pachulo
(M)
August 1, 2024, 12:07am
1
Hi! I’m setting up a container for nextcloud and I would like to configure multiple ZFS datasets for different data (more context here ).
I was expecting that, by setting the zfs.delegate=true on the storage volume, I would be able to create and mount nested ZFS datasets from inside the container, but I can’t get it to work.
Here are the full steps:
On the hotst, I’ve created a new ZFS dataset:sudo zfs create lake/incus
Then a new incus storage pool:incus storage create incus-zfs-dataset zfs source=lake/incus
After that, I’ve created a new volume inside it:incus storage volume create incus-zfs-dataset nextcloud
And set the zfs.delegate property, so that the container can manage it:incus storage volume set incus-zfs-dataset custom/nextcloud zfs.delegate=true
I then attached it to the container on the /mnt/nextcloud path:incus storage volume attach incus-zfs-dataset custom/nextcloud nextcloud-container /mnt/nextcloud
Then, from inside the container:incus exec nextcloud-container -- su --login ubuntu
I created a nested dataset:sudo zfs create lake/incus/custom/default_nextcloud/preview
When trying to use the mount command:sudo mount -F zfs lake/incus/custom/default_nextcloud/preview /mnt/nextcloud/data/appdata_ociemmj53qt4/preview
I got this error:mount: bad usage
Try 'mount --help' for more information.
And when trying zfs mount:zfs set mountpoint=/mnt/nextcloud/data/appdata_ociemmj53qt4/preview lake/incus/custom/default_nextcloud/preview
I’m getting the following permission denied error:cannot mount 'lake/incus/custom/default_nextcloud/preview': Permission denied
property may be set but unable to remount filesystem
I guess I should be able to create a new storage volume inside the incus storage pool from the host, and then attach it to the container, but I was curious to know if I could do it from inside the container.
Thanks!
stgraber
(Stéphane Graber)
August 1, 2024, 6:14am
2
That should be mount -t zfs lake/incus/custom/default_nextcloud/preview /mnt/nextcloud/data/appdata_ociemmj53qt4/preview
pachulo
(M)
August 1, 2024, 9:17am
3
Sorry, I forgot to mention that I also tried that:
$ sudo mount -t zfs lake/incus/custom/default_nextcloud/preview /mnt/nextcloud/data/appdata_ociemmj53qt4/preview
filesystem 'lake/incus/custom/default_nextcloud/preview' can not be mounted: Permission denied
stgraber
(Stéphane Graber)
August 2, 2024, 1:38am
4
stgraber@dakara:~$ incus launch images:ubuntu/24.04 u1
Launching u1
stgraber@dakara:~$ incus storage volume create default u1-extra size=10GiB zfs.delegate=true
Storage volume u1-extra created
stgraber@dakara:~$ incus config device add u1 extra disk pool=default source=u1-extra path=/mnt
Device extra added to u1
stgraber@dakara:~$ incus exec u1 bash
root@u1:~# apt install zfsutils-linux
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
libbrotli1 libcurl4t64 libldap-common libldap2 libnghttp2-14 libnvpair3linux libpsl5t64 librtmp1 libsasl2-2 libsasl2-modules libsasl2-modules-db libssh-4
libuutil3linux libzfs4linux libzpool5linux publicsuffix zfs-zed
Suggested packages:
libsasl2-modules-gssapi-mit | libsasl2-modules-gssapi-heimdal libsasl2-modules-ldap libsasl2-modules-otp libsasl2-modules-sql nfs-kernel-server
samba-common-bin zfs-initramfs | zfs-dracut
The following NEW packages will be installed:
libuutil3linux libzfs4linux libzpool5linux publicsuffix zfs-zed zfsutils-linux
0 upgraded, 18 newly installed, 0 to remove and 0 not upgraded.
Need to get 3900 kB of archives.
