Hi All,
If I start my container(unprivileged) or start then shutdown, the host file system will become read-only.
So if I try to remount the host file system as read-write, I’ll get this error:
‘cannot remount /dev read-write, is write-protected’
I see that the during startup, the container will set the option ‘errors=remount-ro’. But this should only happens when an error occurs? I’ve also tried disabling capabilities, but this doesn’t work. Does anyone knows what might be going on?
Thanks!
