot_expiry\",\n\t\t\t\"volume_snapshot_scheduling\",\n\t\t\t\"trust_ca_certificates\",\n\t\t\t\"snapshot_disk_usage\",\n\t\t\t\"clustering_edit_roles\",\n\t\t\t\"container_nic_routed_host_address\",\n\t\t\t\"container_nic_ipvlan_gateway\",\n\t\t\t\"resources_usb_pci\",\n\t\t\t\"resources_cpu_threads_numa\",\n\t\t\t\"resources_cpu_core_die\",\n\t\t\t\"api_os\",\n\t\t\t\"container_nic_routed_host_table\",\n\t\t\t\"container_nic_ipvlan_host_table\",\n\t\t\t\"container_nic_ipvlan_mode\",\n\t\t\t\"resources_system\",\n\t\t\t\"images_push_relay\",\n\t\t\t\"network_dns_search\",\n\t\t\t\"container_nic_routed_limits\",\n\t\t\t\"instance_nic_bridged_vlan\",\n\t\t\t\"network_state_bond_bridge\",\n\t\t\t\"usedby_consistency\",\n\t\t\t\"custom_block_volumes\",\n\t\t\t\"clustering_failure_domains\",\n\t\t\t\"resources_gpu_mdev\",\n\t\t\t\"console_vga_type\",\n\t\t\t\"projects_limits_disk\",\n\t\t\t\"network_type_macvlan\",\n\t\t\t\"network_type_sriov\",\n\t\t\t\"container_syscall_intercept_bpf_devices\",\n\t\t\t\"network_type_ovn\",\n\t\t\t\"projects_networks\",\n\t\t\t\"projects_networks_restricted_uplinks\",\n\t\t\t\"custom_volume_backup\",\n\t\t\t\"backup_override_name\",\n\t\t\t\"storage_rsync_compression\",\n\t\t\t\"network_type_physical\",\n\t\t\t\"network_ovn_external_subnets\",\n\t\t\t\"network_ovn_nat\",\n\t\t\t\"network_ovn_external_routes_remove\",\n\t\t\t\"tpm_device_type\",\n\t\t\t\"storage_zfs_clone_copy_rebase\",\n\t\t\t\"gpu_mdev\",\n\t\t\t\"resources_pci_iommu\",\n\t\t\t\"resources_network_usb\",\n\t\t\t\"resources_disk_address\",\n\t\t\t\"network_physical_ovn_ingress_mode\",\n\t\t\t\"network_ovn_dhcp\",\n\t\t\t\"network_physical_routes_anycast\",\n\t\t\t\"projects_limits_instances\",\n\t\t\t\"network_state_vlan\",\n\t\t\t\"instance_nic_bridged_port_isolation\",\n\t\t\t\"instance_bulk_state_change\",\n\t\t\t\"network_gvrp\",\n\t\t\t\"instance_pool_move\",\n\t\t\t\"gpu_sriov\",\n\t\t\t\"pci_device_type\",\n\t\t\t\"storage_volume_state\",\n\t\t\t\"network_acl\",\n\t\t\t\"migration_stateful\",\n\t\t\t\"disk_state_quota\",\n\t\t\t\"storage_ceph_features\",\n\t\t\t\"projects_compression\",\n\t\t\t\"projects_images_remote_cache_expiry\",\n\t\t\t\"certificate_project\",\n\t\t\t\"network_ovn_acl\",\n\t\t\t\"projects_images_auto_update\",\n\t\t\t\"projects_restricted_cluster_target\",\n\t\t\t\"images_default_architecture\",\n\t\t\t\"network_ovn_acl_defaults\",\n\t\t\t\"gpu_mig\",\n\t\t\t\"project_usage\",\n\t\t\t\"network_bridge_acl\",\n\t\t\t\"warnings\",\n\t\t\t\"projects_restricted_backups_and_snapshots\",\n\t\t\t\"clustering_join_token\",\n\t\t\t\"clustering_description\",\n\t\t\t\"server_trusted_proxy\",\n\t\t\t\"clustering_update_cert\",\n\t\t\t\"storage_api_project\",\n\t\t\t\"server_instance_driver_operational\",\n\t\t\t\"server_supported_storage_drivers\",\n\t\t\t\"event_lifecycle_requestor_address\",\n\t\t\t\"resources_gpu_usb\