After this operation, 11.7 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://archive.ubuntu.com/ubuntu noble/main amd64 libnvpair3linux amd64 2.2.2-0ubuntu9 [61.5 kB]
Get:2 http://archive.ubuntu.com/ubuntu noble/main amd64 libuutil3linux amd64 2.2.2-0ubuntu9 [52.6 kB]
Get:3 http://archive.ubuntu.com/ubuntu noble/main amd64 libzfs4linux amd64 2.2.2-0ubuntu9 [225 kB]
Get:4 http://archive.ubuntu.com/ubuntu noble/main amd64 libzpool5linux amd64 2.2.2-0ubuntu9 [1397 kB]
Get:5 http://archive.ubuntu.com/ubuntu noble/main amd64 zfsutils-linux amd64 2.2.2-0ubuntu9 [551 kB]
Get:6 http://archive.ubuntu.com/ubuntu noble/main amd64 zfs-zed amd64 2.2.2-0ubuntu9 [67.9 kB]
Get:7 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 libnghttp2-14 amd64 1.59.0-1ubuntu0.1 [74.3 kB]
Get:8 http://archive.ubuntu.com/ubuntu noble/main amd64 libpsl5t64 amd64 0.21.2-1.1build1 [57.1 kB]
Get:9 http://archive.ubuntu.com/ubuntu noble/main amd64 publicsuffix all 20231001.0357-0.1 [129 kB]
Get:10 http://archive.ubuntu.com/ubuntu noble/main amd64 libbrotli1 amd64 1.1.0-2build2 [331 kB]
Get:11 http://archive.ubuntu.com/ubuntu noble/main amd64 libsasl2-modules-db amd64 2.1.28+dfsg1-5ubuntu3 [20.3 kB]
Get:12 http://archive.ubuntu.com/ubuntu noble/main amd64 libsasl2-2 amd64 2.1.28+dfsg1-5ubuntu3 [53.2 kB]
Get:13 http://archive.ubuntu.com/ubuntu noble/main amd64 libldap2 amd64 2.6.7+dfsg-1~exp1ubuntu8 [195 kB]
Get:14 http://archive.ubuntu.com/ubuntu noble/main amd64 librtmp1 amd64 2.4+20151223.gitfa8646d.1-2build7 [56.3 kB]
Get:15 http://archive.ubuntu.com/ubuntu noble/main amd64 libssh-4 amd64 0.10.6-2build2 [188 kB]
Get:16 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 libcurl4t64 amd64 8.5.0-2ubuntu10.1 [341 kB]
Get:17 http://archive.ubuntu.com/ubuntu noble/main amd64 libldap-common all 2.6.7+dfsg-1~exp1ubuntu8 [31.4 kB]
Get:18 http://archive.ubuntu.com/ubuntu noble/main amd64 libsasl2-modules amd64 2.1.28+dfsg1-5ubuntu3 [69.7 kB]
Fetched 3900 kB in 1s (4713 kB/s)
Selecting previously unselected package libnvpair3linux.
(Reading database ... 16107 files and directories currently installed.)
Preparing to unpack .../00-libnvpair3linux_2.2.2-0ubuntu9_amd64.deb ...
Unpacking libnvpair3linux (2.2.2-0ubuntu9) ...
Selecting previously unselected package libuutil3linux.
Preparing to unpack .../01-libuutil3linux_2.2.2-0ubuntu9_amd64.deb ...
Unpacking libuutil3linux (2.2.2-0ubuntu9) ...
Selecting previously unselected package libzfs4linux.
Preparing to unpack .../02-libzfs4linux_2.2.2-0ubuntu9_amd64.deb ...
Unpacking libzfs4linux (2.2.2-0ubuntu9) ...
Selecting previously unselected package libzpool5linux.
Preparing to unpack .../03-libzpool5linux_2.2.2-0ubuntu9_amd64.deb ...
Unpacking libzpool5linux (2.2.2-0ubuntu9) ...
Selecting previously unselected package zfsutils-linux.
Preparing to unpack .../04-zfsutils-linux_2.2.2-0ubuntu9_amd64.deb ...
Unpacking zfsutils-linux (2.2.2-0ubuntu9) ...
Selecting previously unselected package zfs-zed.
