IncusOS is starting... timed out
I created an incusos USB image. After install reboot and Starting incusos… timeouts. I do not get any command prompt, starts cycling through debug dump screens. I could take a picture of the dump screens if it would help but otherwise do not know how to capture the information. Booted into Ubuntu live and below is output of: ls -lh /sys/class/block/*/device/driver and lsmod
The computer is a Beelink Mini PC,12th Gen Intel Alder Lake-N100, 16GB DDR4 RAM 500GB PCIE SSD, S12 Pro Mini Computer, I added a second 2T ssd but trying to install on the 500gb nvme ssd
Thanks in advance for any help.
ubuntu@ubuntu:~$ ls -lh /sys/class/block/*/device/driver
lrwxrwxrwx 1 root root 0 Feb  6 00:21 /sys/class/block/sda/device/driver -> ../../../../../../../bus/scsi/drivers/sd
lrwxrwxrwx 1 root root 0 Feb  6 00:21 /sys/class/block/sdb/device/driver -> ../../../../../../../../../bus/scsi/drivers/sd
ubuntu@ubuntu:~$
ubuntu@ubuntu:~$ lsmod
Module                  Size  Used by
btrfs                2088960  0
blake2b_generic        20480  0
ufs                   114688  0
qnx4                   12288  0
hfsplus               139264  0
hfs                    77824  0
minix                  45056  0
msdos                  16384  0
jfs                   294912  0
nls_ucs2_utils          8192  1 jfs
xfs                  2662400  0
rfcomm                102400  4
snd_seq_dummy          12288  0
snd_hrtimer            12288  1
qrtr                   53248  2
cmac                   12288  3
algif_hash             16384  1
algif_skcipher         16384  1
af_alg                 32768  6 algif_hash,algif_skcipher
bnep                   32768  2
binfmt_misc            24576  1
snd_sof_pci_intel_tgl    12288  0
snd_sof_pci_intel_cnl    20480  1 snd_sof_pci_intel_tgl
snd_sof_intel_hda_generic    36864  2 snd_sof_pci_intel_tgl,snd_sof_pci_intel_cnl
soundwire_intel        77824  1 snd_sof_intel_hda_generic
soundwire_cadence      45056  1 soundwire_intel
snd_sof_intel_hda_common   188416  3 snd_sof_intel_hda_generic,snd_sof_pci_intel_tgl,snd_sof_pci_intel_cnl
snd_soc_hdac_hda       24576  1 snd_sof_intel_hda_common
snd_sof_intel_hda_mlink    45056  3 soundwire_intel,snd_sof_intel_hda_common,snd_sof_intel_hda_generic
snd_sof_intel_hda      24576  2 snd_sof_intel_hda_common,snd_sof_intel_hda_generic
snd_hda_codec_hdmi     98304  0
snd_sof_pci            24576  3 snd_sof_intel_hda_generic,snd_sof_pci_intel_tgl,snd_sof_pci_intel_cnl
snd_sof_xtensa_dsp     12288  1 snd_sof_intel_hda_generic
snd_sof               393216  5 snd_sof_pci,snd_sof_intel_hda_common,snd_sof_intel_hda_generic,snd_sof_intel_hda,snd_sof_pci_intel_cnl
snd_sof_utils          16384  1 snd_sof
snd_soc_acpi_intel_match   131072  3 snd_sof_intel_hda_generic,snd_sof_pci_intel_tgl,snd_sof_pci_intel_cnl
snd_soc_acpi_intel_sdca_quirks    12288  1 snd_soc_acpi_intel_match
soundwire_generic_allocation    24576  1 soundwire_intel
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_sof_intel_hda_generic
soundwire_bus         126976  3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
snd_soc_sdca           12288  2 snd_soc_acpi_intel_sdca_quirks,soundwire_bus
snd_soc_avs           200704  0
snd_soc_hda_codec      24576  1 snd_soc_avs
snd_hda_ext_core       32768  6 snd_soc_avs,snd_soc_hda_codec,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda_mlink,snd_sof_intel_hda
snd_hda_codec_realtek   212992  1
snd_hda_codec_generic   122880  1 snd_hda_codec_realtek
snd_soc_core          425984  6 snd_soc_avs,snd_soc_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda
snd_hda_scodec_component    20480  1 snd_hda_codec_realtek
snd_compress           36864  2 snd_soc_avs,snd_soc_core
ac97_bus               12288  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_hda_intel          61440  1
intel_rapl_msr         20480  0
intel_rapl_common      53248  1 intel_rapl_msr
snd_intel_dspcfg       45056  5 snd_soc_avs,snd_hda_intel,snd_sof,snd_sof_intel_hda_common,snd_sof_intel_hda_generic
snd_intel_sdw_acpi     16384  2 snd_intel_dspcfg,snd_sof_intel_hda_generic
snd_usb_audio         557056  1
snd_hda_codec         204800  8 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_codec_realtek,snd_soc_hdac_hda,snd_sof_intel_hda
x86_pkg_temp_thermal    20480  0
intel_powerclamp       24576  0
drm_gpuvm              45056  0
snd_usbmidi_lib        57344  1 snd_usb_audio
snd_hda_core          147456  11 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
gpu_sched              61440  0
snd_ump                45056  1 snd_usb_audio
snd_hwdep              20480  2 snd_usb_audio,snd_hda_codec
drm_ttm_helper         16384  0
drm_exec               12288  1 drm_gpuvm
snd_pcm               192512  14 snd_soc_avs,snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_sof_intel_hda_generic,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pcm_dmaengine
drm_suballoc_helper    20480  0
coretemp               24576  0
snd_seq_midi           24576  0
snd_seq_midi_event     16384  1 snd_seq_midi
uvcvideo              143360  0
