today I did a test to export and import a container.
I am talking about a very simple test:
incus export CONTAINERNAME --compression=none
incus delete CONTAINERNAME
incus import CONTAINERNAME.tar
But import is failing.
The message I get is a lot of “no space left on device” messages (per file) after a while.
This is because volume created by import is small.
I am using LVM for storage.
By running again and again the lvs
command while the import is happening, I can see that incus has created a (default?) 10 GB volume for the container.
But this is not correct, because container had and should have 90 GB volume size.
I have extracted the .tar and indeed I see 90 GB inside backup/index.yaml and backup/container/backup.yaml files.
Here incus insist to go with a 10 GB volume and of course import process is failing when files are deployed.
Afterwards, I tried:
incus profile device set default root size=90GiB
but again incus creates a 10 GB volume on import.
Any ideas on how to make the import work?
Thank you very much.
