Incus on NixOS: Failed to start tmpfs-overlay device
I followed the video instruction on Incus 6.16 has been released trying to setup a tmpfs-overlay device but it does not work. And incus doesn’t provide useful error message for me to findout what is going on.
$ incus image list
|    ALIAS     | FINGERPRINT  | PUBLIC |             DESCRIPTION             | ARCHITECTURE |   TYPE    |   SIZE    |     UPLOAD DATE      |
| nixos/25.05  | 2a0aa6ad82fa | no     | Nixos 25.05 amd64 (20251020_01:00)  | x86_64       | CONTAINER | 151.24MiB | 2025/10/22 16:43 CST |
| ubuntu/24.04 | d328b74ad3a8 | no     | Ubuntu noble amd64 (20251025_07:42) | x86_64       | CONTAINER | 133.61MiB | 2025/10/26 15:20 CST |
$ incus create ubuntu/24.04 c1
Creating c1
$ incus config device add c1 tmpfs-overlay disk path=/etc size=50MiB source=tmpfs-overlay:
Device tmpfs-overlay added to c1
$ incus start c1
Error: Failed to start device "tmpfs-overlay": Cannot find rootfs path for container
Try `incus info --show-log c1` for more info
$ incus info --show-log c1
Description:
Status: STOPPED
Type: container
Created: 2026/01/06 09:57 CST
Last Used: 1970/01/01 08:00 CST
Log:
$ incus version
Client version: 6.20
Server version: 6.20
The ubuntu/24.04 is the official image pulled from images.linuxcontainers.org. And I think I do basically the same as that showed in the video.
More info about c1 container and storage pool:
$ incus config show c1
  image.architecture: amd64
  image.description: Ubuntu noble amd64 (20251025_07:42)
  image.os: Ubuntu
  image.release: noble
  image.requirements.cgroup: v2
  image.serial: "20251025_07:42"
  image.type: squashfs
  image.variant: default
  volatile.apply_template: create
  volatile.base_image: d328b74ad3a8aa27095e81537ef025d29ffaf8e7b108c9f09141064045f67117
  volatile.cloud-init.instance-id: a55a3d07-6f51-4ccb-a0b6-bfca94ea3e09
  volatile.eth0.hwaddr: 10:66:6a:8f:3c:25
  volatile.idmap.base: "0"
  volatile.uuid: c9a4b46b-d1d7-4d5d-ad16-35f931f7f615
  volatile.uuid.generation: c9a4b46b-d1d7-4d5d-ad16-35f931f7f615
  tmpfs-overlay:
    path: /etc
    source: 'tmpfs-overlay:'
$ incus profile show default
config: {}
    network: incusbr0
    pool: default_zfs
- /1.0/instances/c1
project: default
$ incus storage show default_zfs
  source: zinfra/incus_pool
  volatile.initial_source: zinfra/incus_pool
  zfs.pool_name: zinfra/incus_pool
driver: zfs
- /1.0/images/2a0aa6ad82fac372437f8941120d6fe675908ae0cbde942a626b649565659eb9
- /1.0/images/d328b74ad3a8aa27095e81537ef025d29ffaf8e7b108c9f09141064045f67117
- /1.0/instances/c1
- /1.0/profiles/default
status: Created
locations:
- none
System info (if it matters):
$ incus info
  core.https_address: :8443
  images.auto_update_cached: "false"
api_extensions:
- container_stop_priority
- container_syscall_filtering
- auth_pki
- container_last_used_at
- etag
- patch
- usb_devices
- https_allowed_credentials
- image_compression_algorithm
- directory_manipulation
- container_cpu_time
- storage_zfs_use_refquota
- storage_lvm_mount_options
- network
- profile_usedby
- container_push
- container_exec_recording
- certificate_update
- gpu_devices
- container_image_properties
- migration_progress
- id_map
- network_firewall_filtering
- network_routes
- storage
- file_delete
- file_append
- network_dhcp_expiry
- storage_lvm_vg_rename
- storage_lvm_thinpool_rename
- network_vlan
- image_create_aliases
- container_stateless_copy
- container_only_migration
- storage_zfs_clone_copy
- unix_device_rename
- storage_lvm_use_thinpool
- storage_rsync_bwlimit
- network_vxlan_interface
- storage_btrfs_mount_options
- entity_description
- image_force_refresh
