Wipe everything and restore
I have all volumes in a pool on separate partition.
I want to reinstall a distro.
After I add the old pool to incus, what I need to do to have working instances?
Do I need to copy somewhere instances’ YAMLs or Incus will be able to restore them from a pool?
Thx
Welcome!
In such cases it’s good to perform one (or a few) trial runs before doing the actual thing. Let’s give it a go.
We launch a VM that will act as our Incus server. We then (on the host) create a storage volume of type block. Next, we attach that block storage volume to the VM. In the VM it can be found as /dev/sdb. Subsequently, we incus admin init, and configure Incus to use the block device /dev/sdb.
$ incus launch images:ubuntu/24.04/cloud --vm incusserver
Launching incusserver
$ incus storage volume create default IncusStorage --type=block size=6GiB
Storage volume IncusStorage created
$ incus storage volume attach default IncusStorage incusserver
$ incus shell incusserver
root@incusserver:~# fdisk -l /dev/sdb
Disk /dev/sdb: 6 GiB, 6442450944 bytes, 12582912 sectors
Disk model: QEMU HARDDISK
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
root@incusserver:~# sudo apt install -y incus zfsutils-linux
root@incusserver:~# incus admin init
Would you like to use clustering? (yes/no) [default=no]:
Name of the storage backend to use (dir, zfs) [default=zfs]:
Create a new ZFS pool? (yes/no) [default=yes]:
Would you like to use an existing empty block device (e.g. a disk or partition)? (yes/no) [default=no]: yes
Path to the existing block device: /dev/sdb
Would you like to create a new local network bridge? (yes/no) [default=yes]:
What should the new bridge be called? [default=incusbr0]:
Would you like the server to be available over the network? (yes/no) [default=no]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]:
Would you like a YAML "init" preseed to be printed? (yes/no) [default=no]: yes
config: {}
networks:
- config:
    ipv4.address: auto
    ipv6.address: auto
  type: ""
  project: default
storage_pools:
- config:
    source: /dev/sdb
  driver: zfs
- config: {}
      network: incusbr0
      pool: default
projects: []
cluster: null
root@incusserver:~#
Next we populate the Incus installation with a few alpines.
root@incusserver:~# incus launch images:alpine/edge alpine1
Launching alpine1
root@incusserver:~# incus launch images:alpine/edge alpine2
Launching alpine2
root@incusserver:~# incus launch images:alpine/edge alpine3
Launching alpine3
root@incusserver:~#
This is where the interesting stuff start. We now want to shutdown the Incus server and remove it. However, the block storage volume will still be there, as the server has been shutdown cleanly.
root@incusserver:~# shutdown -h now
root@incusserver:~# Error: websocket: close 1006 (abnormal closure): unexpected EOF
$ incus storage volume show default IncusStorage
type: custom
- /1.0/instances/incusserver
content_type: block
project: default
created_at: ...
$ incus delete incusserver
type: custom
used_by: []
content_type: block
project: default
created_at: ...
Next, we launch a new VM, attach back the block storage volume and install Incus.
Error: Instance is not running
Error: VM agent isn't currently running
root@incusserver:~# apt install -y zfsutils-linux incus
Finally, we bring back the old installation data with those three alpines.
root@incusserver:~# zfs list
no datasets available
root@incusserver:~# zpool list
no pools available
root@incusserver:~# zpool import
   pool: default
  state: ONLINE
 action: The pool can be imported using its name or numeric identifier.
	default     ONLINE
	  sdb       ONLINE
root@incusserver:~# zpool import default
NAME      SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
default  5.50G  6.80M  5.49G        -         -     0%     0%  1.00x    ONLINE  -
root@incusserver:~#
root@incusserver:~# incus admin recover
This server currently has the following storage pools:
Would you like to recover another storage pool? (yes/no) [default=no]: yes
Name of the storage pool: default
Name of the storage backend (zfs, dir): zfs
Source of the storage pool (block device, volume group, dataset, path, ... as applicable): /dev/sdb
Additional storage pool configuration property (KEY=VALUE, empty when done):
The recovery process will be scanning the following storage pools:
 - NEW: "default" (backend="zfs", source="/dev/sdb")
Would you like to continue with scanning for lost volumes? (yes/no) [default=yes]:
Scanning for unknown volumes...
The following unknown storage pools have been found:
 - Storage pool "default" of type "zfs"
The following unknown volumes have been found:
 - Container "alpine2" on pool "default" in project "default" (includes 0 snapshots)
 - Container "alpine3" on pool "default" in project "default" (includes 0 snapshots)
 - Container "alpine1" on pool "default" in project "default" (includes 0 snapshots)
Would you like those to be recovered? (yes/no) [default=no]: yes
Starting recovery...
root@incusserver:~# incus list
|  NAME   |  STATE  | IPV4 | IPV6 |   TYPE    | SNAPSHOTS |
| alpine1 | STOPPED |      |      | CONTAINER | 0         |
| alpine2 | STOPPED |      |      | CONTAINER | 0         |
| alpine3 | STOPPED |      |      | CONTAINER | 0         |
root@incusserver:~#
Do they work? They sure do.
root@incusserver:~# incus start alpine1 alpine2 alpine3
root@incusserver:~# incus list -c ns4t
|  NAME   |  STATE  |         IPV4         |   TYPE    |
| alpine1 | RUNNING | 10.36.146.69 (eth0)  | CONTAINER |
| alpine2 | RUNNING | 10.36.146.101 (eth0) | CONTAINER |
| alpine3 | RUNNING | 10.36.146.248 (eth0) | CONTAINER |
root@incusserver:~#
In summary, the important commands are zpool import and incus admin recover.
Brilliant, thank you.
I forgot that I can simply test it inside my incus.
@simos thanks for the detailed explanation really helped. One last question, I have a second hard drive in my pc, I keep as zfs format and mount @ /mnt/ext_storage. I know I can add as a device using dir type so that it is shared with my containers. Is there a way to use it as zfs type in my containers or is dir the only option? I am asking as dir type as per manual is less performant.
Currently I tried
squeige@Ragnarok:~$ sudo zfs list
[sudo] password for squeige:
ext_storage 840K 450G 96K /mnt/ext_storage
squeige@Ragnarok:~$ incus profile device add ext-storage ZFS ext_storage
Error: Device validation failed for “ZFS”: Failed loading device “ZFS”: Unsupported device type
Thanks in advance,
The ZFS is not a device type for incus profile device add, hence the error you are getting. You should use disk instead.
You can create a dataset for the use of Incus in your existing ZFS pool called ext_storage. See Incus existing ZFS pool
Then, you can add that dataset in Incus as a storage pool, and move images from one pool to another. Or, create images to a specific pool.
incus storage create myincusexternal zfs source=ext_storage/incusexternal
Then, when you launch instances, you would
incus launch images:debian/12/cloud myinstance --storage myincusexternal
I guess I am confused and not clear, I don’t want images or anything related, I just want to provide data storage for the host and it’s containers. I was also reading about shifts, which sounds like s good option
I think it’s best to start a new thread for this. It’s an important question and we want search engines to be able to find the discussion easily.
Mention whether that extra disk is connected permanently to the system.
