You are unable to perform real-world testing and are limited to using synthetic benchmark tools ?
I canāt yet, I have to use these tools
But all the utilities Iāve used before have shown bad results on ZFS
What result were you anticipating with this latest synthetic test and why ?
I expected faster ZFS speed than EXT4
As I wrote above because Canonical recommend using ZFS for LXD
PostgreSQL also recommend ZFS
Iām asking what is the result (data) you anticipated with your most recent test and how is it different than what you anticipated (data) such as :
latency average = 25.720 ms
latency stddev = 13.184 ms
initial connection time = 89.406 ms
and you anticipated:
latency average = 15 ms
latency stddev = 8 ms
initial connection time = 50 ms
If we return to the topic of creating LXD containers, then I expected faster container creation on ZFS than on EXT4
300 containers per 13.215s on EXT4 VS 300 containers per 7.420s on ZFS
but not
300 containers per 13.215s on EXT4 VS 300 containers per 24.420s on ZFS
Or at least equal value but not like a double loss
Do you have any ideas about this?
Have you experienced this?
You are running synthetic benchmark tools and seem to have no expectation. Therefore, there seems no issue you are troublshooting and simply do not like the results are different than the video demo, correct?
Absolutely right
When using the same server, the speed of creating containers in ZFS is worse than on DIR
And I donāt know if this is the norm or not, because the video and other sources say otherwise
Regards.
Do you have any idea how to solve the ZFS speed issue when creating LXD containers?
Regards.
I donāt see a production issue, and synthetic testing without specific data-point expectations can quickly become a distracting rabbit holeā¦
Ok i understand you
Thank you very much for your attention
Iāll try to analyze it myself
Regards.
Iāll let you know as soon as there are achievements.
If anyone has any suggestions I will be glad to hear!
Regards.
Hello everyone again!
I started another test
This time ZFS was 3x faster!
Filesystems behave differently in different workloads
300 containers per 17.562s on EXT4 VS 300 containers per 5.225s on ZFS
lxd-benchmark init --count 50 --parallel 10 images:debian/11
Test environment:
Server backend: lxd
Server version: 5.0.2
Kernel: Linux
Kernel architecture: x86_64
Kernel version: 5.15.79-0-lts
Storage backend: zfs
Storage version: 2.1.6-1
Container backend: lxc
Container version: 5.0.2
Test variables:
Container count: 50
Container mode: unprivileged
Startup mode: normal startup
Image: images:debian/11
Batches: 5
Batch size: 10
Remainder: 0
[Jun 23 12:42:27.321] Importing image into local store: 8294cda0215fdf3b78bab4f4149584592ad10e7a09bf9d5d0da4d10413d5aafc
[Jun 23 12:42:49.163] Found image in local store: 8294cda0215fdf3b78bab4f4149584592ad10e7a09bf9d5d0da4d10413d5aafc
[Jun 23 12:42:49.164] Batch processing start
[Jun 23 12:42:51.559] Processed 10 containers in 2.396s (4.174/s)
[Jun 23 12:42:52.358] Processed 20 containers in 3.194s (6.262/s)
[Jun 23 12:42:53.693] Processed 40 containers in 4.530s (8.831/s)
[Jun 23 12:42:54.389] Batch processing completed in 5.225s
Test environment:
Server backend: lxd
Kernel: Linux
Storage backend: dir
Storage version: 1
Test variables:
Container count: 50
Batches: 5
Batch size: 10
Remainder: 0
[Jun 23 12:47:54.530] Importing image into local store: 8294cda0215fdf3b78bab4f4149584592ad10e7a09bf9d5d0da4d10413d5aafc
[Jun 23 12:48:16.543] Found image in local store: 8294cda0215fdf3b78bab4f4149584592ad10e7a09bf9d5d0da4d10413d5aafc
[Jun 23 12:48:16.543] Batch processing start
[Jun 23 12:48:20.179] Processed 10 containers in 3.636s (2.750/s)
[Jun 23 12:48:23.620] Processed 20 containers in 7.077s (2.826/s)
[Jun 23 12:48:30.624] Processed 40 containers in 14.081s (2.841/s)
[Jun 23 12:48:34.105] Batch processing completed in 17.562s
ZFS should be slower than EXT4?
ZFS has built in integrity checks so it is giving more reliability than ext4, but the cost is reduced performance. They are not comparing the same thing.
@tomp Just because of the capabilities of ZFS, I use it
Itās an awesome file system especially when integrated with LXD
And with some changes it can run faster than EXT4
Hi, itās interesting what did you do to make it faster?
I see it is:
lxd-benchmark init --count 300 images:debian/11
vs
Is it the only change? Or some ZFS tuning?
Hi!
Actually I changed the workload type and also used some zfs settings
ZFS performed better with lxd-benchmark init --count 300 images:debian/11 than with lxd-benchmark init --count 50 --parallel 10 images:alpine/edge
Here are the settings I used for the test
bench:~# zpool create -f -o ashift=12 \
> -O acltype=posixacl -O canmount=off -O compression=lz4 \
> -O dnodesize=auto -O normalization=formD -O relatime=on -O xattr=sa \
> -O recordsize=8K -O atime=off -O logbias=throughput \
> data mirror /dev/sda /dev/sdb mirror /dev/sdc /dev/sdd mirror /dev/sde /dev/
sdf mirror /dev/sdg /dev/sdh mirror /dev/sdi /dev/sdj mirror /dev/sdk /dev/sdl
Regards.
Thanks for sharing @Ibragim_Ganizade!