snd_rawmidi            57344  3 snd_seq_midi,snd_usbmidi_lib,snd_ump
iwlmvm                909312  0
kvm_intel             487424  0
videobuf2_vmalloc      20480  1 uvcvideo
snd_seq               122880  9 snd_seq_midi,snd_seq_midi_event,snd_seq_dummy
kvm                  1425408  1 kvm_intel
uvc                    12288  1 uvcvideo
snd_seq_device         16384  4 snd_seq,snd_seq_midi,snd_ump,snd_rawmidi
cmdlinepart            16384  0
mac80211             1814528  1 iwlmvm
videobuf2_memops       16384  1 videobuf2_vmalloc
snd_timer              53248  3 snd_seq,snd_hrtimer,snd_pcm
videobuf2_v4l2         36864  1 uvcvideo
btusb                  73728  0
irqbypass              12288  1 kvm
spi_nor               163840  0
videobuf2_common       86016  4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
drm_buddy              24576  0
ee1004                 16384  0
mtd                    98304  3 spi_nor,cmdlinepart
videodev              360448  2 videobuf2_v4l2,uvcvideo
libarc4                12288  1 mac80211
btrtl                  32768  1 btusb
rapl                   20480  0
snd                   143360  23 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_ump,snd_pcm,snd_rawmidi
ttm                   118784  1 drm_ttm_helper
btintel                69632  1 btusb
zfs                  6770688  6
intel_cstate           20480  0
mc                     81920  5 videodev,snd_usb_audio,videobuf2_v4l2,uvcvideo,videobuf2_common
soundcore              16384  1 snd
drm_display_helper    278528  0
cp210x                 40960  0
mei_me                 53248  0
i2c_i801               36864  0
btbcm                  24576  1 btusb
cec                    94208  1 drm_display_helper
iwlwifi               663552  1 iwlmvm
wmi_bmof               12288  0
spi_intel_pci          12288  0
btmtk                  36864  1 btusb
rc_core                73728  1 cec
i2c_smbus              20480  1 i2c_i801
i2c_mux                16384  1 i2c_i801
mei                   172032  1 mei_me
spi_intel              36864  1 spi_intel_pci
bluetooth            1011712  34 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
usbserial              69632  1 cp210x
cfg80211             1433600  3 iwlmvm,iwlwifi,mac80211
i2c_algo_bit           16384  0
igen6_edac             28672  0
spl                   192512  1 zfs
intel_pmc_core        122880  0
input_leds             12288  0
joydev                 32768  0
pmt_telemetry          16384  1 intel_pmc_core
pmt_class              16384  1 pmt_telemetry
acpi_tad               20480  0
intel_vsec             20480  1 intel_pmc_core
acpi_pad              184320  0
mac_hid                12288  0
sch_fq_codel           24576  2
msr                    12288  0
parport_pc             53248  0
ppdev                  24576  0
lp                     28672  0
parport                73728  3 parport_pc,lp,ppdev
efi_pstore             12288  0
nfnetlink              20480  1
dmi_sysfs              24576  0
ip_tables              32768  0
x_tables               65536  1 ip_tables
autofs4                57344  2
overlay               217088  1
nls_iso8859_1          12288  1
raid10                 77824  0
raid456               196608  0
async_raid6_recov      20480  1 raid456
async_memcpy           16384  2 raid456,async_raid6_recov
async_pq               20480  2 raid456,async_raid6_recov
async_xor              16384  3 async_pq,raid456,async_raid6_recov
async_tx               16384  5 async_pq,async_memcpy,async_xor,raid456,async_raid6_recov
xor                    20480  2 async_xor,btrfs
raid6_pq              126976  4 async_pq,btrfs,raid456,async_raid6_recov
raid1                  61440  0
raid0                  24576  0
linear                 16384  0
dm_mirror              24576  0
dm_region_hash         24576  1 dm_mirror
dm_log                 20480  2 dm_region_hash,dm_mirror
hid_generic            12288  0
usbhid                 77824  0
hid                   262144  2 usbhid,hid_generic
uas                    32768  0
usb_storage            86016  2 uas
spi_pxa2xx_platform    12288  0
dw_dmac                12288  0
dw_dmac_core           36864  1 dw_dmac
polyval_clmulni        12288  0
spi_pxa2xx_core        28672  1 spi_pxa2xx_platform
8250_dw                20480  0
nvme                   61440  0
polyval_generic        12288  1 polyval_clmulni
ghash_clmulni_intel    16384  0
sha256_ssse3           32768  0
intel_lpss_pci         28672  2
nvme_core             225280  1 nvme
sha1_ssse3             32768  0
r8169                 126976  0
ahci                   49152  0
intel_lpss             12288  1 intel_lpss_pci
video                  77824  0
nvme_auth              28672  1 nvme_core
realtek                49152  1
libahci                53248  1 ahci
idma64                 20480  0
wmi                    28672  2 video,wmi_bmof
pinctrl_alderlake      32768  0
aesni_intel           122880  4
crypto_simd            16384  1 aesni_intel
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel
ubuntu@ubuntu:~$ ^C
Did you check in the BIOS for any RAID mode type setting?