- storage_lvm_lv_resizing
- id_map_base
- file_symlinks
- container_push_target
- network_vlan_physical
- storage_images_delete
- container_edit_metadata
- storage_driver_ceph
- storage_ceph_user_name
- resource_limits
- resources
- kernel_limits
- storage_api_volume_rename
- network_sriov
- console
- restrict_dev_incus
- migration_pre_copy
- infiniband
- dev_incus_events
- proxy
- network_dhcp_gateway
- file_get_symlink
- network_leases
- unix_device_hotplug
- operation_description
- clustering
- event_lifecycle
- nvidia_runtime
- container_mount_propagation
- container_backup
- dev_incus_images
- proxy_unix
- proxy_udp
- clustering_join
- network_state
- proxy_unix_dac_properties
- container_protection_delete
- unix_priv_drop
- pprof_http
- proxy_haproxy_protocol
- network_hwaddr
- proxy_nat
- network_nat_order
- container_full
- backup_compression
- nvidia_runtime_config
- storage_unmapped
- projects
- network_vxlan_ttl
- container_incremental_copy
- usb_optional_vendorid
- snapshot_scheduling
- snapshot_schedule_aliases
- container_copy_project
- clustering_server_address
- container_protection_shift
- snapshot_expiry
- snapshot_expiry_creation
- network_leases_location
- resources_cpu_socket
- resources_gpu
- resources_numa
- kernel_features
- id_map_current
- event_location
- network_nat_address
- container_nic_routes
- cluster_internal_copy
- seccomp_notify
- lxc_features
- container_nic_ipvlan
- network_vlan_sriov
- storage_cephfs
- container_nic_ipfilter
- resources_v2
- container_syscall_intercept
- container_disk_shift
- storage_shifted
- resources_infiniband
- daemon_storage
- instances
- image_types
- resources_disk_sata
- clustering_roles
- images_expiry
- resources_network_firmware
- ceph_data_pool_name
- compression_squashfs
- container_raw_mount
- container_nic_routed
- container_disk_ceph
- virtual-machines
- image_profiles
- clustering_architecture
- resources_disk_id
- storage_lvm_stripes
- vm_boot_priority
- unix_hotplug_devices
- api_filtering
- instance_nic_network
- clustering_sizing
- firewall_driver
- projects_limits
- limits_hugepages
- projects_restrictions
- volume_snapshot_scheduling
- trust_ca_certificates
- snapshot_disk_usage
- clustering_edit_roles
- resources_usb_pci
- resources_cpu_threads_numa
- resources_cpu_core_die
- api_os
- container_nic_ipvlan_mode
- resources_system
- images_push_relay
- network_dns_search
- container_nic_routed_limits
- instance_nic_bridged_vlan
- network_state_bond_bridge
- usedby_consistency
- custom_block_volumes
- clustering_failure_domains
- resources_gpu_mdev
- console_vga_type
- projects_limits_disk
- network_type_macvlan
- network_type_sriov
- network_type_ovn
- projects_networks
- custom_volume_backup
- backup_override_name
- storage_rsync_compression
- network_type_physical
- network_ovn_nat
- tpm_device_type
- gpu_mdev
- resources_pci_iommu
- resources_network_usb
- resources_disk_address
- network_ovn_dhcp
- projects_limits_instances
- network_state_vlan
- instance_bulk_state_change
- network_gvrp
- instance_pool_move
- gpu_sriov
- pci_device_type
- storage_volume_state
- network_acl
- migration_stateful
- disk_state_quota
- storage_ceph_features
- projects_compression
- certificate_project
- network_ovn_acl
- projects_images_auto_update
- images_default_architecture
- network_ovn_acl_defaults
- gpu_mig
- project_usage
- network_bridge_acl
- warnings
- clustering_join_token
- clustering_description
- server_trusted_proxy
- clustering_update_cert
- storage_api_project
- resources_gpu_usb
- clustering_evacuation
- network_ovn_nat_address
- network_bgp
- network_forward
- custom_volume_refresh
