Related to:
- https://github.com/lxc/lxd/issues/5486
- https://github.com/lxc/lxc/issues/1841
- (Maybe) LXC(3.10) container marks host file system as read-only
OS: debian 10
Problem:
# lxc-create -t download -n test-1 -B loop --fssize 2G --fstype ext4 -- -d centos -r 6 -a amd64 ; lxc-start test-1 ; lxc-stop test-1 ; lxc-start test-1
lxc-start: test-1: lxccontainer.c: wait_on_daemonized_start: 842 Received container state "ABORTING" instead of "RUNNING"
lxc-start: test-1: tools/lxc_start.c: main: 330 The container failed to start
lxc-start: test-1: tools/lxc_start.c: main: 333 To get more details, run the container in foreground mode
lxc-start: test-1: tools/lxc_start.c: main: 336 Additional information can be obtained by setting the --logfile and --logpriority options
all because of devpts on host became read only. You can easily fix it with mount -t devpts -o remount,gid=5,mode=620 devpts /dev/pts after each stop of container, but it’s durty. I know guys in Proxmox project somehow “fix” it, there you can start/stop containers as many times as you want without remount something.
In proxmox they somehow use apparmor (as i think) to prevent remount of devpts. In logs i see
Aug 4 23:33:56 test kernel: [11149.862155] audit: type=1400 audit(1596540836.368:77): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/dev/" pid=21831 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.865306] audit: type=1400 audit(1596540836.368:78): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/sys/net/" pid=21833 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.867154] audit: type=1400 audit(1596540836.372:79): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/sys/" pid=21834 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.868787] audit: type=1400 audit(1596540836.372:80): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/sysrq-trigger" pid=21835 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.874872] audit: type=1400 audit(1596540836.380:81): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/sys/devices/virtual/net/" pid=21838 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.876520] audit: type=1400 audit(1596540836.380:82): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/sys/devices/virtual/net/" pid=21839 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.878365] audit: type=1400 audit(1596540836.384:83): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/cpuinfo" pid=21840 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.879960] audit: type=1400 audit(1596540836.384:84): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/diskstats" pid=21841 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.881547] audit: type=1400 audit(1596540836.384:85): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/loadavg" pid=21842 comm="mount" flags="ro, remount"
Aug 4 23:33:56 test kernel: [11149.883390] audit: type=1400 audit(1596540836.388:86): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-101_</var/lib/lxc>" name="/proc/meminfo" pid=21843 comm="mount" flags="ro, remount"
Unfortunately, i completely don’t know how to set apparmor. So, maybe someone know how to avoid this behavior, or maybe set apparmor?
