3.0.1 - apparmor denied mount lxc-container-default-cgns
host ubuntu bionic 4.15.0-23
apparmor 2.12
unpriviliged container gentoo
This is not to be expected or is it?
audit: type=1400 audit(1530602405.099:27): apparmor=“DENIED” operation=“mount” info=“failed type match” error=-13 profile=“lxc-container-default-cgns” name=“/dev/” pid=2108 comm=“mount” flags=“rw, nosuid, remount”
The default apparmor policy doesn’t allow remounting filesystems, so it’s not unexpected to see this denied. It’d be interesting to know what caused that remount attempt in the container in the first place.
Happens on each reboot of the LXC host with a container set
lxc.start.auto = 1
lxc.group = onboot
I was talking about what’s happening inside the container which is running that mount command. The remount isn’t done by LXC, it’s done by something inside your container.
The container only runs an openvpn server inside, nothing else, but for that purpose it needs to mount
lxc.mount.entry = /dev/net/tun dev/net/tun none bind,create=file 0 0
which would correspond to the error
name=“/dev/”
Nope, the error you’re seeing is about a process called mount calling the mount syscall.
If it was LXC itself, you’d see comm="lxc-start" not comm="mount".
Then I would not know what causes this since wanting to remount /dev the only thing there is the tun netdev.
I am willing to debug this further if I would know where to look or how to. There is only that enty in the host’s kernel log though
You’d need to look at init scripts inside your container, that’s where I’d expect the remount to come from.
This would appear the most likely candidate I reckon -> /etc/init.d/devfs (gentoo unpriviliged container)
Summary
#!/sbin/openrc-run
# Copyright (c) 2007-2015 The OpenRC Authors.
# See the Authors file at the top-level directory of this distribution and
# https://github.com/OpenRC/openrc/blob/master/AUTHORS
# This file is part of OpenRC. It is subject to the license terms in
# the LICENSE file found in the top-level directory of this
# distribution and at https://github.com/OpenRC/openrc/blob/master/LICENSE
# This file may not be copied, modified, propagated, or distributed
# except according to the terms contained in the LICENSE file.
description="Set up the /dev directory"
depend()
	provide dev-mount
	before dev
	keyword -docker  -prefix -systemd-nspawn -vserver
mount_dev()
	local action=--mount devfstype msg=Mounting
	# Some devices require exec, Bug #92921
	local mountopts="exec,nosuid,mode=0755"
	if yesno ${skip_mount_dev:-no} ; then
		einfo "/dev will not be mounted due to user request"
		return 0
	fi
	if mountinfo -q /dev; then
		action=--remount
		mountopts="remount,$mountopts"
		msg=Remounting
	fi
	if fstabinfo -q /dev; then
		ebegin "$msg /dev according to /etc/fstab"
		fstabinfo -q $action /dev
		eend $?
		return 0
	fi
	if grep -q devtmpfs /proc/filesystems; then
		devfstype=devtmpfs
		mountopts="$mountopts,size=10M"
	elif grep -q tmpfs /proc/filesystems; then
		devfstype=tmpfs
	fi
	if [ -n "$devfstype" ]; then
		ebegin "$msg $devfstype on /dev"
		mount -n -t $devfstype -o $mountopts dev /dev
		eend $?
	else
		ewarn "This kernel does not have devtmpfs or tmpfs support, and there"
		ewarn "is no entry for /dev in fstab."
		ewarn "This means /dev will not be mounted."
		ewarn "To avoid this message, set CONFIG_DEVTMPFS or CONFIG_TMPFS to y"
		ewarn "in your kernel configuration or see /etc/conf.d/devfs"
	fi
	return 0
seed_dev()
	# Seed /dev with some things that we know we need
	# creating /dev/console, /dev/tty and /dev/tty1 to be able to write
	# to $CONSOLE with/without bootsplash before udevd creates it
	[ -c /dev/console ] || mknod -m 600 /dev/console c 5 1
	[ -c /dev/tty1 ] || mknod -m 620 /dev/tty1 c 4 1
	[ -c /dev/tty ] || mknod -m 666 /dev/tty c 5 0
	# udevd will dup its stdin/stdout/stderr to /dev/null
	# and we do not want a file which gets buffered in ram
	[ -c /dev/null ] || mknod -m 666 /dev/null c 1 3
	# so udev can add its start-message to dmesg
	[ -c /dev/kmsg ] || mknod -m 660 /dev/kmsg c 1 11
	# extra symbolic links not provided by default
	[ -e /dev/fd ] || ln -snf /proc/self/fd /dev/fd
	[ -e /dev/stdin ] || ln -snf /proc/self/fd/0 /dev/stdin
	[ -e /dev/stdout ] || ln -snf /proc/self/fd/1 /dev/stdout
	[ -e /dev/stderr ] || ln -snf /proc/self/fd/2 /dev/stderr
	[ -e /proc/kcore ] && ln -snf /proc/kcore /dev/core
	# Mount required directories as user may not have them in /etc/fstab
	for x in \
		"mqueue /dev/mqueue 1777 ,nodev mqueue" \
		"devpts /dev/pts 0755 ,gid=5,mode=0620 devpts" \
		"tmpfs /dev/shm 1777 ,nodev,mode=1777 shm" \
	; do
		set -- $x
		grep -Eq "[[:space:]]+$1$" /proc/filesystems || continue
		mountinfo -q $2 && continue
		if [ ! -d $2 ]; then
			mkdir -m $3 -p $2 >/dev/null 2>&1 || \
				ewarn "Could not create $2!"
		fi
		if [ -d $2 ]; then
			ebegin "Mounting $2"
			if ! fstabinfo --mount $2; then
				mount -n -t $1 -o noexec,nosuid$4 $5 $2
			fi
			eend $?
		fi
	done
restorecon_dev()
	if [ -x /sbin/restorecon ]; then
		ebegin "Restoring SELinux contexts in /dev"
		restorecon -rF /dev >/dev/null 2>&1
		eend $?
	fi
	return 0
start()
	mount_dev
	seed_dev
	restorecon_dev
	return 0
Seems that AppArmor is causing some trouble in general, to both OpenRC and systemd 3.0.1 - AppArmor buggy kernel patches causing problems in systemd based unpriviliged containers