",\n\t\t\t\"clustering_evacuation\",\n\t\t\t\"network_ovn_nat_address\",\n\t\t\t\"network_bgp\",\n\t\t\t\"network_forward\",\n\t\t\t\"custom_volume_refresh\",\n\t\t\t\"network_counters_errors_dropped\",\n\t\t\t\"metrics\",\n\t\t\t\"image_source_project\",\n\t\t\t\"clustering_config\",\n\t\t\t\"network_peer\",\n\t\t\t\"linux_sysctl\",\n\t\t\t\"network_dns\",\n\t\t\t\"ovn_nic_acceleration\",\n\t\t\t\"certificate_self_renewal\",\n\t\t\t\"instance_project_move\",\n\t\t\t\"storage_volume_project_move\",\n\t\t\t\"cloud_init\",\n\t\t\t\"network_dns_nat\",\n\t\t\t\"database_leader\",\n\t\t\t\"instance_all_projects\",\n\t\t\t\"clustering_groups\",\n\t\t\t\"ceph_rbd_du\",\n\t\t\t\"instance_get_full\",\n\t\t\t\"qemu_metrics\",\n\t\t\t\"gpu_mig_uuid\",\n\t\t\t\"event_project\",\n\t\t\t\"clustering_evacuation_live\",\n\t\t\t\"instance_allow_inconsistent_copy\",\n\t\t\t\"network_state_ovn\",\n\t\t\t\"storage_volume_api_filtering\",\n\t\t\t\"image_restrictions\",\n\t\t\t\"storage_zfs_export\",\n\t\t\t\"network_dns_records\",\n\t\t\t\"storage_zfs_reserve_space\",\n\t\t\t\"network_acl_log\",\n\t\t\t\"storage_zfs_blocksize\",\n\t\t\t\"metrics_cpu_seconds\",\n\t\t\t\"instance_snapshot_never\",\n\t\t\t\"certificate_token\",\n\t\t\t\"instance_nic_routed_neighbor_probe\",\n\t\t\t\"event_hub\",\n\t\t\t\"agent_nic_config\",\n\t\t\t\"projects_restricted_intercept\",\n\t\t\t\"metrics_authentication\",\n\t\t\t\"images_target_project\",\n\t\t\t\"images_all_projects\",\n\t\t\t\"cluster_migration_inconsistent_copy\",\n\t\t\t\"cluster_ovn_chassis\",\n\t\t\t\"container_syscall_intercept_sched_setscheduler\",\n\t\t\t\"storage_lvm_thinpool_metadata_size\",\n\t\t\t\"storage_volume_state_total\",\n\t\t\t\"instance_file_head\",\n\t\t\t\"instances_nic_host_name\",\n\t\t\t\"image_copy_profile\",\n\t\t\t\"container_syscall_intercept_sysinfo\",\n\t\t\t\"clustering_evacuation_mode\",\n\t\t\t\"resources_pci_vpd\",\n\t\t\t\"qemu_raw_conf\",\n\t\t\t\"storage_cephfs_fscache\",\n\t\t\t\"network_load_balancer\",\n\t\t\t\"vsock_api\",\n\t\t\t\"instance_ready_state\",\n\t\t\t\"network_bgp_holdtime\",\n\t\t\t\"storage_volumes_all_projects\",\n\t\t\t\"metrics_memory_oom_total\",\n\t\t\t\"storage_buckets\",\n\t\t\t\"storage_buckets_create_credentials\",\n\t\t\t\"metrics_cpu_effective_total\",\n\t\t\t\"projects_networks_restricted_access\",\n\t\t\t\"storage_buckets_local\",\n\t\t\t\"loki\",\n\t\t\t\"acme\",\n\t\t\t\"internal_metrics\",\n\t\t\t\"cluster_join_token_expiry\",\n\t\t\t\"remote_token_expiry\",\n\t\t\t\"init_preseed\",\n\t\t\t\"storage_volumes_created_at\",\n\t\t\t\"cpu_hotplug\",\n\t\t\t\"projects_networks_zones\",\n\t\t\t\"network_txqueuelen\",\n\t\t\t\"cluster_member_state\",\n\t\t\t\"instances_placement_scriptlet\",\n\t\t\t\"storage_pool_source_wipe\",\n\t\t\t\"zfs_block_mode\",\n\t\t\t\"instance_generation_id\",\n\t\t\t\"disk_io_cache\",\n\t\t\t\"amd_sev\",\n\t\t\t\"storage_pool_loop_resize\",\n\t\t\t\"migration_vm_live\",\n\t\t\t\"ovn_nic_nesting\",\n\t\t\t\"oidc\",\n\t\t\t\"network_ovn_l3only\",\n\t\t\t\"ovn_nic_acceleration_vdpa\",\n\t\t\t\"cluster_healing\",\n\t\t\t\"instances_state_total\",\n\t\t\t\"auth_user\",\n\t\t\t\"security_csm\",\n\t\t\t\"instances_rebuild\",\n\t\t\t\"numa_cpu_placement\",\n\t\t\t\"custom_volume_iso\",\n\t\t\t\"network_allocations\",\n\t\t\t\"zfs_delegate\",\n\t\t\t\"storage_api_remote_volume_snapshot_copy\",\n\t\t\t\"operations_get_query_all_projects\",\n\t\t\t\"metadata_configuration\",\n\t\t\t\"syslog_socket\",\n\t\t\t\"event_lifecycle_name_and_project\",\n\t\t\t\"instances_nic_limits_priority\",\n\t\t\t\"disk_initial_volume_configuration\",\n\t\t\t\"operation_wait\",\n\t\t\t\"image_restriction_privileged\",\n\t\t\t\"cluster_internal_custom_volume_copy\",\n\t\t\t\"disk_io_bus\",\n\t\t\t\"storage_cephfs_create_missing\",\n\t\t\t\"instance_move_config\",\n\t\t\t\"ovn_ssl_config\",\n\t\t\t\"certificate_description\",\n\t\t\t\"disk_io_bus_virtio_blk\",\n\t\t\t\"loki_config_instance\",\n\t\t\t\"instance_create_start\",\n\t\t\t\"clustering_evacuation_stop_options\",\n\t\t\t\"boot_host_shutdown_action\",\n\t\t\t\"agent_config_drive\",\n\t\t\t\"network_state_ovn_lr\",\n\t\t\t\"image_template_permissions\",\n\t\t\t\"storage_bucket_backup\",\n\t\t\t\"storage_lvm_cluster\",\n\t\t\t\"shared_custom_block_volumes\",\n\t\t\t\"auth_tls_jwt\",\n\t\t\t\"oidc_claim\",\n\t\t\t\"device_usb_serial\",\n\t\t\t\"numa_cpu_balanced\",\n\t\t\t\"image_restriction_nesting\",\n\t\t\t\"network_integrations\",\n\t\t\t\"instance_memory_swap_bytes\",\n\t\t\t\"network_bridge_external_create\",\n\t\t\t\"network_zones_all_projects\",\n\t\t\t\"storage_zfs_vdev\",\n\t\t\t\"container_migration_stateful\",\n\t\t\t\"profiles_all_projects\",\n\t\t\t\"instances_scriptlet_get_instances\",\n\t\t\t\"instances_scriptlet_get_cluster_members\",\n\t\t\t\"instances_scriptlet_get_project\",\n\t\t\t\"network_acl_stateless\",\n\t\t\t\"instance_state_started_at\",\n\t\t\t\"networks_all_projects\",\n\t\t\t\"network_acls_all_projects\",\n\t\t\t\"storage_buckets_all_projects\",\n\t\t\t\"resources_load\",\n\t\t\t\"instance_access\",\n\t\t\t\"project_access\",\n\t\t\t\"projects_force_delete\",\n\t\t\t\"resources_cpu_flags\",\n\t\t\t\"disk_io_bus_cache_filesystem\",\n\t\t\t\"instances_lxcfs_per_instance\",\n\t\t\t\"disk_volume_subpath\",\n\t\t\t\"projects_limits_disk_pool\",\n\t\t\t\"network_ovn_isolated\",\n\t\t\t\"qemu_raw_qmp\",\n\t\t\t\"network_load_balancer_health_check\",\n\t\t\t\"oidc_scopes\",\n\t\t\t\"network_integrations_peer_name\",\n\t\t\t\"qemu_scriptlet\",\n\t\t\t\"instance_auto_restart\",\n\t\t\t\"storage_lvm_metadatasize\",\n\t\t\t\"ovn_nic_promiscuous\",\n\t\t\t\"ovn_nic_ip_address_none\",\n\t\t\t\"instances_state_os_info\",\n\t\t\t\"network_load_balancer_state\",\n\t\t\t\"instance_nic_macvlan_mode\",\n\t\t\t\"