Hi all,
I just created a basic container with incus launch images:ubuntu/24.04 dummy
, I then have the following result for incus info dummy
[me@mycomputer ~]$ incus info dummy
Nom : dummy
État : RUNNING
Type: container
Architecture : x86_64
PID: 17072
Créé : 2024/09/03 14:32 CEST
Last Used: 2024/09/03 14:32 CEST
Started: 2024/09/03 14:32 CEST
Ressources :
Processus : 12
CPU utilisé :
CPU utilisé (en secondes): 0
Mémoire utilisée :
Mémoire (courante): 127.72MiB
Réseau utilisé :
Type: broadcast
State: UP
Host interface: veth4e8ff958
MAC address: 00:16:3e:f3:fd:02
MTU: 1500
Octets reçus: 4.92kB
Octets émis: 2.73kB
Paquets reçus: 48
Paquets émis: 29
IP addresses:
inet: 10.27.1.94/24 (global)
inet6: fd42:ab2a:2225:e10c:216:3eff:fef3:fd02/64 (global)
inet6: fe80::216:3eff:fef3:fd02/64 (link)
lo:
Type: loopback
State: UP
MTU: 65536
Octets reçus: 0B
Octets émis: 0B
Paquets reçus: 0
Paquets émis: 0
IP addresses:
inet: 127.0.0.1/8 (local)
inet6: ::1/128 (local)
My default language is French (fr-ch) and, as you can see, some keys are translated and some are not. You may not notice it, but there are also NBSP at the end of French keys. For example, instead of Name
, I have "Nom\u202F"
(I discovered that thanks to shyaml
). The NBSP only appears at the end of French names and can be explained because you are supposed to add a space before a colon in French, it’s probably part of the translation.
As it feels strange to have something half-translated, even more if it’s YAML keys, I would like to know if it’s normal, translation in progress or a bug.
NOTE: It doesn’t happen on my legacy LXC containers.
