Hi, I’ve been unable to start an incus container after running the lxd-to-incus migration due to the storage being unavailable. The zfs pool was migrated from lxd but I’m unable to find it while using zpool list. I then ran incus admin init to see if another “default” pool can be created and found by zpool, and it is but no cPool.
# incus start jammyTest
Error: Storage pool "cPool" unavailable on this server
# incus storage list
| cPool | zfs | /var/lib/incus/disks/cPool.img | | 6 | UNAVAILABLE |
| default | zfs | /var/lib/incus/disks/default.img | | 0 | CREATED |
# zpool list
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
default 7.50G 633K 7.50G - - 0% 0% 1.00x ONLINE -
When trying to import “cPool” I get an error stating the pool does not exist:
# zpool import -dFmn /dev/disk/by-partuuid/device-address/var/lib/incus/disks/cPool.img
cannot import '/dev/disk/by-partuuid/device-address/var/lib/incus/disks/cPool.img': no such pool available
# zpool import -f -d /var/lib/incus/disks/ cPool
cannot import 'cPool': I/O error
Recovery is possible, but will result in some data loss.
Returning the pool to its state as of Thu Oct 12 13:35:53 2023
should correct the problem. Approximately 5 minutes of data
must be discarded, irreversibly. After rewind, at least
one persistent user-data error will remain. Recovery can be attempted
by executing 'zpool import -F cPool'. A scrub of the pool
is strongly recommended after recovery.
# zpool import -Ff -d /var/lib/incus/disks/ cPool
# zpool list
cPool 19.5G 1.77G 17.7G - - 3% 9% 1.00x ONLINE -
# incus list
| jammyTest | RUNNING | | 4c39 (eth0) | VIRTUAL-MACHINE | 0 |
| nexus | STOPPED | | | VIRTUAL-MACHINE | 0 |
| pbx3 | RUNNING | | 1f71 (eth0) | VIRTUAL-MACHINE | 0 |
| pve | STOPPED | | | VIRTUAL-MACHINE | 0 |
