MTL
(MTL)
August 6, 2021, 6:05pm
1
Installed by downloading lxc-3.0.1.tar.gz
Executed ./configure && make && sudo make install|
but lxc --version returns nothing.
But tools (like lxc-create,lxc-start ) returns their version as 3.0.1
did i miss anything?
I want to install particular version of lxc 3.0.1 and not the one available from my linux distribution
stgraber
(Stéphane Graber)
August 6, 2021, 6:53pm
2
That’d be because lxc isn’t actually a valid command. lxc is either the LXD client (so completely different thing) or is a shell script that your distribution provided.
The only binaries you’ll get when building LXC are lxc-*
MTL
(MTL)
August 6, 2021, 7:04pm
3
Thank you for the reply…
But when we do “sudo apt-get install lxc” we can see the version for lxc
lxc --version works then.
What is the need of this client then, over the binaries we build for lxc-create, lxc-start …
stgraber
(Stéphane Graber)
August 6, 2021, 7:11pm
4
In Ubuntu, lxc gets you the LXD client.
See Comparing LXD vs. LXC