Preparing to unpack .../05-zfs-zed_2.2.2-0ubuntu9_amd64.deb ...
Unpacking zfs-zed (2.2.2-0ubuntu9) ...
Selecting previously unselected package libnghttp2-14:amd64.
Preparing to unpack .../06-libnghttp2-14_1.59.0-1ubuntu0.1_amd64.deb ...
Unpacking libnghttp2-14:amd64 (1.59.0-1ubuntu0.1) ...
Selecting previously unselected package libpsl5t64:amd64.
Preparing to unpack .../07-libpsl5t64_0.21.2-1.1build1_amd64.deb ...
Unpacking libpsl5t64:amd64 (0.21.2-1.1build1) ...
Selecting previously unselected package publicsuffix.
Preparing to unpack .../08-publicsuffix_20231001.0357-0.1_all.deb ...
Unpacking publicsuffix (20231001.0357-0.1) ...
Selecting previously unselected package libbrotli1:amd64.
Preparing to unpack .../09-libbrotli1_1.1.0-2build2_amd64.deb ...
Unpacking libbrotli1:amd64 (1.1.0-2build2) ...
Selecting previously unselected package libsasl2-modules-db:amd64.
Preparing to unpack .../10-libsasl2-modules-db_2.1.28+dfsg1-5ubuntu3_amd64.deb ...
Unpacking libsasl2-modules-db:amd64 (2.1.28+dfsg1-5ubuntu3) ...
Selecting previously unselected package libsasl2-2:amd64.
Preparing to unpack .../11-libsasl2-2_2.1.28+dfsg1-5ubuntu3_amd64.deb ...
Unpacking libsasl2-2:amd64 (2.1.28+dfsg1-5ubuntu3) ...
Selecting previously unselected package libldap2:amd64.
Preparing to unpack .../12-libldap2_2.6.7+dfsg-1~exp1ubuntu8_amd64.deb ...
Unpacking libldap2:amd64 (2.6.7+dfsg-1~exp1ubuntu8) ...
Selecting previously unselected package librtmp1:amd64.
Preparing to unpack .../13-librtmp1_2.4+20151223.gitfa8646d.1-2build7_amd64.deb ...
Unpacking librtmp1:amd64 (2.4+20151223.gitfa8646d.1-2build7) ...
Selecting previously unselected package libssh-4:amd64.
Preparing to unpack .../14-libssh-4_0.10.6-2build2_amd64.deb ...
Unpacking libssh-4:amd64 (0.10.6-2build2) ...
Selecting previously unselected package libcurl4t64:amd64.
Preparing to unpack .../15-libcurl4t64_8.5.0-2ubuntu10.1_amd64.deb ...
Unpacking libcurl4t64:amd64 (8.5.0-2ubuntu10.1) ...
Selecting previously unselected package libldap-common.
Preparing to unpack .../16-libldap-common_2.6.7+dfsg-1~exp1ubuntu8_all.deb ...
Unpacking libldap-common (2.6.7+dfsg-1~exp1ubuntu8) ...
Selecting previously unselected package libsasl2-modules:amd64.
Preparing to unpack .../17-libsasl2-modules_2.1.28+dfsg1-5ubuntu3_amd64.deb ...
Unpacking libsasl2-modules:amd64 (2.1.28+dfsg1-5ubuntu3) ...
Setting up libnvpair3linux (2.2.2-0ubuntu9) ...
Setting up libbrotli1:amd64 (1.1.0-2build2) ...
Setting up libsasl2-modules:amd64 (2.1.28+dfsg1-5ubuntu3) ...
Setting up libpsl5t64:amd64 (0.21.2-1.1build1) ...
Setting up libnghttp2-14:amd64 (1.59.0-1ubuntu0.1) ...
Setting up libldap-common (2.6.7+dfsg-1~exp1ubuntu8) ...
Setting up libsasl2-modules-db:amd64 (2.1.28+dfsg1-5ubuntu3) ...
Setting up librtmp1:amd64 (2.4+20151223.gitfa8646d.1-2build7) ...
