Where to comment on forum setup
Greetings
My last question resulted in a number of responses - - - to get the complete solution there were actually at least a few different posts needing to be stitched together. Yet it is only possible to pick 1 post as a solution.
Any way to change that?
I do not think there is a feature in this type of forum to have multiple solution posts.
I suppose you can add a new post that summarizes in a single post those two or three posts that covers your solution. Then, mark that single new post as the solution. Future visitors to this forum will love you for that.
OK - - - can do. Am finding that this style of forum (software primarily) definitely has some issues.
I marked that post as the Solution (I am sort of forum admin).
Are you able to mark your own posts as Solution?
It would be good to know so that I can keep an eye for such posts in the future.
It appears to be possible.
I edited the title/heading to make it easier to find for those looking for such information.
Is the second part of the title helpful?
What I would do, is change the title to something like
How do I connect containers to more than one network using a bridge or macvlan?
It is to the point, search engines will love it as it matches more or less a typical search query.