- network_counters_errors_dropped
- metrics
- image_source_project
- clustering_config
- network_peer
- linux_sysctl
- network_dns
- ovn_nic_acceleration
- certificate_self_renewal
- instance_project_move
- storage_volume_project_move
- cloud_init
- network_dns_nat
- database_leader
- instance_all_projects
- clustering_groups
- ceph_rbd_du
- instance_get_full
- qemu_metrics
- gpu_mig_uuid
- event_project
- clustering_evacuation_live
- instance_allow_inconsistent_copy
- network_state_ovn
- storage_volume_api_filtering
- image_restrictions
- storage_zfs_export
- network_dns_records
- storage_zfs_reserve_space
- network_acl_log
- storage_zfs_blocksize
- metrics_cpu_seconds
- instance_snapshot_never
- certificate_token
- instance_nic_routed_neighbor_probe
- event_hub
- agent_nic_config
- projects_restricted_intercept
- metrics_authentication
- images_target_project
- images_all_projects
- cluster_migration_inconsistent_copy
- cluster_ovn_chassis
- container_syscall_intercept_sched_setscheduler
- storage_lvm_thinpool_metadata_size
- storage_volume_state_total
- instance_file_head
- instances_nic_host_name
- image_copy_profile
- container_syscall_intercept_sysinfo
- clustering_evacuation_mode
- resources_pci_vpd
- qemu_raw_conf
- storage_cephfs_fscache
- network_load_balancer
- vsock_api
- instance_ready_state
- network_bgp_holdtime
- storage_volumes_all_projects
- metrics_memory_oom_total
- storage_buckets
- storage_buckets_create_credentials
- metrics_cpu_effective_total
- projects_networks_restricted_access
- storage_buckets_local
- loki
- acme
- internal_metrics
- cluster_join_token_expiry
- remote_token_expiry
- init_preseed
- storage_volumes_created_at
- cpu_hotplug
- projects_networks_zones
- network_txqueuelen
- cluster_member_state
- instances_placement_scriptlet
- storage_pool_source_wipe
- zfs_block_mode
- instance_generation_id
- disk_io_cache
- amd_sev
- storage_pool_loop_resize
- migration_vm_live
- ovn_nic_nesting
- oidc
- network_ovn_l3only
- ovn_nic_acceleration_vdpa
- cluster_healing
- instances_state_total
- auth_user
- security_csm
- instances_rebuild
- numa_cpu_placement
- custom_volume_iso
- network_allocations
- zfs_delegate
- storage_api_remote_volume_snapshot_copy
- operations_get_query_all_projects
- metadata_configuration
- syslog_socket
- event_lifecycle_name_and_project
- instances_nic_limits_priority
- disk_initial_volume_configuration
- operation_wait
- image_restriction_privileged
- cluster_internal_custom_volume_copy
- disk_io_bus
- storage_cephfs_create_missing
- instance_move_config
- ovn_ssl_config
- certificate_description
- disk_io_bus_virtio_blk
- loki_config_instance
- instance_create_start
- clustering_evacuation_stop_options
- boot_host_shutdown_action
- agent_config_drive
- network_state_ovn_lr
- image_template_permissions
- storage_bucket_backup
- storage_lvm_cluster
- shared_custom_block_volumes
- auth_tls_jwt
- oidc_claim
- device_usb_serial
- numa_cpu_balanced
- image_restriction_nesting
- network_integrations
- instance_memory_swap_bytes
- network_bridge_external_create
- network_zones_all_projects
- storage_zfs_vdev
- container_migration_stateful
- profiles_all_projects
- instances_scriptlet_get_instances
- instances_scriptlet_get_cluster_members
- instances_scriptlet_get_project
- network_acl_stateless
- instance_state_started_at
- networks_all_projects
- network_acls_all_projects
- storage_buckets_all_projects
- resources_load
- instance_access
- project_access
- projects_force_delete
- resources_cpu_flags
- disk_io_bus_cache_filesystem
- instance_oci
- clustering_groups_config
- instances_lxcfs_per_instance