We’ve seen issues like this when this kind of setting is enabled.
I have and there are no RAID settings in the BIOS.
Can you show lspci -k and nvme list?
ubuntu@ubuntu:~$ nvme list
Node                  Generic               SN                   Model                                    Namespace  Usage                      Format           FW Rev
/dev/nvme0n1          /dev/ng0n1            BE250738142D00834593 PCIe SSD                                 0x1        512.11  GB / 512.11  GB    512   B +  0 B   EHFM90.1
ubuntu@ubuntu:~$ lspci -k
00:00.0 Host bridge: Intel Corporation Device 461c
DeviceName: Onboard - Other
Subsystem: Intel Corporation Device 7270
Kernel driver in use: igen6_edac
Kernel modules: igen6_edac
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-N [UHD Graphics]
DeviceName: Onboard - Video
Subsystem: Intel Corporation Alder Lake-N [UHD Graphics]
Kernel driver in use: i915
Kernel modules: i915, xe
00:14.0 USB controller: Intel Corporation Alder Lake-N PCH USB 3.2 xHCI Host Controller
Kernel driver in use: xhci_hcd
00:14.2 RAM memory: Intel Corporation Alder Lake-N PCH Shared SRAM
00:14.3 Network controller: Intel Corporation CNVi: Wi-Fi
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Wi-Fi 6 AX101NGW
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller: Intel Corporation Device 54e8
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Device 54e9
00:16.0 Communication controller: Intel Corporation Alder Lake-N PCH HECI Controller
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Device 54d3
DeviceName: Onboard - SATA
Kernel driver in use: ahci
Kernel modules: ahci
00:19.0 Serial bus controller: Intel Corporation Device 54c5
00:19.1 Serial bus controller: Intel Corporation Device 54c6
00:1c.0 PCI bridge: Intel Corporation Device 54be
Kernel driver in use: pcieport
00:1d.0 PCI bridge: Intel Corporation Device 54b2
00:1e.0 Communication controller: Intel Corporation Device 54a8
00:1e.3 Serial bus controller: Intel Corporation Device 54ab
00:1f.0 ISA bridge: Intel Corporation Alder Lake-N PCH eSPI Controller
00:1f.3 Audio device: Intel Corporation Alder Lake-N PCH High Definition Audio Controller
DeviceName: Onboard - Sound
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
00:1f.4 SMBus: Intel Corporation Device 54a3
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller: Intel Corporation Device 54a4
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Kernel driver in use: r8169
Kernel modules: r8169
02:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5015-E15 PCIe3 NVMe Controller (DRAM-less) (rev 01)
Subsystem: Phison Electronics Corporation PS5015-E15 PCIe3 NVMe Controller (DRAM-less)
Kernel driver in use: nvme
Kernel modules: nvme
Okay, not seeing anything problematic there.
Could you try booting IncusOS again and this time wait for the 10min (or 15min, not sure) timeout?
Once the timeout hits, the screen will start alternating between various debug views which should help see what’s going on.
I really hope something in here helps. Thanks for all your amazing work, love Incus!
It looks like a failure to setup the encrypted storage through the TPM.
We’ve seen issues like that in rare situations where the TPM is in a bad state.
Could you reboot your machine, go in the BIOS and reset the TPM?
Most BIOS have an option to trigger a TPM clear or reset command.
That worked! I had already set the TPM in the reset mode several times before but I always immediately tried reinstalling after, I never just rebooted. FYI I looked at my TPM keys when Incusos was failing to start and there were 4 Incus keys there and now with it working there are 4 keys there, I have looked at the keys and everything looks the same as when it wouldn’t start, which is a bit confusing. Is there anything I can do to help? If any logs or other info might help fix whatever happened for future installs just let me know. Thank you for your help, the work you do is amazing!
The keys would be Secure Boot and therefore unrelated to TPM.
The content of the TPM isn’t shown in the BIOS, the only thing that’s typically available is some control on the supported hashes, on what gets measured in early boot and then the option to clear its content.
