It works! Resolving my containers on the host (and within containers) with systemd-resolve just fine:
root@testcontainer:~# systemd-resolve othercontainer.lxd
othercontainer.lxd: fd42:86b1:4590:a8d9:216:3eff:fe8b:a44 -- link: eth0
10.14.216.203 -- link: eth0
-- Information acquired via protocol DNS in 2.2ms.
-- Data is authenticated: no
Unfortunately, that seems to have broken all other external name resolution within containers:
root@testcontainer:~# systemd-resolve google.com
google.com: resolve call failed: All attempts to contact name servers or networks failed
If I change the DNS servers to a non-local one (e.g. 8.8.8.8) in /etc/resolv.conf, it works. By default, it’s currently:
nameserver 127.0.0.53
options edns0
search lxd
On restart, and sporadically this gets overwritten, so it’s not exactly a permanent solution.
Within the containers, the output of systemd-resolve --status is:
root@testcontainer:~# systemd-resolve --status
Global
LLMNR setting: no
MulticastDNS setting: no
DNSOverTLS setting: no
DNSSEC setting: no
DNSSEC supported: no
DNSSEC NTA: 10.in-addr.arpa
16.172.in-addr.arpa
168.192.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 98 (eth0)
Current Scopes: DNS
DefaultRoute setting: yes
LLMNR setting: yes
DNSSEC setting: no
Current DNS Server: 10.14.216.1
DNS Servers: 10.14.216.1
fd42:86b1:4590:a8d9::1
fe80::ecfe:c9ff:feb3:cfb2
DNS Domain: lxd
The tutorial you followed assumes that the default Ubuntu resolution applies on the host, that is, with systemd-resolve. Is your host /etc/resolv.conf pointing to 127.0.0.53 ?
It’s worth mentioning that resolution on the host does work for both gTLDs and .lxd domains (before and after that command):
$ systemd-resolve google.com
google.com: 172.217.21.238
2a00:1450:4001:81f::200e
-- Information acquired via protocol DNS in 2.0ms.
using the same trick as for adding dns-loop-detect
then after restarting lxd do a
tail /var/log/dnsmasq-lxd.log -F
and do a resolution test in the container.(systemd-resolve linuxcontainers.org or anything)
if you get a message about request denied at this point, what gives on the host
lxc network show lxdbr0
ip route
I do not think the problem is within the host - it is some problem with the lxd resolver - all dns requests on the host work perfectly fine, it is only those within the guests that start to fail. But for the outputs of those commands, see below.
Within the log, everytime i run dig myspace.com on the guests, a surprising amount of requests are made:
Apr 26 13:22:42 dnsmasq[2141]: query[A] myspace.com from 10.14.216.219
Apr 26 13:22:42 dnsmasq[2141]: query[A] myspace.com from fd42:86b1:4590:a8d9:216:3eff:fe70:c722
Apr 26 13:22:42 dnsmasq[2141]: query[A] myspace.com from fe80::216:3eff:fe70:c722
Apr 26 13:22:47 dnsmasq[2141]: query[A] myspace.com from 10.14.216.219
Apr 26 13:22:47 dnsmasq[2141]: query[A] myspace.com from fd42:86b1:4590:a8d9:216:3eff:fe70:c722
Apr 26 13:22:47 dnsmasq[2141]: query[A] myspace.com from fe80::216:3eff:fe70:c722
Apr 26 13:22:52 dnsmasq[2141]: query[A] myspace.com from 10.14.216.219
Apr 26 13:22:52 dnsmasq[2141]: query[A] myspace.com from fd42:86b1:4590:a8d9:216:3eff:fe70:c722
Apr 26 13:22:52 dnsmasq[2141]: query[A] myspace.com from fe80::216:3eff:fe70:c722
systemd-resolve --status (there’s quite a few irrelevant entries, of the form veth*):
Global
DNS Servers: 213.133.99.99
213.133.100.100
213.133.98.98
16.172.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 11 (lxdbr0)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
DNS Domain: lxd
Link 6 (lxcbr0)
Current Scopes: none
LLMNR setting: yes
DNSSEC setting: no
Link 2 (eth0)
LLMNR setting: yes
DNSSEC setting: no
DNS Domain: ~.
ip route:
default via 172.31.1.1 dev eth0
10.0.3.0/24 dev lxcbr0 proto kernel scope link src 10.0.3.1
10.14.216.0/24 dev lxdbr0 proto kernel scope link src 10.14.216.1
172.31.1.1 dev eth0 scope link
I don’t understand why it does not work for you; it’s better IMO to do it my way with DNS scope, servers and default ‘DNS route’ set on the interface instead of globally since it avoid unnecessary queries that are doomed to fail, but it should work.
Did you remove the default symlink /etc/resolv.conf and replaced it with a regular file? See http://manpages.ubuntu.com/manpages/xenial/man8/systemd-resolved.service.8.html on why it’s not a good idea.
Nope, I didn’t replace it, it’s still the default.
I ended up sort of temporarily solving it by just reverting some of the changes, removing the startup scripts installed via that tutorial, and running on the host:
I’m not sure this counts as a solution though, it just reverts the ability for the host to do .lxd resolution (there are changes cached, which still work, but spawning a new container and performing name resolution on it fails). Using the lxd nameserver still works (i.e. running dig @10.14.216.1 containername.lxd), but it’s not really usable because it means I can’t resolve .lxd on the host using the system resolver.
Any tips on how to configure the host to allow .lxd resolution?
I was asking because I see a ‘search lxd’ that is not in my default resolv.conf on the only 18.04 system and default systemd where I can dabble with network resolution and where I tested @simos tutorial. I don’t know how it could be a following of the tutorial. Anyway, I’d say that you should attempt to set your dns servers on your physical interface, not globally. It’s the more satisfying setup and the only one where you can be sure to avoid loops.
Something like that;
Link 2 (enp3s0)
Current Scopes: DNS
DNS Servers: 10.0.0.250
DNS Domain: ~.
here I use a private DNS server on my internal network but you could do the same with public DNS servers.
Other than that you can make do with solutions on this thread
These are not very pretty hacks but you may care only about the result. Try to not use 8.8.8.8 at least.