storage_lvm_cluster_create\",\n\t\t\t\"network_ovn_external_interfaces\",\n\t\t\t\"instances_scriptlet_get_instances_count\",\n\t\t\t\"cluster_rebalance\",\n\t\t\t\"custom_volume_refresh_exclude_older_snapshots\",\n\t\t\t\"storage_initial_owner\",\n\t\t\t\"storage_live_migration\",\n\t\t\t\"instance_console_screenshot\",\n\t\t\t\"image_import_alias\",\n\t\t\t\"authorization_scriptlet\",\n\t\t\t\"console_force\",\n\t\t\t\"network_ovn_state_addresses\",\n\t\t\t\"network_bridge_acl_devices\",\n\t\t\t\"instance_debug_memory\",\n\t\t\t\"init_preseed_storage_volumes\",\n\t\t\t\"init_preseed_profile_project\",\n\t\t\t\"instance_nic_routed_host_address\",\n\t\t\t\"instance_smbios11\",\n\t\t\t\"api_filtering_extended\",\n\t\t\t\"acme_dns01\",\n\t\t\t\"security_iommu\",\n\t\t\t\"network_ipv4_dhcp_routes\",\n\t\t\t\"network_state_ovn_ls\",\n\t\t\t\"network_dns_nameservers\",\n\t\t\t\"acme_http01_port\",\n\t\t\t\"network_ovn_ipv4_dhcp_expiry\",\n\t\t\t\"instance_state_cpu_time\",\n\t\t\t\"network_io_bus\",\n\t\t\t\"disk_io_bus_usb\"\n\t\t],\n\t\t\"api_status\": \"stable\",\n\t\t\"api_version\": \"1.0\",\n\t\t\"auth\": \"trusted\",\n\t\t\"public\": false,\n\t\t\"auth_methods\": [\n\t\t\t\"tls\"\n\t\t],\n\t\t\"auth_user_name\": \"user\",\n\t\t\"auth_user_method\": \"unix\",\n\t\t\"environment\": {\n\t\t\t\"addresses\": [],\n\t\t\t\"architectures\": [\n\t\t\t\t\"x86_64\",\n\t\t\t\t\"i686\"\n\t\t\t],\n\t\t\t\"certificate\": \"-----BEGIN CERTIFICATE-----\\nM...r/\\n-----END CERTIFICATE-----\\n\",\n\t\t\t\"certificate_fingerprint\": \"0b...f6\",\n\t\t\t\"driver\": \"lxc | qemu\",\n\t\t\t\"driver_version\": \"6.0.4 | 10.0.6\",\n\t\t\t\"firewall\": \"nftables\",\n\t\t\t\"kernel\": \"Linux\",\n\t\t\t\"kernel_architecture\": \"x86_64\",\n\t\t\t\"kernel_features\": {\n\t\t\t\t\"idmapped_mounts\": \"true\",\n\t\t\t\t\"netnsid_getifaddrs\": \"true\",\n\t\t\t\t\"seccomp_listener\": \"true\",\n\t\t\t\t\"seccomp_listener_continue\": \"true\",\n\t\t\t\t\"uevent_injection\": \"true\",\n\t\t\t\t\"unpriv_binfmt\": \"true\",\n\t\t\t\t\"unpriv_fscaps\": \"true\"\n\t\t\t},\n\t\t\t\"kernel_version\": \"6.12.57+deb13-amd64\",\n\t\t\t\"lxc_features\": {\n\t\t\t\t\"cgroup2\": \"true\",\n\t\t\t\t\"core_scheduling\": \"true\",\n\t\t\t\t\"devpts_fd\": \"true\",\n\t\t\t\t\"idmapped_mounts_v2\": \"true\",\n\t\t\t\t\"mount_injection_file\": \"true\",\n\t\t\t\t\"network_gateway_device_route\": \"true\",\n\t\t\t\t\"network_ipvlan\": \"true\",\n\t\t\t\t\"network_l2proxy\": \"true\",\n\t\t\t\t\"network_phys_macvlan_mtu\": \"true\",\n\t\t\t\t\"network_veth_router\": \"true\",\n\t\t\t\t\"pidfd\": \"true\",\n\t\t\t\t\"seccomp_allow_deny_syntax\": \"true\",\n\t\t\t\t\"seccomp_notify\": \"true\",\n\t\t\t\t\"seccomp_proxy_send_notify_fd\": \"true\"\n\t\t\t},\n\t\t\t\"os_name\": \"Debian