After problem with my cluster I found that the 4 volumes (3 rootfs and one data volumes) in the 3 container instances have multiple errors like below (dmesq output from the incus cluster node):
[ 9055.177230] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
[ 9150.545493] EXT4-fs error (device rbd7): ext4_validate_block_bitmap:423: comm ext4lazyinit: bg 127: bad block bitmap checksum
[ 9152.366853] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
[ 9152.380677] EXT4-fs error (device rbd7): __ext4_find_entry:1693: inode #786568: comm prometheus: checksumming directory block 0
[ 9152.503874] EXT4-fs error (device rbd7): ext4_validate_inode_bitmap:105: comm prometheus: Corrupt inode bitmap - block_group = 96, inode_bitmap = 3145744
[ 9152.979961] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
[ 9152.991895] EXT4-fs error (device rbd7): __ext4_find_entry:1693: inode #786568: comm prometheus: checksumming directory block 0
[ 9157.503979] EXT4-fs error (device rbd7): ext4_validate_block_bitmap:423: comm kworker/u8:5: bg 111: bad block bitmap checksum
[ 9159.739104] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
[ 266.401467] EXT4-fs error (device rbd2): ext4_validate_block_bitmap:423: comm incusd: bg 1: bad block bitmap checksum
[ 266.412380] EXT4-fs error (device rbd2) in ext4_mb_clear_bb:6542: Filesystem failed CRC
[ 266.423542] EXT4-fs error (device rbd2): ext4_validate_block_bitmap:423: comm incusd: bg 15: bad block bitmap checksum
[ 268.710419] EXT4-fs error (device rbd2): ext4_validate_block_bitmap:423: comm ext4lazyinit: bg 49: bad block bitmap checksum
[ 271.081652] EXT4-fs error (device rbd3): ext4_validate_block_bitmap:423: comm ext4lazyinit: bg 1: bad block bitmap checksum
[ 273.589060] EXT4-fs error (device rbd7): ext4_validate_block_bitmap:423: comm ext4lazyinit: bg 127: bad block bitmap checksum
[ 277.987183] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
[ 278.004281] EXT4-fs error (device rbd7): __ext4_find_entry:1693: inode #786568: comm prometheus: checksumming directory block 0
[ 278.131252] EXT4-fs error (device rbd7): ext4_validate_inode_bitmap:105: comm prometheus: Corrupt inode bitmap - block_group = 96, inode_bitmap = 3145744
[ 278.531097] EXT4-fs error (device rbd3): ext4_validate_inode_bitmap:105: comm samba: Corrupt inode bitmap - block_group = 0, inode_bitmap = 137
[ 278.550398] EXT4-fs error (device rbd3) in ext4_free_inode:362: Filesystem failed CRC
[ 278.721024] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
[ 278.747239] EXT4-fs error (device rbd7): __ext4_find_entry:1693: inode #786568: comm prometheus: checksumming directory block 0
[ 281.316261] EXT4-fs error (device rbd3): ext4_lookup:1857: inode #16: comm samba: deleted inode referenced: 25
[ 281.326675] EXT4-fs error (device rbd3): ext4_lookup:1857: inode #16: comm samba: deleted inode referenced: 25
[ 282.974984] EXT4-fs error (device rbd7): ext4_validate_block_bitmap:423: comm kworker/u8:22: bg 111: bad block bitmap checksum
[ 339.957217] EXT4-fs error (device rbd7): ext4_lookup:1857: inode #786433: comm prometheus: deleted inode referenced: 786440
All impacted rootfs and data volumes attached to the instances are located on the ceph storage (actaully microceph).
What is the right way to fix these filesystem errors?