Setting up libsasl2-2:amd64 (2.1.28+dfsg1-5ubuntu3) ...
Setting up libssh-4:amd64 (0.10.6-2build2) ...
Setting up libuutil3linux (2.2.2-0ubuntu9) ...
Setting up publicsuffix (20231001.0357-0.1) ...
Setting up libldap2:amd64 (2.6.7+dfsg-1~exp1ubuntu8) ...
Setting up libzpool5linux (2.2.2-0ubuntu9) ...
Setting up libcurl4t64:amd64 (8.5.0-2ubuntu10.1) ...
Setting up libzfs4linux (2.2.2-0ubuntu9) ...
Setting up zfsutils-linux (2.2.2-0ubuntu9) ...
modprobe: FATAL: Module zfs not found in directory /lib/modules/6.9.12-zabbly+
Created symlink /etc/systemd/system/zfs-import.target.wants/zfs-import-cache.service → /usr/lib/systemd/system/zfs-import-cache.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-import.target → /usr/lib/systemd/system/zfs-import.target.
Created symlink /etc/systemd/system/zfs-mount.service.wants/zfs-load-module.service → /usr/lib/systemd/system/zfs-load-module.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-load-module.service → /usr/lib/systemd/system/zfs-load-module.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-mount.service → /usr/lib/systemd/system/zfs-mount.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-share.service → /usr/lib/systemd/system/zfs-share.service.
Created symlink /etc/systemd/system/zfs-volumes.target.wants/zfs-volume-wait.service → /usr/lib/systemd/system/zfs-volume-wait.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-volumes.target → /usr/lib/systemd/system/zfs-volumes.target.
Created symlink /etc/systemd/system/multi-user.target.wants/zfs.target → /usr/lib/systemd/system/zfs.target.
zfs-import-scan.service is a disabled or a static unit, not starting it.
Setting up zfs-zed (2.2.2-0ubuntu9) ...
Created symlink /etc/systemd/system/zed.service → /usr/lib/systemd/system/zfs-zed.service.
Created symlink /etc/systemd/system/zfs.target.wants/zfs-zed.service → /usr/lib/systemd/system/zfs-zed.service.
Processing triggers for libc-bin (2.39-0ubuntu8.2) ...
root@u1:~# zfs list -t all
dakara 273G 533G 98K none
dakara/incus 119G 533G 105K legacy
dakara/incus/custom 7.83G 533G 105K legacy
dakara/incus/custom/default_u1-extra 98K 10.0G 98K legacy
root@u1:~# zfs create dakara/incus/custom/default_u1-extra/foo
dakara/incus/custom/default_u1-extra 196K 10.0G 98K legacy
dakara/incus/custom/default_u1-extra/foo 98K 10.0G 98K legacy
root@u1:~# mount -t zfs dakara/incus/custom/default_u1-extra/foo /srv/
root@u1:~# df -h
dakara/incus/containers/u1 21G 334M 20G 2% /
none 492K 4.0K 488K 1% /dev
efivarfs 128K 36K 88K 29% /sys/firmware/efi/efivars
tmpfs 100K 0 100K 0% /dev/incus
tmpfs 100K 0 100K 0% /dev/.incus-mounts
tmpfs 32G 0 32G 0% /dev/shm
tmpfs 13G 124K 13G 1% /run
dakara/incus/custom/default_u1-extra 10G 128K 10G 1% /mnt
dakara/incus/custom/default_u1-extra/foo 10G 128K 10G 1% /srv
root@u1:~#
pachulo
(M)
August 5, 2024, 10:21am
5
First of all, thanks a lot for your help @stgraber !
I’ve tried to reproduce your example, but got the same permission denied error:
Launching u1
$ incus storage volume create incus-zfs-dataset u1-extra size=10GiB zfs.delegate=true
$ incus config device add u1 extra disk pool=incus-zfs-dataset source=u1-extra path=/mnt
libbrotli1 libcurl4t64 libldap-common libldap2 libnghttp2-14 libnvpair3linux libpsl5t64 librtmp1 libsasl2-2 libsasl2-modules libsasl2-modules-db libssh-4 libuutil3linux libzfs4linux libzpool5linux
Suggested packages:
libsasl2-modules-gssapi-mit | libsasl2-modules-gssapi-heimdal libsasl2-modules-ldap libsasl2-modules-otp libsasl2-modules-sql nfs-kernel-server samba-common-bin zfs-initramfs | zfs-dracut
Fetched 3900 kB in 1s (2874 kB/s)
modprobe: FATAL: Module zfs not found in directory /lib/modules/6.8.0-39-generic
lake 64.4G 14.3T 234K /lake
lake/incus 64.4G 14.3T 234K legacy
lake/incus/custom 64.4G 14.3T 234K legacy
lake/incus/custom/default_u1-extra 234K 10.0G 234K legacy
root@u1:~# zfs create lake/incus/custom/default_u1-extra/foo
lake/incus/custom/default_u1-extra 469K 10.0G 234K legacy
lake/incus/custom/default_u1-extra/foo 234K 10.0G 234K legacy
root@u1:~# mount -t zfs lake/incus/custom/default_u1-extra/foo /srv/
filesystem 'lake/incus/custom/default_u1-extra/foo' can not be mounted: Permission denied
And the only difference I can think of is that I’m not working with the default storage pool, but an additional one I created:
$ sudo zfs create lake/incus
$ incus storage create incus-zfs-dataset zfs source=lake/incus
$ incus storage list
| NAME | DRIVER | DESCRIPTION | USED BY | STATE |
| default | lvm | | 5 | CREATED |
| incus-zfs-dataset | zfs | | 2 | CREATED |
$ incus storage show incus-zfs-dataset
source: lake/incus
volatile.initial_source: lake/incus
zfs.pool_name: lake/incus
driver: zfs
- /1.0/storage-pools/incus-zfs-dataset/volumes/custom/u1-extra
status: Created
locations:
- none
stgraber
(Stéphane Graber)
August 5, 2024, 4:01pm
6
Can you look for any DENIED entries in dmesg?
pachulo
(M)
August 5, 2024, 8:09pm
7
Yes indeed:
[326838.334609] audit: type=1400 audit(1722503823.764:560): apparmor="DENIED" operation="mount" class="mount" info="failed perms check" error=-13 profile="incus-nextcloud-container_</var/lib/incus>" name="/mnt/nextcloud/data/appdata_ociemmj53qt4/preview/" pid=123975 comm="mount.zfs" fstype="zfs" srcname="lake/incus/custom/default_nextcloud/preview"
[632638.920310] audit: type=1400 audit(1722809624.000:564): apparmor="DENIED" operation="mount" class="mount" info="failed perms check" error=-13 profile="incus-nextcloud-container_</var/lib/incus>" name="/srv/" pid=163900 comm="mount.zfs" fstype="zfs" srcname="lake/incus/custom/default_nextcloud/preview"
[675384.710007] audit: type=1400 audit(1722852369.743:577): apparmor="DENIED" operation="mount" class="mount" info="failed perms check" error=-13 profile="incus-u1_</var/lib/incus>" name="/srv/" pid=182898 comm="mount.zfs" fstype="zfs" srcname="lake/incus/custom/default_u1-extra/foo"
By the way, the host runs Ubuntu 24.04 with the 6.8.0-39-generic kernel.
stgraber
(Stéphane Graber)
August 5, 2024, 9:17pm
8
Okay, try putting raw.apparmor=mount fstype=zfs, in your container config, that should take care of that.
I’ll look at adding that to the generated profile, not sure why it’s not there already and even less sure why it’s not needed on my system…
pachulo
(M)
August 6, 2024, 9:07am
10
stgraber:
I added it like this:
$ incus config set u1 raw.apparmor "mount fstype=zfs,"
And now it works!
I understand then that because this is now merged , the workaround won’t be necessary on next Incus version, right?
Thanks for all the support!
stgraber
(Stéphane Graber)
August 6, 2024, 1:30pm
11
That’s right, the fix will be in Incus 6.4.