GNU/Linux\",\n\t\t\t\"os_version\": \"13\",\n\t\t\t\"project\": \"default\",\n\t\t\t\"server\": \"incus\",\n\t\t\t\"server_clustered\": false,\n\t\t\t\"server_event_mode\": \"full-mesh\",\n\t\t\t\"server_name\": \"host\",\n\t\t\t\"server_pid\": 44791,\n\t\t\t\"server_version\": \"6.0.4\",\n\t\t\t\"storage\": \"dir\",\n\t\t\t\"storage_version\": \"1\",\n\t\t\t\"storage_supported_drivers\": [\n\t\t\t\t{\n\t\t\t\t\t\"Name\": \"dir\",\n\t\t\t\t\t\"Version\": \"1\",\n\t\t\t\t\t\"Remote\": false\n\t\t\t\t},\n\t\t\t\t{\n\t\t\t\t\t\"Name\": \"lvm\",\n\t\t\t\t\t\"Version\": \"2.03.31(2) (2025-02-27) / 1.02.205 (2025-02-27) / 4.48.0\",\n\t\t\t\t\t\"Remote\": false\n\t\t\t\t},\n\t\t\t\t{\n\t\t\t\t\t\"Name\": \"lvmcluster\",\n\t\t\t\t\t\"Version\": \"2.03.31(2) (2025-02-27) / 1.02.205 (2025-02-27) / 4.48.0\",\n\t\t\t\t\t\"Remote\": true\n\t\t\t\t}\n\t\t\t]\n\t\t}\n\t}"
Launching mydeb
time="2025-12-14T17:08:10+02:00" level=debug msg="Connecting to a remote simplestreams server" URL="https://images.linuxcontainers.org"
time="2025-12-14T17:08:10+02:00" level=debug msg="Sending request to Incus" etag= method=POST url="http://unix.socket/1.0/instances?project=user-1000"
time="2025-12-14T17:08:10+02:00" level=debug msg="\n\t{\n\t\t\"architecture\": \"\",\n\t\t\"config\": {},\n\t\t\"devices\": {},\n\t\t\"ephemeral\": false,\n\t\t\"profiles\": null,\n\t\t\"stateful\": false,\n\t\t\"description\": \"\",\n\t\t\"name\": \"mydeb\",\n\t\t\"source\": {\n\t\t\t\"type\": \"image\",\n\t\t\t\"certificate\": \"\",\n\t\t\t\"alias\": \"debian/12\",\n\t\t\t\"server\": \"https://images.linuxcontainers.org\",\n\t\t\t\"protocol\": \"simplestreams\",\n\t\t\t\"mode\": \"pull\",\n\t\t\t\"allow_inconsistent\": false\n\t\t},\n\t\t\"instance_type\": \"\",\n\t\t\"type\": \"container\",\n\t\t\"start\": true\n\t}"
I truly don’t know what to do
Can you show incus project list?
~ $ incus project list
|  NAME   | IMAGES | PROFILES | STORAGE VOLUMES | STORAGE BUCKETS | NETWORKS | NETWORK ZONES |      DESCRIPTION      | USED BY |
| default | YES    | YES      | YES             | YES             | YES      | YES           | Default Incus project | 2       |
Okay, so for some reason your client is configured to access a non-existing project.
Use incus project switch default to get it back to normal.
It seems to work
Thank you very much!
Can you tell me what could cause that? Maybe something was wrong during the installation?
I used the apt install -y incus method (the official Debian 13 repository)
Although you helped me with the original problem, Now I am facing another problem:
~ $ incus launch images:devuan/excalibur devuan6vm --vm
Launching devuan6vm
Error: Failed instance creation: Failed getting remote image info: Failed getting image: The requested image couldn't be found
But if I try to launch a debian/12 it works.
The same error as seen above is happening with images:devuan/daedalus as well
Devuan is only available as container images, not VMs.
Okay, Thank you very much!
