IP renumbering bricked the system but only after a reboot
// <tl;dr>
A single instance IncusOS node is currently unable to start the incus application with cannot assign requested address, after I changed it’s IP addresses, confirmed everything is still working and later rebooting the device.
// How I got there
I was running 202611241409 when I had to renumber a single node system because of a network change (both IPv4 and IPv6). After changing the local and router IPv4/IPv6 as well as the routes in the network configuration with incus admin os system network edit, it was behaving as per usual. incus list showed my container. All good, I confirmed with incus admin os system network confirm.
The changes to my network demanded moving equipment physically, and because of that I had to shutdown and power disconnect the device. Only then, after restarting the node I could no longer connect to the IncusOS host.
Unable to connect to: <myhost.my.domain>:8443
I could ping it though on both the IPv4 and the IPv6 address.
In the beginning I thought it must have been a firewall change which happened in parallel, as it was also complaining about it not being able to reach images.linuxcontainers.org. I fixed that, and still got the same result. But that confirmed, that the IP setup still must be correct as outbound connectivity at least for IPv4 was given (outbound traffic to images.linuxcontainers.org are in the firewall logs).
This is the last line in the UI log (visible via connected monitor) after starting up:
Starting application name=incus version=7.6 (202611241409)
// My impatient behaviour
Nothing more is shown, and it did not suggest any error or issues with the system. At this point I could not connect to the system. Only when I clicked the power button of the device and the system shuts down, I got a brief one second window to see another message (had to video record). This message would (as I later found out) also be shown after the long waiting period:
ERROR: Failed to run: systemctl start incus.socket incus-lxcfs.service incus-startup.service incus.service: exit status 1 (Job for incus-startup.service canceled. Job for incus.service canceled.)
WARN: Primary application incus failed to start: attempting to enable fallback HTTPS server for basic connectivity.
INFO: Fallback HTTPS listener started on :40399
INFO: System is ready version=202611241409
I was wondering if the fallback is already being started in the background, without it being displayed. It does not appear to be the case, and because of the changing high port, that would be of no use anyway.
When booting the backup image 202611182248 there is a bit more log output as it points out the use of the backup image and skips auto-updating. Apart from that, I got exactly the same behaviour.
// My patient behaviour
According to the timestamps of the log, after around 10 minutes of silent waiting, the same error message appears, the fallback mode is being started and I was able to connect to it.
My network configuration contains required_for_online: both and IPv6 configuration didn’t seem to work.
  default_confirmation_timeout: 5m
  dns:
    domain: <my.domain>
    hostname: <myhost>
    nameservers:
    - 192.168.zzz.1
    - fdxx:yyyy:zzzz:1::1
  ignore_service_checks: false
  interfaces:
  - addresses:
    - 192.168.zzz.55/24
    - fdxx:yyyy:zzzz:1::55/64
    hwaddr: aa:bb:cc:dd:ee:ff
    roles:
    - management
    - instances
    routes:
    - to: 0.0.0.0/0
      via: 192.168.zzz.1
    - to: ::/0
      via: fdxx:yyyy:zzzz:1::1
  time:
    timezone: UTC
state:
  configuration_in_process: false
  interfaces:
    enp2s0:
      addresses:
      - 192.168.zzz.55
      mtu: 1500
      roles:
      - management
      - instances
      - cluster
      routes:
      - to: default
        via: 192.168.zzz.1
      speed: "1000"
      state: routable
      stats:
        rx_bytes: 387748
        rx_errors: 0
        tx_bytes: 1.0662611e+07
        tx_errors: 0
      type: interface
I found out, that I failed to configure NPTv6 on my firewall/router, so I suspected this must be the cause. However, even after configuring that and switching required_for_online to any, the incus application still wouldn’t come up following the same behaviour.
incus admin os debug log | grep -i error showed this
[2026/11/27 20:58:51 CET] incusd: time="2026-11-27T19:58:51Z" level=error msg="Failed to start the daemon" err="Failed starting metrics listener: Bind network address: listen tcp [fdaa:bbbb:cccc::55]:8444: bind: cannot assign requested address"
[2026/11/27 20:58:51 CET] incusd: Error: Failed starting metrics listener: Bind network address: listen tcp [fdaa:bbbb:cccc::55]:8444: bind: cannot assign requested address
[2026/11/27 20:58:51 CET] incus-startup: Error: Get "http://unix.socket/1.0": EOF
[2026/11/27 20:58:51 CET] incus-osd: 2026-11-27 19:58:51 ERROR Failed to run: systemctl start incus.socket incus-lxcfs.service incus-startup.service incus.service: exit status 1 (Job for incus.service failed because the control process exited with error code.
[2026/11/27 20:58:51 CET] incus-osd: Job for incus-startup.service failed because the control process exited with error code.
With fdaa:bbbb:cccc::55 being the old IPv6 which I had replaced in the very beginning with fdxx:yyyy:zzzz:1::55.
I checked if others in the forum had similiar issues, and found eg. this post, but that appears to be about a netmask only issue, and I don’t see any configuration error like that on my side currently.
// Current (open) status
My last idea currently is to revive the old network prefix somehow. But that is quite some work.
So has anyone any ideas where in the configuration this old IPv6 could still be lurking? Somewhere in incus config ... maybe? I couldn’t find it though. Any suggestion is appreciated!
// Sidenote: Some UX suggestions
  • If possible, Starting foo steps in the console could indicate that it’s in a “wait/starting” state, eg. with the infamous growing . line after Starting application ...... or similar.
  • If interaction in the console view is eventually be possible, allow to interupt a startup after a couple of seconds, so we can speed up the process of reaching the fall-back listener.
  • Until then, maybe reduce the timeout a bit. I am in OPS, and not knowing a systems state is more stressful than knowing it is borked. No an expert on typical incus startup times obviously, but generally speaking anything over 5 minutes of app startup would seem excessive to me. It is not java after all.
  • (If not done already) After changing the network configuration and required_for_online: both is set, confirm connectivity on IPv4 and IPv6, otherwise fail.
Not sure, why I didn’t think of this earlier. Just re-adding the “old” IP fdaa:bbbb:cccc::55 to the interface, fixed it in the sense, that incus can start again. I can now connect again and incus list and the rest works just fine.
But nothing in my network is on fdaa:bbbb:cccc::, so the traffic must go through the other IP adresses, and incus seems to bind to all those adresses.
And removing the old fdaa:bbbb:cccc::55 brings me back to where I started, with the incus app not being able to start.
So I’d still appreciate any potential input, as to where this configuration could sit and be modified.
Yeah, look at incus config edit, sounds like you have core.metrics_address set to a specific address rather than a wildcard.
I’ll have a look at that logic as normally the only fatal listener should be cluster.https_address, all the others should allow for startup even if they fail, and then retry in the background, so it’s weird to see the metrics one blocking startup here.
