Any ideas?
incus launch images:ubuntu/23.04 LLAMA --target RRAI
Launching LLAMA
Error: Failed instance creation: Failed pre-start check for device “eth0”: Network “incusbr0” unavailable on this server
incus launch images:ubuntu/23.04 LLAMA2 --target RRAI
Launching LLAMA2
simos
(Simos Xenitellis)
February 8, 2024, 1:53pm
2
You would need to check with the following command that the RRAI node has the incusbr0 network device.
incus network list RRAI:
If you migrated from LXD (I think, while an instance was running?), then the network device was kept with the old name, lxdbr0.
If indeed, then you rename to incusbr0. Requires to stop the affected containers while renaming.
It is a new install on this whole cluster, never had lxd
incus network list
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| 10.0.0.0 | bridge | YES | 10.119.230.1/24 | fd42:266e:d72f:8869::1/64 | | 0 | CREATED |
| eno2 | physical | NO | | | | 0 | |
| incusbr0 | bridge | YES | 10.126.149.1/24 | fd42:ecf:4f02:b679::1/64 | | 21 | CREATED |
simos
(Simos Xenitellis)
February 8, 2024, 2:33pm
4
I can see a network called 10.0.0.0. Is that right? It looks like it was created by mistake.
It is not used by any instance. If you do not need it, remove it.
Do clusters share the output of incus network list? I think they do not. In that case, provide the output of all nodes in the cluster.
Finally,
use the fenced code blocks to surround the output of commands.
@ list
| 10TBBACK | RUNNING | 10.126.149.44 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe02:9ecc (eth0) | CONTAINER | 0 | Q5 |
| AD-Controller1 | RUNNING | 10.126.149.106 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe0c:29a4 (eth0) | CONTAINER | 0 | Q5 |
| AD-TEST | RUNNING | 10.126.149.13 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe15:c4a2 (eth0) | CONTAINER | 0 | Q5 |
| ELK-1 | RUNNING | 10.126.149.254 (eth0) | fd42:ecf:4f02:b679:216:3eff:fecd:7e3d (eth0) | CONTAINER | 0 | RRSOC |
| FLECTRA | RUNNING | 10.126.149.213 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe79:b98f (eth0) | CONTAINER | 0 | Q5 |
| KALI1 | RUNNING | 10.126.149.216 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe6e:306e (eth0) | CONTAINER | 0 | Q5 |
| LLAMA | STOPPED | | | CONTAINER | 0 | RRAI |
| LLAMA2 | STOPPED | | | CONTAINER | 0 | RRAI |
| MARIADB-3 | RUNNING | 10.126.149.181 (eth0) | fd42:ecf:4f02:b679:216:3eff:fec3:dd9c (eth0) | CONTAINER | 0 | Q5 |
| ODOO | RUNNING | 10.126.149.139 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe23:9f49 (eth0) | CONTAINER | 0 | Q5 |
| PYMAIL | RUNNING | 10.126.149.159 (eth0) | fd42:ecf:4f02:b679:216:3eff:feb3:39e9 (eth0) | CONTAINER | 0 | Q5 |
| ROD-AX | RUNNING | 10.126.149.66 (eth0) | fd42:ecf:4f02:b679:216:3eff:feaf:d2af (eth0) | CONTAINER | 0 | Q5 |
| RR-MARIABK | RUNNING | 10.126.149.160 (eth0) | fd42:ecf:4f02:b679:216:3eff:feae:5e3e (eth0) | CONTAINER | 0 | RRSOC |
| RRDB3 | RUNNING | 10.126.149.183 (eth0) | fd42:ecf:4f02:b679:216:3eff:fe22:764c (eth0) | CONTAINER | 0 | RRDB2 |
| RRTEAMS-TEST1 | RUNNING | 10.126.149.151 (eth0) | fd42:ecf:4f02:b679:216:3eff:feec:5216 (eth0) | CONTAINER | 0 | RRTEAMS |
root@RRDB2:/home/rr2020# @ network list
| enp1s0f0 | physical | NO | | | | 0 | |
| enp1s0f1 | physical | NO | | | | 0 | |
It is not being used, how do I take it out?
NOt sure what you want me to fence code blocks and why?
For some reason all the servers have 10.0.0.0 bridged
simos
(Simos Xenitellis)
February 8, 2024, 2:55pm
6
Regarding the fenced code blocks:
It’s easier to understand what is being shown and it is visually more appealing.
WITH:
WITHOUT:
