Hi!
I am trying to use a VISA driver provided by National Instrument from within an LXC container.
Problem: I am getting ‘Operation not permitted’ when trying to write to the driver’s platform abstraction layer (in the form of /dev/nipalk).
root@agent-ubuntu:/home/agent/build# echo 0 > /dev/nipalk
bash: /dev/nipalk: Operation not permitted
I tried installing and using the driver on my native OS, which worked fine. In theory, the driver should just work with the underlying TCP/IP socket, and using the raw TCP/IP socket works in the container, so I don’t think anything is inherently preventing it from working and it’s a matter of giving it the appropriate access right.
Also quickly checking the owner and group, I don’t see anything obviously wrong.
crw-rw-rw- 1 root root 509, 0 Dec 5 01:24 nipalk
root@agent-ubuntu:/home/agent/build# whoami
root
I have read several threads which have mentioned concepts like uid mapping, and cgroup setting which are still relatively unfamiliar to me. So I am hoping if I could get some help here on checking these configs in case that’s what I am missing.
I will also post on the National Instrument’s forum but I feel like this problem could be more on the LXC side.
Thanks!
LXC config below:
lxc.arch = linux64
# Network configuration
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:13:ea:77
lxc.net.1.type = veth
lxc.net.1.flags = up
lxc.net.1.link = br-1
lxc.net.1.ipv4.address = 192.168.1.3/24
lxc.net.2.type = veth
lxc.net.2.flags = up
lxc.net.2.link = br-1
lxc.net.2.ipv4.address = 169.254.64.3/24
lxc.rootfs.path = dir:/var/lib/lxc/agent-ubuntu/rootfs
lxc.uts.name = agent-ubuntu
Setup info:
Host OS: Ubuntu 20.04
Container OS: Ubuntu 22.04
