I have question
I use zfs as backend storage for lxd cluster, but when joining cluster there is a difference in “zpool status” on node1 and node2.
On node1 like this:
pool: apps_pool
state: ONLINE
scan: scrub repaired 0B in 0 days 01:35:51 with 0 errors on Sun Jun 12 08:59:53 2022
NAME STATE READ WRITE CKSUM
apps_pool ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
sdd ONLINE 0 0 0
sde ONLINE 0 0 0
sdf ONLINE 0 0 0
sdg ONLINE 0 0 0
sdh ONLINE 0 0 0
sdi ONLINE 0 0 0
On node2 like this:
pool: apps_pool
state: ONLINE
scan: none requested
/var/snap/lxd/common/lxd/disks/apps_pool.img ONLINE 0 0 0
When node2 joins the cluster, the zfs backend storage becomes an image:
Can the zfs backend storage on node2 not be an image and be the same as node1 ?
Thanks
