Using Proxmox 7.2.3, Freeswitch will run in lxc privileged container. Freeswitch will not run in lxc unprivileged container without commenting out IOSchedulingClass=realtime in /lib/systemd/system/freeswitch.service
How can Freeswitch be run in lxc unprivileged container without changing IOSchedulingClass ?
CT container template debian-11-standard_11.3-1_amd64.tar.zst shows the following output errors:
root@deb11fstest:~# freeswitch -c
ERROR: Failed to set SCHED_FIFO scheduler (Operation not permitted)
journalctl -xe
May 22 21:00:32 deb11fstest systemd[1]: Starting freeswitch…
– Subject: A start job for unit freeswitch.service has begun execution
– Defined-By: systemd
– Support: Debian -- User Support
– A start job for unit freeswitch.service has begun execution.
– The job identifier is 1686.
May 22 21:00:32 deb11fstest systemd[125577]: freeswitch.service: Failed to set up CPU scheduling: Operation not permitted
May 22 21:00:32 deb11fstest systemd[125577]: freeswitch.service: Failed at step SETSCHEDULER spawning /bin/mkdir: Operation not permitted
– Subject: Process /bin/mkdir could not be executed
– The process /bin/mkdir could not be executed and failed.
– The error number returned by this process is ERRNO.
May 22 21:00:32 deb11fstest systemd[1]: freeswitch.service: Control process exited, code=exited, status=214/SETSCHEDULER
– Subject: Unit process exited
– An ExecStartPre= process belonging to unit freeswitch.service has exited.
– The process’ exit code is ‘exited’ and its exit status is 214.
May 22 21:00:32 deb11fstest systemd[1]: freeswitch.service: Failed with result ‘exit-code’.
– Subject: Unit failed
– The unit freeswitch.service has entered the ‘failed’ state with result ‘exit-code’.
May 22 21:00:32 deb11fstest systemd[1]: Failed to start freeswitch.
– Subject: A start job for unit freeswitch.service has failed
– A start job for unit freeswitch.service has finished with a failure.
– The job identifier is 1686 and the job result is failed.
May 22 21:00:32 deb11fstest systemd[1]: freeswitch.service: Scheduled restart job, restart counter is at 3.
– Subject: Automatic restarting of a unit has been scheduled
– Automatic restarting of the unit freeswitch.service has been scheduled, as the result for
– the configured Restart= setting for the unit.
May 22 21:00:32 deb11fstest systemd[1]: Stopped freeswitch.
– Subject: A stop job for unit freeswitch.service has finished
– A stop job for unit freeswitch.service has finished.