- clustering_groups_vm_cpu_definition
- disk_volume_subpath
- projects_limits_disk_pool
- network_ovn_isolated
- qemu_raw_qmp
- network_load_balancer_health_check
- oidc_scopes
- network_integrations_peer_name
- qemu_scriptlet
- instance_auto_restart
- storage_lvm_metadatasize
- ovn_nic_promiscuous
- ovn_nic_ip_address_none
- instances_state_os_info
- network_load_balancer_state
- instance_nic_macvlan_mode
- storage_lvm_cluster_create
- network_ovn_external_interfaces
- instances_scriptlet_get_instances_count
- cluster_rebalance
- custom_volume_refresh_exclude_older_snapshots
- storage_initial_owner
- storage_live_migration
- instance_console_screenshot
- image_import_alias
- authorization_scriptlet
- console_force
- network_ovn_state_addresses
- network_bridge_acl_devices
- instance_debug_memory
- init_preseed_storage_volumes
- init_preseed_profile_project
- instance_nic_routed_host_address
- instance_smbios11
- api_filtering_extended
- acme_dns01
- security_iommu
- network_ipv4_dhcp_routes
- network_state_ovn_ls
- network_dns_nameservers
- acme_http01_port
- network_ovn_ipv4_dhcp_expiry
- instance_state_cpu_time
- network_io_bus
- disk_io_bus_usb
- storage_driver_linstor
- instance_oci_entrypoint
- network_address_set
- server_logging
- network_forward_snat
- memory_hotplug
- instance_nic_routed_host_tables
- instance_publish_split
- init_preseed_certificates
- custom_volume_sftp
- network_ovn_external_nic_address
- network_physical_gateway_hwaddr
- backup_s3_upload
- snapshot_manual_expiry
- resources_cpu_address_sizes
- disk_attached
- limits_memory_hotplug
- disk_wwn
- server_logging_webhook
- storage_driver_truenas
- container_disk_tmpfs
- instance_limits_oom
- backup_override_config
- network_ovn_tunnels
- init_preseed_cluster_groups
- usb_attached
- backup_iso
- instance_systemd_credentials
- cluster_group_usedby
- bpf_token_delegation
- file_storage_volume
- network_hwaddr_pattern
- storage_volume_full
- storage_bucket_full
- device_pci_firmware
- resources_serial
- ovn_nic_limits
- storage_lvmcluster_qcow2
api_status: stable
api_version: "1.0"
auth: trusted
public: false
auth_methods:
- tls
auth_user_name: ...
auth_user_method: unix
environment:
  addresses:
  architectures:
  - x86_64
  - i686
  certificate: |
    -----BEGIN CERTIFICATE-----
    -----END CERTIFICATE-----
  certificate_fingerprint: ...
  driver: lxc | qemu
  driver_version: 6.0.5 | 10.1.2
  firewall: nftables
  kernel: Linux
  kernel_architecture: x86_64
  kernel_features:
    idmapped_mounts: "true"
    netnsid_getifaddrs: "true"
    seccomp_listener: "true"
    uevent_injection: "true"
    unpriv_binfmt: "true"
    unpriv_fscaps: "true"
  kernel_version: 6.12.63
  lxc_features:
    cgroup2: "true"
    core_scheduling: "true"
    devpts_fd: "true"
    idmapped_mounts_v2: "true"
    mount_injection_file: "true"
    network_ipvlan: "true"
    network_l2proxy: "true"
    network_veth_router: "true"
    pidfd: "true"
    seccomp_notify: "true"
  os_name: NixOS
  os_version: "25.11"
  project: default
  server: incus
  server_clustered: false
  server_event_mode: full-mesh
  server_name: ...
  server_pid: 3602569
  server_version: "6.20"
  storage: zfs | dir
  storage_version: 2.3.5-1 | 1
  storage_supported_drivers:
  - name: lvm
    version: 2.03.35(2) (2025-09-09) / 1.02.209 (2025-09-09) / 4.48.0
    remote: false
  - name: zfs
    version: 2.3.5-1
    remote: false
  - name: btrfs
    version: 6.17.1
    remote: false
  - name: dir
    version: "1"
    remote: false
Do I need to provide something else?
I’m guessing your distribution is using some other path as the liblxc temporary rootfs mount point.
