I imagine there is already an LXC container out there perfectly designed to run one docker container inside ?
Since most distributed containers are in docker form, that seems like the fastest way to do it if you only use LXC ?
Or, if there is an automatic process to convert a docker container into an LXC container, I imagine that would be a lot better but I guess this does not exist or I simply cannot find it ?
I have a single dedicated proxmox computer, I don’t want to run docker in parrallel on the base OS and I don’t want to create a full VM for every single docker container I need to run. There simply isn’t enough ram to do that.
