What's wrong with my lxc container and vlan?
I have created on openwrt router an interface tagged with vlan id 1
On one server i have some lxc containers and I want some of them using this vlan (id 1), I have created the bridge
    ip link add name br1 type bridge
    ip link set br1 type bridge vlan_filtering 1
    ip link set enp7s0.1 up
    ip link set br1 up
    ip addr add 192.168.179.2 dev br1
add the vlan tag
    bridge vlan del dev enp7s0.1 vid 1
    bridge vlan add dev enp7s0.1 vid 1
    bridge vlan del dev br1 vid 1 self
    bridge vlan add dev br1 vid 1 self
    bridge vlan add dev veth1001_17Yt vid 1
This is the result
    bridge vlan sh
    port              vlan-id
    enp7s0            1 PVID Egress Untagged
    wlan0             1 PVID Egress Untagged
    br0               1 PVID Egress Untagged
    vnet0             1 PVID Egress Untagged
    veth1001_LoZK     1 PVID Egress Untagged
    veth1001_4Kss     1 PVID Egress Untagged
    veth1001_ZF7k     1 PVID Egress Untagged
    veth1001_FuzI     1 PVID Egress Untagged
    veth1001_1C5W     1 PVID Egress Untagged
    veth1001_W2FM     1 PVID Egress Untagged
    veth1001_YsU5     1 PVID Egress Untagged
    veth1001_823Q     1 PVID Egress Untagged
    veth1001_Uf5S     1 PVID Egress Untagged
    veth1001_R5zN     1 PVID Egress Untagged
    veth1001_9gyW     1 PVID Egress Untagged
    lxcbr0            1 PVID Egress Untagged
    enp7s0.1          1
    br1               1
    veth1001_17Yt     1
From pc using the bridge I try to ping ip of lxc container (which use vlan tag 1)
  ping 192.168.179.3
    PING 192.168.179.3 (192.168.179.3) 56(84) bytes of data.
It doesn’t work!
But if I disable vlan filtering…
ip link set dev br1 type bridge vlan_filtering 0
works
    ping 192.168.179.3
    64 bytes from 192.168.179.3: icmp_seq=1 ttl=63 time=8.75 ms
    64 bytes from 192.168.179.3: icmp_seq=2 ttl=63 time=6.88 ms
but seems vlan tag are not used
 tcpdump -i br1 -e vlan
    tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
    listening on br1, link-type EN10MB (Ethernet), snapshot length 262144 bytes
    ^C
    0 packets captured
    0 packets received by filter
    0 packets dropped by kernel
I have configured lxc container with those lines
# Network configuration
lxc.net.0.type = veth
lxc.net.0.link = br1
lxc.net.0.flags = up
lxc.net.0.name = eth0
lxc.net.0.hwaddr = *********
lxc.net.0.veth.vlan.tagged.id = 1
lxc.net.0.ipv4.address = 192.168.179.3/24
lxc.net.0.ipv4.gateway = 192.168.179.1
lxc.net.0.veth.pair = vethvlan1
What I miss?