Do you mean this?
lxc.rootfs.path = dir:/var/lib/incus/storage-pools/default_zfs/containers/c1/rootfs
Well, my host machine is NixOS. And that path is a default. :joy:
No, that’s the container’s rootfs, that’s not the same as the temporary mount point.
If you set raw.lxc=lxc.log.level=trace and then start a container, we should be able to find the mount point in incus info --show-log afterwards.
Ok, after some hours, I roughly figured it out. liblxc uses ./lxc/rootfs (relative to liblxc.so) as a temporary root mountpoint when launching container (e.g. in Incus-OS it is /opt/incus/lib/lxc/rootfs/). Is that correct?
And yeah, in NixOS liblxc would be something like /nix/store/m25jfcwkcp16hwlq5dx5mgk57hq8j1g9-lxc-6.0.5/lib/liblxc.so and temporary mount point is /nix/store/m25jfcwkcp16hwlq5dx5mgk57hq8j1g9-lxc-6.0.5/lib/lxc/rootfs. Which causes problem.
From the behavior I noticed, incus assumes liblxc would be located under one of those three paths ( /opt/incus/lib/, /usr/lib/x86_64-linux-gnu/ and a aarch64 one). If I manually create /opt/incus/lib/lxc/rootfs/ dir, incus will move on and ends up in a lxc.conf like:
lxc.mount.entry = none proc tmpfs size=50000000,defaults 0 0
lxc.mount.entry = none proc/upper invalid defaults,create=dir,optional 0 0
lxc.mount.entry = none proc/work invalid defaults,create=dir,optional 0 0
lxc.mount.entry = none sys overlay userxattr,lowerdir=/opt/incus/lib/lxc/rootfs/etc,upperdir=/opt/incus/lib/lxc/rootfs/proc/upper,workdir=/opt/incus/lib/lxc/rootfs/proc/work 0 0
lxc.mount.entry = /opt/incus/lib/lxc/rootfs/proc etc none move 0 0
lxc.mount.entry = /opt/incus/lib/lxc/rootfs/sys etc none move 0 0
But again it would fail to launch, because the liblxc does not use /opt/incus/lib/lxc/rootfs.
My questions:
  1. Does liblxc allow set a different temporary rootfs mount point? I only found lxc.lxcpath, but that is another thing.
  2. Whether a feasible solution would exist for distros like NixOS, except making incus aware of liblxc location. I have heard about the difference between absolute path and relative path notation in the context of lxc, but not quite sure. Could we generate lxc.conf like:
lxc.mount.entry = none sys overlay userxattr,lowerdir=etc,upperdir=proc/upper,workdir=proc/work 0 0
lxc.mount.entry = proc etc none move 0 0
lxc.mount.entry = sys etc none move 0 0
It can be specified at liblxc build time, so if that was set to a predictable path,then we could add it to the list of paths we check.
That won’t work for that specific feature as the relative mount points only work for paths directly handled by liblxc, here we’re passing some paths directly to overlayfs which doesn’t know what those paths would be relative to.
Thanks for your guidance!
Is that this one?
I am not familiar with meson. Suppose it complies with POSIX path joining, we could theoretically set it to a absolute path like /opt/incus/lib/lxc/rootfs/ instead of libdir-relative path, which varies among different versions of lxc package (This is intrinsic to nix).
Otherwise, should we also add a compiling option to incus for rootFsPaths? Or even let incus dynamically decide where liblxc is located?
Anyway, it is more of a nix packaging problem. I might also consult those package maintainers.
Yeah, that’s the one.
It just needs to be a directory on the system which all users can access.
In theory your could abuse/re-use a system path like /srv or something for that, so long as the container will not ever need access to anything under that path.
Having it be a config option or at least have a way to retrieve it from liblxc would certainly be convenient, but that tends to take a little while to land a new API in liblxc, then have it be in a release and picked up by distributions :slight_smile:
We can patch rootFsPaths with the nix store lxc location in the incus source before building. I don’t know much about this feature, but given the paths listed this being read only doesn’t appear to be a problem.
Yeah, solving it on nix side with minimal change sounds more practical.
Let me put a link here for others to come by incus: tmpfs-overlay feature not working · Issue #477619 · NixOS/nixpkgs · GitHub
Thanks again for your help!
Yep, that’d work fine.
